Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-20-2010, 06:45 PM   #51
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Re: BBC Build and Questions.
I found the article mentioned comparing a mini blower to an 871
http://www.chevyhiperformance.com/te...ine/index.html
It's a good read, and might provide some insight on parts selection and outcome.
Makes me want to get back on my project quickly..
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 01-20-2010, 07:57 PM   #52
70stroker
70stroker's Avatar
quick question guys, I line honed by block. Now i have never had to do this with any of my blocks. My question is how do i order the correct bearings? I mean a .030 oversize bearing adds material on the crank side to make up for a ground crank. What about if you take metal off the other side? thanks
70stroker is offline   Reply With Quote
Old 01-20-2010, 11:12 PM   #53
Captainfab
60-66 Nut
Line honing doesn't change the outer diameter of the bearings needed. A couple of things you will have to get different since the block is line honed is a specific rear main seal (not positive on BB, I know sb does) and a slightly shorter timing chain ( typically .005 or .010).
Old 01-21-2010, 12:13 AM   #54
70stroker
70stroker's Avatar
tonight i painted the motor and installed the main studs. not alot by still a little progress
Old 01-21-2010, 06:38 AM   #55
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Did you have the machine work done already? If so isnt it a bad idea to install main studs now?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 01-22-2010, 12:19 AM   #56
Captainfab
60-66 Nut
Hopefully those studs were installed for the linehoning process.......
Old 01-22-2010, 04:15 AM   #57
70stroker
70stroker's Avatar
well actually they were not installed before, I really wanted new bolts or studs vs the stock ones.
So if you guys see it a problem then i either send it back to the machine shop to have it honed again. I rather be safe then sorry.
Could i just but arp bolts and be ok? Or have to have it checked again?
Dont take this as a bad attitude guys. Actually thats why i posted here hoping someone would catch anything out of place. I appreciate the heads up before i go any further. You guys are great.
So what would you guys do? Like i said the bolts that was line honed with were stock as far as i know... I dont really trust them with a blower sittin on top... or would i be ok?
Just let me know what you guys think.
Thanks again.
Old 01-22-2010, 11:59 PM   #58
Captainfab
60-66 Nut
Typically anytime you change your main cap bolts to either new bolts or studs you should have the mains line honed. New fasteners will change the distortion they create on the main bores. So if you were not wanting to reuse the stock main bolts, the studs should have been installed prior to line honing. I'll let one of the experts recommend what to do now.
