Old 01-04-2009, 01:18 AM   #51
justcuz
justcuz's Avatar
Re: NAPCO Thread
Originally Posted by Walts_restoration View Post
is it the same trans as the 2wds used?
Yes, because it has a divorced t-case a 2wd transmission can be used.
justcuz is offline   Reply With Quote
Old 01-04-2009, 02:14 AM   #52
abebummy26
abebummy26's Avatar
Re: NAPCO Thread
uh if its a 57 it might not be a true napco it could be a factory 4x4
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 01-04-2009, 09:48 AM   #53
Re: NAPCO Thread
Not yet in`57.And,the first factory 4wds were Napcos.
Old 01-04-2009, 11:24 AM   #54
renegade6
Re: NAPCO Thread
Originally Posted by AK56 View Post
Hello, I picked up this 56 this fall, getting ready to tear it apart for paint, upgrades and a 396. My goal is to keep the axles to preserve a little of its heritage but will replace tranny and Tcase with something more modern. Somebody put a car 4 speed in it along the way and the Tcase is pretty noisey.i had a bad experience with a divorced Tcase on an old power wagon so I am going with a T350/np205 if I can make it fit.
What size of tires/rims are you using?
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 01-04-2009, 12:30 PM   #55
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Re: NAPCO Thread
trust me, shes a napco. Ive also got a a buddy of mine was converting to a napco-like truck, but he was going to use a late 70s drive train (bbc, th400 np205).
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 01-04-2009, 04:05 PM   #56
too much stuff
Roadtrip!
too much stuff's Avatar
Re: NAPCO Thread
Probably my favorite napco. Belongs to board member sakohntr. I believe it had 28,XXX actual miles when he bought this. We left grand rapids MN in a cavalier, drove past golden colorado, gave the car away and jumped in this thing and drove it home. 292, 4 speed and 5:13 gears. I think we hit 55mph a couple times briefly. Bruce will add more i think after he sees this.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 01-04-2009, 07:39 PM   #57
Re: NAPCO Thread
There she is,one of the most beautiful trucks on this website!
And what a cool adventure.Just do it!
Old 01-05-2009, 12:02 AM   #58
AK56
AK56's Avatar
Re: NAPCO Thread
They are BFG AT's 305/70/16 about 33" tall 12" wide
AK56 is offline   Reply With Quote
Old 01-05-2009, 12:12 AM   #59
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
Re: NAPCO Thread
Here are some pics of some NAPCO'S
66Gilbert is offline   Reply With Quote
Old 01-11-2009, 02:29 PM   #60
Re: NAPCO Thread
You didn`t post this one:
Old 01-11-2009, 08:11 PM   #61
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: NAPCO Thread
Special-K, check out http://www.firenews.org/listing.html
Lots of hot trucks.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 01-11-2009, 11:54 PM   #62
Re: NAPCO Thread
Thanks for the helpful link.I ended up there before somehow.
Old 01-19-2009, 01:56 PM   #63
justcuz
justcuz's Avatar
Re: NAPCO Thread
I've seen several 3/4 ton Napco's in GM products and they all had transfer case output and front axle pumpkins were on the drivers side as opposed to the 1/2 tons that were all on the passenger side. Why do you suppose that is? It would seem easier to keep them all the same. I am gonna check the Napco site and see if they have an explination.
Old 01-19-2009, 08:47 PM   #64
justcuz
justcuz's Avatar
Re: NAPCO Thread
Looked at Napco site, picture gallery has 3/4 and 1 tons with front drive on either side. What gives?
Old 01-19-2009, 09:51 PM   #65
Bad4wd
Re: NAPCO Thread
1955, 1st series 3/4 ton and up and 2nd series gm trucks and earlier years should all be driver side. 1956 to "59 Napco trucks should all be pass. side. 1955 was the odd year because of the two differant trucks in the same year. The second series "55 1/2 ton went to a cv joint rear driveshaft instead of the old torque tube style, So you could easily put blocks in the back to raise the rear to match the frt. heght. I had a 2nd series "55 chevy 1/2 ton with a driv. side 8-lug, 3.90 gear and 2 lever rockwell transfer case. Napco also made a 1" thick spacer for the rear axle for the "55 1/2 ton to go from 6-lugs to 8 but really used only 6-lug nuts on a 8 bolt pattern but you would never know because of the hubcap. I think after "55, Napco had the time to develop a new 6-lug & 8-lug frt axles for the new trucks back then. I think this is right.......Dave.
Bad4wd is offline   Reply With Quote
Old 04-30-2009, 11:06 PM   #66
pulltilbroke
pulltilbroke's Avatar
Re: NAPCO Thread
Heres some pics I snapped of a Big Napco in central NE
60 4x4,235,SM420,Rockwell T221,D44/HO33 sold 4/12
67 C-20,292,SM420,HO72
90 Dodge W250 Cummins,NV4500HD,205,D60/D80
93 Dodge W350 Dually Cummins, Getrag, 205,D60/D70
pulltilbroke is offline   Reply With Quote
Old 04-30-2009, 11:17 PM   #67
thirdstreettito
Resident of Here
Re: NAPCO Thread
Words cannot describe how much I love that truck.
~Bradley~
Miss having a truck
Old 07-14-2009, 11:02 AM   #68
7T2
Active Member
7T2's Avatar
Re: NAPCO Thread
From Goodguys Columbus:
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 07-14-2009, 11:05 AM   #69
7T2
Active Member
7T2's Avatar
Re: NAPCO Thread
more...
1957 GMC Ambulance
1962 Belair Wagon
Old 07-16-2009, 09:11 PM   #70
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: NAPCO Thread
don't tell anyone I'm over here..... but I am a closet NAPCO fanatic! these rigs are just so cool and purpose built!
pulltilbroke,
is that wrecker in Eagle? love to see it in person when I'm through there heading to Ashland.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 07-17-2009, 01:17 PM   #71
martindc1
Re: NAPCO Thread
Isn't that last truck on the very first post a Chevy Army truck? Wouldn't that have been a factory 4x4? And where was the pic taken? If it is not the same one, there is one in Kenton, OH that is exactly the same, faded paint and all.
Currently truckless, previous trucks:
67 K20, 87 K10 aka V10 & 72 C10
martindc1 is offline   Reply With Quote
Old 07-18-2009, 05:07 AM   #72
Re: NAPCO Thread
You`re right.That is a GI Chevy,not a Napco.
Old 07-18-2009, 06:04 AM   #73
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: NAPCO Thread
Came across a 57 Chevy Truck slammed to the ground, he took the body off a original running Napco 4X4. Is it me or is that just wrong!
Old 07-18-2009, 07:05 AM   #74
62 short step
62 short step's Avatar
Re: NAPCO Thread
I loved the slammed trucks too, but that was wrong!
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 07-18-2009, 10:46 AM   #75
Re: NAPCO Thread
very very wrong.Some people have no respect.Aren`t there more 2wd drive trucks available than Napcos?THOUGHT SO!!!
