08-22-2009, 01:10 PM | #51 |
Re: 2" Drop Trailing arms
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
08-22-2009, 03:53 PM | #52 |
Does this trailing arm cross member require modification to the cab floor? Is it compatible with one pc drive shaft on swb?
Please educate this newbie |
08-22-2009, 05:58 PM | #53 | |
-With new cab mount bishings there is .25" between the bottom of the cab floor and top of the tube. With worn out and compressed cab mount bushings it might touch. -One piece drive-shaft will work up to a certain amount of drop. If you're going to be cutting into the bed floor by more than a couple inches, I would recommend the version with the carrier bearing mounting tab, and running a two-piece driveshaft.
08-22-2009, 07:19 PM | #54 |
#002 checking in . . .... ETA? You've got my number.
08-26-2009, 05:38 PM | #55 |
The LuvShack Garage
Still waiting for the Brown man to show up, I hope it's soon.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
08-26-2009, 06:30 PM | #56 |
We're both on the short list . . ....
08-26-2009, 08:46 PM | #57 |
The LuvShack Garage
08-26-2009, 09:04 PM | #58 |
Did you mean to say "Short Bus"?
Now be a good boy and put your helmet back on before we strap you in.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! Last edited by PBFAB.COM; 08-26-2009 at 09:05 PM. |
08-27-2009, 05:34 PM | #59 |
The LuvShack Garage
Hey Nate, don't you owe me some pictures?
08-27-2009, 05:37 PM | #60 |
Wow, these look great.
08-27-2009, 10:41 PM | #61 |
hey Nate,
Any more info/pics you would like to torture us with. Put me in the line up! |
08-28-2009, 05:58 PM | #62 |
The LuvShack Garage
Got mine today, and wow wee, dropped them off at the
powdercoaters and install pictures sometime next week. Nate, You Rock
08-28-2009, 06:22 PM | #63 |
big guy
Can't wait to see pic's
08-28-2009, 07:22 PM | #64 |
It'd be alot cooler if you did
I'm pretty sure they are TIG welded.
08-28-2009, 08:33 PM | #65 |
big guy
I guess i didn't use the right words.
08-28-2009, 08:54 PM | #66 |
Happy to be here
You just now getting yours? I had a set last week.
Oh, did I say that out loud....
08-29-2009, 06:40 AM | #67 |
The LuvShack Garage
The place that does my PC work cleans everything with
some kinda phosphate? (Spelling) as for the welds, Nate has them so clean that there is no lil balls as you call it. With shipping and PC they are about the same $ as CPP but why buy there's when you can have PORTERBUILT
08-29-2009, 09:57 AM | #68 |
big guy
these are what i am talking about. I am not trying to say anything bad about Nathans welding at all, as a matter fax i think hes better than a robot! This is normal stuff, i just didn't like them after PC was done> i thought i would save you from going threw it. Maybe i am just to picky. That is why i went with Porter built stuff in the first place, i am picky. Sorry if i had hurt anyones feelings, not my intent.
Ray |
08-29-2009, 10:01 AM | #69 |
You aren't hurting anybodies feelings... you have a valid point and the pics to back it up. No problem.
08-29-2009, 11:18 AM | #70 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-29-2009 at 11:19 AM. |
08-29-2009, 11:22 AM | #71 |
Yep. Nate lays down some excellent beads but there can be some stray slag that will hurt the overall quality of a nice PC job. When I did my Dropmember, a quick (& I mean real quick) once over w/a 3" 3M disc cleaned it up easily.
08-29-2009, 11:27 AM | #72 |
Hey Ray.... Stop talking about my balls!
Often times, it's inevitable to get some "welding berries" on the parts when MIG welding. As Ray mentioned, sandblasting alone doesn't always remove these. Those really picky guys (and I know there are a lot of us) may want to put forth a little more effort to remove these, as they will be more noticable with a color coat.
08-29-2009, 12:25 PM | #73 |
For the record..... I said slag. Are you done w/mine yet?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-29-2009 at 12:26 PM. |
08-29-2009, 12:48 PM | #74 |
Did you order a set?
They're done, I am just finishing up some other bracketry you will need.
08-29-2009, 01:05 PM | #75 |
Sweet. I've been looking for alternatives on the PHB bushings this week. Any you recommend off the top of your head?
