Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 03-13-2011, 03:14 AM   #51
blackout
blackout's Avatar
Re: 1987 chevy scottsdale 4x4 first project
http://67-72chevytrucks.com/vboard/s...d.php?t=434087 chevy scottsdale first project
blackout is offline   Reply With Quote
Old 03-13-2011, 07:19 PM   #52
Altec
Getcha Pull
Altec's Avatar
Are you going to be running a bumper? I only ask because you might want to add some more bracing if you aren't. The frame from the factory is known to flex more then the suspension bolted to it.
Also, might want to add a brace from the frame to the fill tube. Somewhere around the shock mount. So it doesn't vibrate and crack something. Just a thought.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 03-14-2011, 12:42 AM   #53
blackout
blackout's Avatar
yup running a bumper and those pictures are just the test fits im not done with it. the crossmember i had before is way weaker then the one i had. i will be running a bumper and a hitch that should keep the frame in place
as for the filler i might just have it running straight up to the wheel well and having a filler there because the way i have it routed at the point isnt the best.. but time will tell
Old 03-14-2011, 07:46 AM   #54
madcow75
madcow75's Avatar
Are you going to be using a body lift with that gas tank filler line? If not it will hit your box rails.
madcow75 is offline   Reply With Quote
Old 03-14-2011, 09:34 PM   #55
blackout
blackout's Avatar
ya maybe not sure i still havent been able to get an engine lift for i can set the bed back on the frame to see if that gas tank will hit and how i will route the gas filler. then i cut the box rails to accomadate the filler.
Old 03-20-2011, 05:04 PM   #56
blackout
blackout's Avatar
got the crossmembers drilled and mounted in the frame
skid plate for fuel tank is installed..well half of it going
to have to make a bracket for it the other side to hold it up.
more pictures when it stops raining
thats my friends ford highboy probably the only ford i would buy
sorry if you guys dont approve of fords but i gotta say it looks pretty awesome
Old 03-22-2011, 11:48 PM   #57
blackout
blackout's Avatar
Old 03-23-2011, 12:01 AM   #58
blackout
blackout's Avatar
Old 03-23-2011, 12:41 AM   #59
Altec
Getcha Pull
Altec's Avatar
Tank look good. does the back need to go up more?
pipe wrench will straighten that bumper right out!
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Old 03-23-2011, 01:25 AM   #60
MTCK
MTCK's Avatar
Looks real good! So you're going to run the filler neck up to the passenger side stock filler location? How big is that tank? Your truck is a LWB, right? It looks like it but in a couple of the pics I think my eyes are playing tricks on me. I want to do that swap and get rid of the saddle tanks the next time I have mine apart.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 03-23-2011, 03:10 AM   #61
Altec
Getcha Pull
Altec's Avatar
Marcus' post reminded me about this. Just saw this post, and thought it might be right up your alley if you wanted to ditch the mile long tube.
http://67-72chevytrucks.com/vboard/s...96#post4450196
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Old 03-23-2011, 09:58 PM   #62
blackout
blackout's Avatar
altec- Thanks! do u mean that thank tank needs to be up more..or a suspension lift lol? and thanks for the link ill look into that. the bent bumper just bugs me! ill probably just end up getting a push bumper for it or build one out angle iron and sheet metal.
MtCk-Thanks! i believe the tank is a 33 gallon suburban tank. and yes it is longbed.. the pictures i posted makes the truck look smaller than it appears haha...
I got me an oil,temp,and ammeter gauges the other day! bought them for 30 bucks from oreilys hopefully they last long, emphasize on hopefully. also got a fuel strainer for the electric pump...10 bucks! saw one online for 3 bucks!. I also got some starter shims and there the wrong ones so i have to make a trip back to the auto parts store
Old 03-23-2011, 10:02 PM   #63
Altec
Getcha Pull
Altec's Avatar
The tank. It seems like the back of it is sitting lower then the front.
Make sure to get that ammeter wired properly.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Old 03-23-2011, 10:55 PM   #64
blackout
blackout's Avatar
i can fix that i can just lower the front straps to even it out.
as for the gauges do u know of any good threads on installations ? if you dont mind me asking
Old 03-23-2011, 11:10 PM   #65
Altec
Getcha Pull
Altec's Avatar
Who makes the gauge you have? I can find a diagram for you depending on the kind of ammeter. There are two types. One that runs inline with your main + line from the battery, and the other type connects one side to the main + line on the battery, and the other end connects to the Alternator output.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Old 04-16-2011, 12:21 AM   #66
blackout
blackout's Avatar
Its been a while since i posted here but i will have some pictures up. altec sorry for the mix up i have a voltemeter instead of a ammeter..does that make a difference?
Old 04-16-2011, 12:25 AM   #67
blackout
blackout's Avatar
also equus is the brand of gauges...bought the set at o reillys for 40 bucks
Old 04-16-2011, 12:42 AM   #68
Altec
Getcha Pull
Altec's Avatar
Big difference! Makes it easier lol.
On the back of the volt gauge is two connectors. One should be marked "+" the other "-." Simply hook the "+" side to a spot on the fuse block that gets power while the key is on. The "-" is just a ground. Hook it where you like. I'd probably run it to the ground block that is up under the dash on the kick panel roughly right behind where the AC vent is located by the head light switch. At least, my '86 has one...
Can't wait for some new pics!
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Old 04-17-2011, 11:21 PM   #69
blackout
blackout's Avatar
Old 04-17-2011, 11:27 PM   #70
blackout
blackout's Avatar
haha tell me if the pictures are to big for i can resize them...i used photobucket this time way much better!
well installed my gauges...probably going to get a fuel pressure gauge but boy was that a pain in the rear to install. In the process of taking the old oil sender out i was trying to take the top part of and it was stuck so i used force and well it broke in half and broke into the hole...thank god for extractors and drills!
decided to refit my exhaust much better. Got a brand new battery with sidepost and top post. bought a brand new postive batt wire. also got my starter shimmed! almost ready to get this thing moving!
Old 04-17-2011, 11:28 PM   #71
blackout
blackout's Avatar
Old 04-18-2011, 12:07 AM   #72
Altec
Getcha Pull
Altec's Avatar
Looks good! Pictures are fine!
Hope you were careful getting the broken fitting out. That is the last place you want to send metal shavings done.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Old 04-18-2011, 12:14 AM   #73
blackout
blackout's Avatar
thanks!yup carefull as can be i was really upset when i broke it ...but so happy when i got it done
Old 05-03-2011, 08:54 PM   #74
blackout
blackout's Avatar
well i found a good deal on a suburban with a 5.7 v8 gm goodwrench motor and transmission with only 60,000 on the combo. Im thinking about getting the suburban and used the motor,transmission,transfercase and put in my 1990 suburban
Old 05-03-2011, 11:57 PM   #75
Altec
Getcha Pull
Altec's Avatar
If the price is right, why not?
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
