Old 09-07-2010, 06:05 PM   #51
baclay9
Re: baclay9's 83' SWB Build
Originally Posted by scotts62 View Post
I think i found all the parts to the serp setup too, ill try and lay it out to be sure..
Cool deal man. I appreciate it. By the way, the oil pan I got from you is way to shallow. I bet your buddy had a really short oil pump on his boat and had to have that pan custom made to clear the hull or something. Sooo, you are going to get a sandblasted and nicely painted pan back.
baclay9 is offline   Reply With Quote
Old 09-07-2010, 06:43 PM   #52
scotts62
One day...
scotts62's Avatar
Thanks!
Is it hitting the pickup tube?
There are different ones out there if you wana try and use it, if not a stock one will look just as good
Scott
93 crew cab build
Project 62
Old 09-07-2010, 07:12 PM   #53
baclay9
I just pulled the one off the donor engine ad stuck it on there. It just has one small dent in it. I figure if someone is looking that close at my oil pan they have no life.
Old 09-07-2010, 07:15 PM   #54
scotts62
One day...
scotts62's Avatar
or get kicked in the arse while their down there!
Scott
93 crew cab build
Project 62
Old 09-08-2010, 04:04 PM   #55
JohnC
JohnC's Avatar
JohnC is offline   Reply With Quote
Old 09-11-2010, 06:31 AM   #56
nbpro
sweet truck love da color on it.
nbpro is offline   Reply With Quote
Old 09-12-2010, 10:58 AM   #57
baclay9
Thanks man but the color is going bye, bye...
Scored this on CL yesterday for the BB conversion. Had to drive about 2 hours north of where I am working to pick it up but it is in great shape. Ready to bolt on. 750 Holley w/ vacuum secondaries. Electric Choke.
By claypool782 at 2010-09-12
I also picked up these "spinners"(I guess that is what they are called) for my rallies. The caps need to be cleaned up but I can't decide if I am going to like the way they look. What do you guys think?
Old 09-12-2010, 11:08 AM   #58
LiveAnimals
LiveAnimals's Avatar
I need that carb
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline   Reply With Quote
Old 09-12-2010, 11:25 AM   #59
joe231
joe231's Avatar
Nice score!
I'm torn on the 3 bar spinners, I dig them, but they kinda scream "circa 1980"
But if that's what your going for then your golden
CHEVY ONLY
Old 09-12-2010, 11:40 AM   #60
JohnC
JohnC's Avatar
I think the spinners are cool. The great thing about them is if you get tired of them you can just throw on some regular centers, and swap back from time to time. 3r!c84 has them on his truck. Here is a pic of it.
Old 09-12-2010, 12:26 PM   #61
baclay9
I am going to try and get my tires put on the rallies when I get home this time and we will see how it all looks when put together. I am just hoping I can get my caps to clean up as good as yours did Joe!
Old 09-21-2010, 09:08 PM   #62
baclay9
Well, I got a little done over the last couple of days. It is finally off the Jack stands and on the ground. I had to buy a new tire due to one of the ones I had was separated. I hated to do it seeing how this setup is temporary but the Coys just aren't in the budget right now due to all the motor work I have to do.
Here are a couple of pics. I got the newly painted rallies on with the trim rings on but still haven't cleaned up the caps yet. I had the wheels blasted and then painted them with several coats of Rustoleum Proffesional "Stainless Steel". I got all the steering system on and started running the fuel lines and got the wiring harness on. I am going to get the rest of the lines in (brake, fuel) and the tanks painted up and on later this week. I will get some better pics then.
After that it will be time to start on the 454 and tranny work.
By claypool782 at 2010-09-21
More to come....
Old 09-21-2010, 10:38 PM   #63
joe231
joe231's Avatar
nice work!
CHEVY ONLY
Old 09-23-2010, 12:50 PM   #64
JohnC
JohnC's Avatar
Looks good man! Keep at it!
Old 09-23-2010, 09:24 PM   #65
baclay9
Here is some more. I am pretty much done with this "phase" of my build. All the fuel lines are run and the brake lines are pretty much done. I have to replace the hard brake line that goes from the proportioning valve to the frame because I had to cut them to get them off.
I got the tanks put on and everything. As soon as I get the front hard brake ins replaced I am going to slap the motor mounts on. Here are a few more pics.
By claypool782 at 2010-09-23
Next time I come home it will be time to tear into this bad boy...
Old 09-23-2010, 09:34 PM   #66
joe231
joe231's Avatar
Right On!!
I forgot again
What paint did you use on the frame?
CHEVY ONLY
Old 09-23-2010, 09:43 PM   #67
baclay9
Originally Posted by joe231 View Post
Right On!!
I forgot again
It is PM Industries "Chassis Black"
http://www.nomorerust.com/
Good stuff. Lays down thick and doesn't leave brush marks. It is really hard. It doesn't have a UV protectant in it though so it will fade if you leave it out in the sun. It doesn't make it chip off or anything but it takes the gloss away.
Old 09-23-2010, 09:55 PM   #68
joe231
joe231's Avatar
Ah,
Yeah
Now I remember!
CHEVY ONLY
Old 09-29-2010, 02:35 PM   #69
baclay9
I just bought something preeettyyyy!!!!!
Old 09-29-2010, 02:42 PM   #70
joe231
joe231's Avatar
Spill it!!!!
CHEVY ONLY
Old 09-29-2010, 05:02 PM   #71
scotts62
One day...
scotts62's Avatar
what?????????
Scott
93 crew cab build
Project 62
Old 09-29-2010, 05:11 PM   #72
joe231
joe231's Avatar
come on man....
you killin' us ova here!!
CHEVY ONLY
Old 09-29-2010, 07:17 PM   #73
nbpro
Looks good
Old 09-29-2010, 08:37 PM   #74
baclay9
Sorry guys, I didn't mean to leave ya hangin like that. I got slammed at work right after typing that. LOL
I ordered a set of Boss 338's today. I got 2 18x9.5 and 2 18x8's. I supposedly got two of the last three 18x8's there are available according to Eagle. I am freaking pumped. I got called out in the middle of the night the other night so they threw a little extra cash my way. I knew exactly what to do with it
Old 09-29-2010, 08:40 PM   #75
joe231
joe231's Avatar
Right on man!!!
Did you get gray?
After you get them, I might need to come out and test fit those on the crew to see how I like the 18's
CHEVY ONLY
