#51 |
Re: Lets see your seat swaps....
Those are gorgeous....did they bolt right up or? More details if you don't mind.
Here are the ones I used in my 2wd crew front and back, bit of modifying but all in all pretty simple process. Might use these again here, but want to look at some options. Heated, memory, power seats from a 2000 Chrysler Concorde. Probably ditching the headrests as I have always liked the low backs over tall. ![]()
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" |
#52 |
At the body shop.
91/92 seat. Easy easy swap
http://67-72chevytrucks.com/vboard/s...d.php?t=381564 Posted via Mobile Device
" That didnt make it any newer " " Dont antique the equipment " |
#53 | |
Devillusion, They were pretty simple to install. Just remove the mounting brackets and use the ones off you old bench seat. To mount to the seat you will have to drill a new hole on the rear and put a large sheet metal scew in it.There is a place on the seat to do this. On the front of the seat you will have to block it up 1-1/2". I used a piece of wood about 6" long and mounted it left to right with some large sheet metal scews and then scewed the track to that. Worked out great and it seems to be at the right height. I mounted two of them like this . Just have to get the measurement on the hole centers on the truck to get the tracks space correctly. Took me about hour and a half. |
#54 | |
brackets were part # 81196B and 81197B $76.95ea seats were part # 80-1400-51R and 80-1400-51L and $230.95 each all were in stock and shipped from www.summitracing.com with no oversize charges. ![]() ![]() ![]() ![]()
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
#55 | |
Look at the summit mounts above. Hits 3 factory bolt holes. Nice Last edited by wraprail; 12-29-2012 at 12:25 PM. |
#56 | |
#57 |
this was in the truck when i purchased? no information on the saet.
#58 |
oh yea good idea...please mount those seats. it's important. last fall i bought a nova with much $$$ in the motor only to find small self tapping trim screws holding the racing seats in place. what the truck was somebody thinkin? easy eject? wow pants almost turned brown when i found those small screws. why throw the oars out in the middle of the lake?
#59 | |
#60 | |
I would have to agree....and even going as far as putting another plate or massive washer underneath if you have to drill holes through the sheetmetal, that sheetmetal itself won't hold much. On the ones above I welded in plates top and bottom 1/8" plate. Just to be on the safe side, kids will be riding around in mine.
#61 |
78K & 79C Jimmys
my 88 had custom mounts with conversion seats big 1/2 bolts and washers under it
get rid of the wood
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#62 | |
#63 | |
2004 Silverado Crewcab (Dark Spiral Gray) |
#64 |
I like these swaps guys. I went a little newer then most of you..
I put a second row seat out of a 2011 Tahoe into my 86 GMC. I had to take off ALL the original mounting brackets and make my own out of angle iron. drilled new holes in my floor as well. |
#65 |
My buddy put seats in his 81 blazer out of a 2000ish chevy IIRC. had them reupholstered by a local guy.
#66 | |
![]() 1985 C10 2004 Avalanche |
#67 |
Just picked these up at Pic-A-Part
1997 Cadillac Eldorado Power recline as well as heated. Black leather $50 each. Note the large flat aluminum seat tracks. Should be an easy straight forward install. Will post pics when finished. ![]() ![]() ![]() |
#68 |
that tahoe seat kicks some major but. the caddy seats look ok too. keep those seat shots coming! thank you
#69 |
![]() Join Date: Jan 2009
#70 | |
Posted via Mobile Device |
#71 | |
How difficult was this swap? Do you happen to have any pictures of the brackets you made? Love the way that looks in there. Nicely done, and how much higher do you sit with those bad boys? |
#72 |
Sorry, I've recently sold the truck and can't get specs on the seat swap. But it sat only an inch or two higher than the stock bench. The back was more vertical as well. They were comfortable. I just cut up the stock 2011 brackets and rewelded them so they'd work... It was a 2 day job. I also use angle iron in some spots.
#73 |
More we need more seat swaps
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#74 |
2001 impreza buckets.... redid the drivers side so now it's about 2 inches lower and 2 inches further back.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
#75 |
2005 Cadillac CTS heated leather.
Console made from toolbox, with LED lighted cup holders. |
