Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 04-18-2012, 12:41 AM   #51
jonesky2
jonesky2's Avatar
Re: Needed a new toy. Why a Blazer? Why NOT a Blazer?!?!
Originally Posted by fxdxharley View Post
looking good! i like your tipper, i was eying the setup topless built too and was planning on building one. i would like to get those dimensions from you. pm them to me please. thanks and keep up the good work.
how about keep it public? I would also like to build one in the near future
jonesky2 is offline   Reply With Quote
Old 04-18-2012, 09:13 AM   #52
fxdxharley
Just a nother gear head
fxdxharley's Avatar
yes keep it public. i just wanted them in my messages to make it easier to find is all.
2013 HD FLHX
2000 chevy 2500 6.0l 4x4 3dr
2000 harley fxdx
71 Jimmy 4x4- future crawler/ woods rig
71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589
fxdxharley is offline   Reply With Quote
Old 05-17-2012, 08:23 PM   #53
thor
thor's Avatar
looking good!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 06-09-2012, 01:45 AM   #54
2fast55
2fast55's Avatar
I guess I should get on those numbers for you guys since it's been almost 2 months. The front body mounts are 3' 5" apart center-to-center. The rear set I used, 2nd from the rear, are 3' 1-5/8" center-to-center. They are 8' front to rear, still measured on centers. I used all 2" square tube, and my wheels are 6" from floor to mounting surface. Overall height of the cart uprights is 24" front, and 29-1/2" rear. I welded nuts to some plate and bolted it to the bottom of the body before I set it on the cart, then welded the plates to the top of the uprights. Total width of the cart to arm mounting surfaces is 3' 11". The arms are 8" horizontal to the outside of the first angle. The 45 degree section is 17" outside angles. The height of the upright is less relevant, but mine happen to be 5'. I used 6" sleeves in the arms (3" in, 3" out) to slip inside and bolt to the cart. There is not much clearance to the bedsides when it is on the side, but most of that was lost in the loose sleeves because of the seam inside square tubing. Plating the outside instead would fit much better. 2 guys can flip the whole assembly with the body over by hand, it balances pretty good, but maintains good stability in either position. Sorry for the mix of feet and inches, and pure inches; I have to work with multiple groups who measure either way depending on their trade, so I am completely comfortable with both styles and tend to mix them on my own work. And besides, the length is still the same, no matter how it is written.
In other news, I am super close to finally getting a little color on both sides of the firewall and windshield frame. I should have already sprayed it, but had a problem with the sealer I was using, and am on a delay while it cures so I can sand it in a couple areas.
1972 Chevy K5 Blazer
1972 Chevy K20
1955 Chevy 3100
"If we knew what it was we were doing, it would not be called research, would it?"
- Albert Einstein
2fast55 is offline   Reply With Quote
Old 06-11-2012, 11:59 AM   #55
fxdxharley
fxdxharley's Avatar
Thanks for the numbers. Your timing is just about perfect. I have the steel for mine now and need to get going on the cart so i can get my tub off the saw horses. a mix of feet and inches is fine. i would have probably written it the same way, and added fractions or decimals too. sence im a machinist. lol!
2013 HD FLHX
2000 harley fxdx
Old 06-13-2012, 01:56 AM   #56
2fast55
2fast55's Avatar
Well, I wanted the brightest green I could buy, and I think I found it. This stuff almost requires sunglasses to look at it in the dark. I've been waiting almost a year to see it on something bigger than a sample chip. Now I've got some new motivation to get to work and get the rest of it done. I want to see it all put together and outside in the sunshine.
1972 Chevy K20
1955 Chevy 3100
- Albert Einstein
Old 06-13-2012, 10:49 AM   #57
fxdxharley
fxdxharley's Avatar
thats an awsome color. im kinda fond of the kawasaki green myself and thats pretty close. cant wait to see it all done and in the sunlight.
2013 HD FLHX
2000 harley fxdx
Old 06-13-2012, 06:15 PM   #58
NTR72GMC
2wd FTW!!!!
NTR72GMC's Avatar
Twins!! J/K nice build btw.
NTR72GMC is offline   Reply With Quote
Old 06-13-2012, 06:34 PM   #59
NTR72GMC
2wd FTW!!!!
NTR72GMC's Avatar
Old 06-14-2012, 09:14 PM   #60
2fast55
2fast55's Avatar
Mmm...Bedliner. I had a couple quarts left over from another project, and I didn't like it at all in that truck. It's too slick, so under the body was a perfect place to put it. It should be MUCH easier to keep clean than undercoating.
It turns out that a needle scaler really does wonders on crusty old undercoating. But it's useless on the soft stuff. I ended up scraping the rest by hand with a tool I built from a piece of old peeler blade from a plywood mill. One of those new oscillating tools with a scraper on it would probably be just the ticket.
1972 Chevy K20
1955 Chevy 3100
- Albert Einstein
Old 07-14-2012, 02:19 AM   #61
CTENTA1
Registered 1971 K5
looking good, keep pushing
CTENTA1 is offline   Reply With Quote
Old 07-14-2012, 01:58 PM   #62
Erik V
Did you use my autoX car's color? 1995 Dodge/Plymouth Neon specific, "Nitro Yellow Green" ?
I love that undercarriage shot-looks better than new!
Erik
Erik V is offline   Reply With Quote
