Old 12-03-2010, 10:21 PM   #51
Big Irish
Big Irish's Avatar
Re: Need more leg room . please help
Robert I notice also that your peddles sit even and close to the floor . This must help with driving comfort as well ?? Thanks again for the efforts .
1955 Chevy 2 door Wagon
1967 Short Wide BAGGED Gone to someone else
1953 Shop truck Clipped and Snipped sold
1951 GMC Bagged and patina
Big Irish is offline   Reply With Quote
Old 12-05-2010, 08:09 AM   #52
55dude
55dude's Avatar
all of the advice given is really great but as much as i personally love these trucks a PANEL was my solution. gives you unlimited leg room.
55dude is offline   Reply With Quote
Old 12-05-2010, 10:10 PM   #53
mobileortho
mobileortho's Avatar
Every little bit helps!
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 03-04-2012, 09:14 AM   #54
FRED 53
You say get rid of tank--what fuel tank are you using-- in my state can not have FUEL fill in bed area-- do you go the 47-tank fill out the side ? ? please show some pictures-- Thanks
FRED 53 is offline   Reply With Quote
Old 03-04-2012, 01:33 PM   #55
Handfull 54
Handfull 54's Avatar
Big Irish,
Here is what i did. I got a Glide Engineering frame for the 47-54 truck. I had the upholsterer use less padding in the backrest portion of the seat. This seat drops right in to your present bracket. All you do is remove the current tracks and put this frame in. It has its own track and the bottom lifts out so you can put items under the seat like an amp or fuse box or whatever. There is plenty of room. I have my remote fill for my master cylinder and my fuse box under the seat. I am 6'4" also and this works great. I also took the gas tank out. Here is a picture of what it looks like finished.
Handfull 54 is offline   Reply With Quote
Old 03-05-2012, 09:29 AM   #56
solidaxel
solidaxel's Avatar
Another solution is what I did to my 53, I used the stock seat and frame, But I removed all the springs and wire from the seat back, then cut a piece of plywood to fit the verticle bracing of the seat back.
It was then covered with foam and frabic,............. and I left the tank in behind the seat, it has a lot more room and still has adjustment on the seat!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-12-2013, 02:19 AM   #57
MIKEs50Chevy
MIKEs50Chevy's Avatar
Originally Posted by Handfull 54 View Post
Big Irish,
I love the look of your seat, I'm looking at doing the model with the tapered backs and the fold down armrest. I'm also removing the gas tank, so do you just have space behind the seat or were you able to move the seat back? I have longer legs and am looking for the legroom which is one of the reasons I'm moving the gas tank (eliminating the smell is the other). I'd also live to see the bottom part if the seat and how it fits and looks with the original skirt, etc. Thanks!
MIKEs50Chevy is offline   Reply With Quote
Old 06-12-2013, 01:15 PM   #58
_Ogre
_Ogre's Avatar
removing the gas tank doesn't give more room in the cab, the seat goes to the back of the cab regardless.
as does your head
a thin seat back and raising the seat above stock is about all you can do, short of extending the cab.
i also cut 3.5 inches off the brake pedal to give less leg action to hit the pedal.
raising the seat and tilting the bottom gives you more leg support for long trips.
i used 07 ford fusion seats; chopped 6 inches and raised 1.5 inches above stock
if i lean back hard i will smack my head on the metal above the big back window
i have a hard foam headrest above the window that is upholstered to match my seats
shop air compressor timer
Old 06-15-2013, 01:14 AM   #59
Truck Guy99
Sweet swaps! I didn't know the 88-98 seats fit with just some drilling. I would add reinforcement plates though unless it's only for things like parades, farm work, or car shows. I may be getting an AD or TF truck soon and seat belts are first. I have also seen someone use leather seats from an old but clean land yacht of a Caddy. Black with big arm rests but I think there was no center console. Not sure though. I would personally get an 88-98 seat, recover it with new foam and in a fabric that matches the exterior paint. To the OP, what did you decide to go with?
My names Tye. No Chevy right now
Truck Guy99 is offline   Reply With Quote
