07-31-2013, 01:52 PM | #51 |
Formerly- 1972SuperCheyenne
Re: Overbuilding - Looking for advice on how not to
Absolutely love this truck. Planning to keep the 250? For some reason I really like the 250/292.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
07-31-2013, 03:54 PM | #52 |
You're doing exactly what I didn't.
I actually started the same way but then the wife said something that made me tear it apart. "If you're going to keep it, build it the way you want it and dot it all the first time." That said, its getting redone completely and I've driven it 100 total since I bought it. Posted via Mobile Device
Rob 1971 c10 - ground up in progress Tripp's Speed Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=589750 |
07-31-2013, 04:31 PM | #53 |
Your build is great! it is roughly the same path that I am just starting. hopefully you won't mind much if I use some of your ideas in my build! thanks for being so detailed in this thread it is a great help. Am definately watching this build and subscribed!
07-31-2013, 09:26 PM | #54 |
Very nice....I like where it is going
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
07-31-2013, 10:31 PM | #55 |
I'm in!
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
09-03-2013, 09:51 PM | #56 | |||
Yep - The 250 is running super strong and has yet to let me down so I have no plans of taking her out of action....actually have made some improvements (you'll see the updates) and have additional plans to make the 250 more enjoyable as well so I can keep it in service Quote:
Thanks Guys
'68 SWB Stepside - Inline Long Six 250 C.I. (LS250): http://67-72chevytrucks.com/vboard/s...ferrerid=83901 |
09-03-2013, 10:04 PM | #57 |
So..........
With the front and rear suspension sorted out, put back together and 5 lug swap completed on all four corners I was without wheels and the truck was floating on jack-stands. This is the way most builders suggest doing it and I have to agree - build your suspension and everything first before you order the wheels. Things change and it is much better to have the actual measurements of your truck(vehicle) and what you are working with in your specific situation before spending $$ on wheels So resist that urge to buy wheels first and save them for last, it will definitely increase your potential for success With all that said I went thru my own trials and tribulations with measuring for wheels and the conversation and results can be seen in this thread along with some great input from some knowledgeable guys on measuring for wheels Final wheel and tire specs are at the end: http://67-72chevytrucks.com/vboard/s...d.php?t=482381 also here is a thread with some more good information for starting #'s for wheel specs: http://67-72chevytrucks.com/vboard/s...&postcount=810
'68 SWB Stepside - Inline Long Six 250 C.I. (LS250): http://67-72chevytrucks.com/vboard/s...ferrerid=83901 Last edited by RdoubleU; 09-03-2013 at 10:09 PM. |
09-03-2013, 10:23 PM | #58 |
So once the measurements were all sorted out it was time to chose the wheels
My original plan was to use Coy's with the matte finish like member Raul has on his truck
09-03-2013, 10:32 PM | #59 |
But due to my needs from the measurements I needed to go with a custom backspace wheel
So with the look of my truck and personal taste I decided to go with American Racing Salt Flats I was only able to find one other C10 with them to give an idea of how they looked on our trucks : http://67-72chevytrucks.com/vboard/s...423629&page=11 But I have always liked them in the larger diameters on other vehicles And Ridetech's C10 has a close looking wheel with the Centerlines for an idea as well
09-03-2013, 10:41 PM | #60 |
To order the wheels I worked with a forum vendor Pro Performance : http://www.azproperformance.com/home.php
And I can't say enough how much additional help Travis was able to provide me : http://67-72chevytrucks.com/vboard/s...d.php?t=563762 He answered and confirmed a bunch of my measurement and thoughts, worked with me on tire sizing, gave me an idea of what my truck would look like with various wheel choices , all before I even ordered the wheels from him
09-03-2013, 10:46 PM | #61 |
SWEET! I cant wait to see them on the truck. I absolutely love those wheels and have been thinking about them for my truck too.
09-03-2013, 10:51 PM | #62 |
Bolted up and exciting day haha
09-03-2013, 10:55 PM | #63 |
Just went back and saw they were already on! haha, not sure how I missed that. Are you having to do anything to make the rear wheel ceter in the wheelwell more?
09-04-2013, 07:26 AM | #64 |
Nothing special other than I have an adjustable panhard bar so I could center it as best possbile (i'm about 1/4" off perfect center) and I measured my wheels to where I have around 1/2" on each side of the tire in the wheelwells without needing to roll the rear fender lips
09-04-2013, 08:41 AM | #65 |
Im sorry, I meant centering it front to back. It looks to be way forward in this pic, unless its just the angle/illusion?
09-04-2013, 04:29 PM | #66 | |
But i feel the truck was alittle off on that side body wise from the get go if you look at post #13 http://67-72chevytrucks.com/vboard/s...6&postcount=13 Suspension wise everything lined up, but adjustable trailing arms would be the only way to align that if you had an issue (other than using washers as spacers on the trailing arm mounts) http://www.porterbuiltfabrication.com/?p=317
09-04-2013, 05:15 PM | #67 |
Progress is looking great!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
09-04-2013, 06:53 PM | #68 |
sweet truck!
Garage Built |
04-28-2014, 02:29 PM | #69 |
A320 Pilot/USAF Retired
Great looking truck, you got any updates?
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
04-29-2014, 09:25 AM | #70 |
Thanks, I do indeed - just have dropped the ball on updating the thread so I need to get back on it.
And wanted to let you know your truck was one of the first build threads I book marked on the forum (I also have a 56 awaiting teardown) and you did a great job with yours
04-29-2014, 11:07 AM | #71 |
Awesome man, thanks!!
04-30-2014, 11:18 PM | #72 |
When can we expect the next update. I'm on the edge of my seat haha
1991 Camaro Z28 |
05-01-2014, 12:22 AM | #73 |
Still Learning
Very cool old stepper. Lots of nice upgrades too.
05-01-2014, 09:08 AM | #74 | |
I'll do my best for it to be soon.....but forum updates = less wrenching time haha
05-01-2014, 10:58 AM | #75 |
Good looking truck man, I like the dark metallic gray paint / powder contrast with the black frame. Looks really clean.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
