Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-11-2010, 08:49 AM   #51
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Pro Street Trucks/Cars pics!!! im in love with the fatty tires!!
Originally Posted by djracer View Post
Are the cup arms as heavy as the truck arms?
I did a side by side feel test and the Cup arms felt a bit lighter..I dont think they are quite as wide...that being said they do have the hanger for an adjustable P bar on the DS and a place to mount a sway bar....I flipped my shock mounts and added a 1" block
I havn't gotten to the sway bar add yet but is going to be an easy add...you can see the hanger with 3 threaded mounting holes on the back of the bar...I may have to relocate my air tank but havn't really thought about doing it yet??
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-14-2010, 07:48 PM   #52
samwise68
FarmBoy.
samwise68's Avatar
Where did you order your cup arms from? They look awesome!
-Sam.
1969 GMC C1500. long fleet.
307. 3 on the tree. 3.07 gears.
Oliver green. Bent and bruised. Daily Driver.
Screw patina... it's a beater...Beaters are cool.
my build thread - Project Homebrew:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993
samwise68 is offline   Reply With Quote
Old 03-14-2010, 09:32 PM   #53
Hottrucks
Hottrucks's Avatar
if your asking me I built mine...2 3/4" of 8" pipe and some flat stock..took about 2 hours but I did borrow my buddies plasma cutter to cut out the old spring pocket
Old 03-15-2010, 05:51 PM   #54
samwise68
FarmBoy.
samwise68's Avatar
My apologies Hottruck - I was refering to your trailing arms. I thought they were refered to as "Cup arms" because of the Spring Cup racing. They look after market. I was just wondering where you ordered them from, because new ones would sure be nice some days.
Thanks!
-Sam.
Old 03-15-2010, 08:46 PM   #55
bigguy69
dazed and confused
bigguy69's Avatar
Thanks!
-Sam.
i thought the same thing? so are they cup trailing arms?
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 03-15-2010, 09:28 PM   #56
Hottrucks
Hottrucks's Avatar
yes they are..I'm looking for the link they where $100 shipped to my door..if you look back you can see that its a bolt in fit..comes with some free be's too look at the adjustable P bar mount and there are 3 bolt holes on the back to mount a sway bar
http://cgi.ebay.com/ebaymotors/ws/eB...CA:MOTORS:1123
Old 03-15-2010, 09:35 PM   #57
Hottrucks
Hottrucks's Avatar
also I added a 1" block but you have to notice that the bar is backwards from stock (you can see stock the frame hanger in the pic) I fabbed up a quick mount on the outside of the frame on the other side ..mt P bar is 42" long and works like a charm if you look you can see where he weld is glueing 2 bars together to make 1 new bar long enough...adjustable is easy to install but why spend $$ for something adjustable that you never adjust??...I flipped the stock shock mounts so shock travel is great...once my wheels are here I will locate the E brake cable hanger to clear the wheel...
I will say this was the best $$$ I have spent on a mod total cost...$100 and a few hours labor and fab work
I doing the motor transplant now I'm sure that will be $$ well spent but not nearly as easy
Old 03-29-2010, 12:48 PM   #58
383Chevy
[><]Sofa King Dirty 4x4[><]
383Chevy's Avatar
85' chevy stepside,33x18.5x15 M&H and she aint tubbed either
00' Chevy Silverado 1500 z71
33"s
3" lift
5-speed
Past trucks
85' Chevy C10 Step side
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
92' S10/Tahoe sbc swap
383Chevy is offline   Reply With Quote
Old 03-29-2010, 10:43 PM   #59
drag_72
Ready to go fast!!
drag_72's Avatar
dood really? i mean if thats what you like thats cool? but you need to tubbed it and lower it just my opinion
454 block .30 forged aluminum pistons
steel crank
valve job
Holley Strip Dominator intake
1030cfm holley carb, 250 plate shot
roller rockers Erson Solid cam split duration 307/310.
.575/.595 lift
milodon oil pan
fab. aluminum valve covers
4 bolt main splayed anodized caps
all studded
drag_72 is offline   Reply With Quote
Old 03-29-2010, 10:44 PM   #60
drag_72
Ready to go fast!!
drag_72's Avatar
short lil burnout... didnt wanna hit the car parked in the middle of the damn road.. bad quality also... it was taken off of a buddies phone
steel crank
valve job
.575/.595 lift
milodon oil pan
all studded
Old 03-30-2010, 07:35 AM   #61
Hottrucks
Hottrucks's Avatar
Shhh don't tell him but someone put his tubs on the outside of his bed
but that would look kool with a straight axle under it !!!!
Old 03-30-2010, 10:38 AM   #62
383Chevy
383Chevy's Avatar
Don't hate,it was a one day thing i took em off
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
Old 03-30-2010, 11:13 AM   #63
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: Pro Street Trucks/Cars pics!!! im in love with the fatty tires!!
If I had that year and body style truck she would look like this....
Well...... I if I had the money that is...
http://www.eurodragster.com/news/fea...up/default.asp
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 03-30-2010, 11:13 AM   #64
Hottrucks
Hottrucks's Avatar
trust me theres no hate I would put some 4" rims on it up front spray the rear quarters with Pam and take it to the track for a good ass woop'n
Highboy's where all the rage back in the day..its a very retro look thats why I said put a straight axle on it!!! and a big 671 out of the hood!!
Old 03-30-2010, 11:14 AM   #65
Hottrucks
Hottrucks's Avatar
dam you ! bad I din't hit enter fast enough!!l LMAO...I'd love to be blown!!
Old 03-30-2010, 02:27 PM   #66
Hottrucks
Hottrucks's Avatar
ok here how it goes when you have a budget ( I'm going to do a build on it but you guys are getting the sneak peak!!!) keep in mind I could have spent more time on cleaning but I want them on the truck this weekend ( its going to be near 80* for the first time....time to cruz)
I think its self explanitory.... cost to for widening was stupid cheap compaired to a new wheel..your going to have to follow my build and wait for prices,names and address's but I can say its not me...tires will go on tomorrow as soon as the paint has time to dry a bit after another couple coats..
to bad I can't post pics on this freak'n page WTF!!!!!!!
5 min later same pics no problem??
Old 03-31-2010, 11:36 AM   #67
Hottrucks
Hottrucks's Avatar
CAN I hang with you guys now...PLEASE!!!
Old 03-31-2010, 12:14 PM   #68
midevil1
ShortBus KingPin
midevil1's Avatar
If you lose the "Service Truck" rear bumper.....Yes you can. LOL. Lookin good.
67 shortstep prosteet. 505 BBC, FULL BILLET TH350, Owner built EVERYTHING.... (My RIDE)
2008 GMC Yukon DENALI, 425 AWHP, 5700LBS, 12.40's at 109mph. (Her RIDE)
2006 Kawasaki Brute Force, 916cc, 80 shot, 6.20's at 111 mph. (Her RIDE)
midevil1 is offline   Reply With Quote
Old 03-31-2010, 12:25 PM   #69
Hottrucks
Hottrucks's Avatar
I use it for weight transfer...(read as) to tranfer my fat Azz from the ground to the truck!!
LMAO....
Old 03-31-2010, 06:50 PM   #70
1Bad62Pro/Street
Thumbs up Re: Pro Street Trucks/Cars pics!!! im in love with the fatty tires!!
Sorry........
I had to!!!
Now this truck wins a One Bad Mamma Jamma award!
67 Chevy Truck "All Glass" Truckin Magazine
CLICK ON:
See more images of this vechicle.
http://www.usbodysource.com/__Photo-Gallery/T-Bod-Fe-Chevy/67-001-d.htm
http://www.usbodysource.com/__Photo-...y/67-002-b.htm
Old 03-31-2010, 07:30 PM   #71
CoggedBelt75
CoggedBelt75's Avatar
Looks good!! The bumper will be fine for now since the license plate tells the story. What's next on the to-do list?
Joe
__________________________________________
1975 C10
"Questions are a sign of intelligence indicating a desire to eliminate ignorance"
CoggedBelt75 is offline   Reply With Quote
Old 03-31-2010, 08:57 PM   #72
Hottrucks
Hottrucks's Avatar
check my build!!!!
Old 04-02-2010, 01:37 AM   #73
team39763
Where do you guys get the material for the bed floor? I'm wanting to do my bed, but our local places want $100 for a 24X40" piece of aluminum sheet(steel isn't much cheaper). I considered doing the bed floor with lexan since it's $58 for 26X72, but I don't think that would work too good.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 04-02-2010, 08:27 AM   #74
djracer
djracer's Avatar
I'm doing the fake wood and stainless strips in my sons truck.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-02-2010, 09:08 PM   #75
fiddy9apache
fiddy9apache's Avatar
i kinda did the same with a piece of 3/4in treated plywood and the layed fence wood over it and stained it. its hinged so i can get under it to get to my battery and adj coil overs when that time comes.
fiddy9apache is offline   Reply With Quote
