Old 09-03-2015, 01:23 PM   #51
Fitz
Re: pics of trucks witha 3/5 drop?
Originally Posted by picklito View Post
Cutting is fine if you know what you're doing... same rule as for everything else in life. In these threads I almost never hear anyone talking about checking for coil bind at full compression or about checking preload of the spring installed and at full extension, etc.
The restoring force of a spring is the spring constant 'K' multiplied by the distance the spring is compressed, 'X'. So Restoring Force = K*X. When you shorten a spring by cutting out coils the spring can 'bottom out' on your suspension stops in 'bump' giving a sudden change in suspension geometry. Hitting a pothole while turning a corner at speed with shortened springs can easily cause a rollover, making the driver of that vehicle a candidate for a Darwin award. A reputable manufacturer of a drop spring will increase the spring constant so that the same restoring force is obtained with a shorter compressive length before hitting the bump stops. A drop spring made by a fly by night is just as dangerous as a spring you have cut yourself.
Fitz is offline   Reply With Quote
Old 09-03-2015, 01:27 PM   #52
Fitz
Originally Posted by beerformeplz View Post
Can anyone with a 5 drop in the rear please tell me what shocks your using? Ive already installed the relocation bracket just need to figure the shocks out.
The cool thing about the relocation bracket is it allows you to use the stock length shock on a dropped truck. Early Classic Enterprises uses KYB GR2 gas filled but any replacement for the stock shock will work just fine.
Old 09-03-2015, 05:55 PM   #53
joewell80
Hi C10 King,
Are those 18" AR TT2 on your 71? if so, what tire size are you running and what is the drop?
thanks.
joewell80 is offline   Reply With Quote
Old 09-03-2015, 10:56 PM   #54
C/10 King
C/10 King's Avatar
Originally Posted by joewell80 View Post
Hi C10 King,
thanks.
Lol 3/5 drop, 17' AR TT2, tires I believe were 50' series but I don't remember the exact size, it's been a while.
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 09-03-2015, 11:24 PM   #55
tonkatrux2
4/6 drop
tonkatrux2 is offline   Reply With Quote
Old 03-01-2016, 11:54 AM   #56
Schlem69lwb
Schlem69lwb's Avatar
What headers are you guys running?? I doing 3.5/5 on my 69LWB and I have a motor ready to drop just need to find the perfect headers.
Schlem69lwb is offline   Reply With Quote
Old 03-01-2016, 05:16 PM   #57
70shtbx
Lowered w/Classic Enterprise Dropped springs , spindles and shocks in front and lowering springs in back, did it about 18 years ago.
70shtbx is offline   Reply With Quote
Old 03-01-2016, 08:09 PM   #58
DTMsurf
Originally Posted by ddiaz90503 View Post
Here's mine with a 3"/5" with CPP coils, shocks, and relocation brackets
Perfect! That's exactly what I hope mine turns out to look like
DTMsurf is offline   Reply With Quote
Old 03-02-2016, 01:10 PM   #59
gbaker783
This is my '69 with a 3/5" drop with a c-notch kit installed.
gbaker783 is offline   Reply With Quote
Old 04-25-2018, 10:27 PM   #60
Twisted11
Originally Posted by big_al_71 View Post
Here is an old pict of my truck with 3/5 drop cut springs and 5 inch in the rear...It rode like crap specially in the front the back was just fine.
Twisted11 is offline   Reply With Quote
Old 04-25-2018, 10:30 PM   #61
Twisted11
Originally Posted by Twisted11 View Post
Hey Big_Al_71, what size rims and tires you got on that truck of yours?
Old 04-26-2018, 03:25 AM   #62
72 Burb 3dr
72 Burb 3dr's Avatar
3.5" / 5" Early Classic Enterprises kit.
20" Riddler wheels with 245/35zr20
72 Burb 3dr is offline   Reply With Quote
Old 09-21-2018, 02:25 PM   #63
js0k
js0k's Avatar
1969 C10 Longbed With CPP 3/5 drop, just shocks and springs... have adjustable panhard bar and rear shock relocators but haven’t installed them, it rides fine
js0k is offline   Reply With Quote
Old 09-21-2018, 11:16 PM   #64
Southpaw69
Originally Posted by C/10 King View Post
Here's a few 3/5's
I like how this one sits. Looks good and usable. This is 3/5? Looks a bit higher in the back.
Southpaw69 is offline   Reply With Quote
