Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer > projects and builds
Old 04-06-2011, 07:51 PM   #51
brothers69c-10
Suburban Hick
brothers69c-10's Avatar
Re: 93 s10 v8 swap
WHAT IS THE BEST SURFACE ON WHICH TO PAINT POR-15?
POR-15 likes rusted surfaces best. Seasoned metal and sandblasted
metal are also good. POR-15 does not adhere well to smooth, shiny
surfaces, but will adhere well with the use of Marine Clean and Metal
Ready preps.
http://www.por15.com/Data%20Sheets/P...cationInfo.pdf
Mathew
1947 Chevy 3600
1951 GMC 100
1969 Chevy C-10 396/500hp TH400 lowered 4"
1968 Imapla Custom 396/325hp TH400 "Grandmas Car"
1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505
1978 Chevy K-10 454
1983 S10 4x4 "Bumblb" (Grandpa's truck)
1993 Chevy S10 V8 conversion
1990 Ford Probe Gt
1992 Dodge W-150 "Old Man's Truck"
1992 Pontiac Grand Prix SE
1992 Mercury Grand Marquis-Mercruiser
2000 Ford F150 (Currently my mother drives this)
1946 Farmall H with Stan Hoist loader
1965 John Deere 110
1961 Wheel Horse " Rat Tractor"
brothers69c-10 is offline   Reply With Quote
Old 04-07-2011, 04:18 PM   #52
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 93 s10 v8 swap
It will be fine. Anyone who thinks painting anything over rust is a sure cure repair deserves the end result they get. I've seen restored cars after the floors were por-d. The rust in the areas they didn't address was worse than areas they replaced with new metal because the por held in the original rust and it just got worse and worse.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-18-2011, 09:21 PM   #53
brothers69c-10
Suburban Hick
Re: 93 s10 v8 swap
New question for you guys. Have any of you had problems with the oil pan hitting on the crossmember? My mounts are in the raised position and i can't put the motor back any further and the oil pan is still ressting on the crossmember. Any ideas where to find a different pan?
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 05-18-2011, 10:07 PM   #54
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
Re: 93 s10 v8 swap
I didn't it was close, I'm sure sure what the pan i used was off of. whats yours off of? can't put a bit qt. pan sure mines a 5qt. also is the trans at the installed height?
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 05-18-2011, 10:13 PM   #55
Dieselwrencher
Re: 93 s10 v8 swap
Can you use a block of wood and a hammer or just a hammer to help get your clearance you need? How about making some shims to put under the engine mounts and frame?
Ryan
Old 05-19-2011, 09:25 PM   #56
brothers69c-10
Suburban Hick
Re: 93 s10 v8 swap
I'm not sure what the pan was off of and the trans is at the right height. I did some looking at a couple of other pans i had in the garage and the deep part of the pan on them is 2 inches shorter than the one on the motor now. I'm gonna pull the motor this weekend and test fit this other pan i found and see what happens. If I'm still having issues I'm gonna try the block of wood and hammer solution.
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 05-19-2011, 09:27 PM   #57
brothers69c-10
Suburban Hick
Re: 93 s10 v8 swap
Also ryan I could make shims for the motor mounts but the engine is already at too much of an angle and if i raise it anymore it creates clearance issues in the trans tunnel and the with the headers. If i can lower the motor to the upper holes in the engine mounts it will solve all my other clearance problems aside from the oil pan and i'll be able to put a 4 inch air cleaner on it.
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 05-20-2011, 02:18 AM   #58
Dieselwrencher
Re: 93 s10 v8 swap
Well what are you waiting for?
Ryan
Old 05-20-2011, 07:33 AM   #59
chevy2racr
chevy2racr's Avatar
Re: 93 s10 v8 swap
yea I'm running mine in the upper location and on the later s10s I had to cut the bracing out of my hood and a dished lower air cleaner pan to clear a 4" but HEI to firewall is WAY TIGHT
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 05-27-2011, 12:26 PM   #60
brothers69c-10
Suburban Hick
Re: 93 s10 v8 swap
Ok have the oil pan situation under control and now am needing help with the wiring. Due to the the fact that the truck is a 93 and had a tbi motor with a 100 different sensors how do i get everything to work in the dash and be able to elimnate all the extra wires and the ecu? Any body know where to find a complete wiring diagram?
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 05-28-2011, 12:41 AM   #61
chevy2racr
chevy2racr's Avatar
Re: 93 s10 v8 swap
alldata diy for $25 will give you the pin outs on the ECM hook ups so you can use wires and such. I have abuddy with a garage that had alldata and I printed mine out.... but scraped the stock dash anyway...
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 07-11-2011, 09:27 PM   #62
brothers69c-10
Suburban Hick
Re: 93 s10 v8 swap
Its been a while, but finally making progress. The motor and everything is back in the truck. I pulled all the extra wires out my wiring harness and put what was left back in and so far everything works as it should. Will find out more next week when i start it.
A tidbit for future refernece, I found on autozone you can get complete wiring schematics and alot of other helpful information in their how to section. Just register with them for free and you get all kinds of reference material.
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 07-21-2011, 01:38 PM   #63
brothers69c-10
Suburban Hick
Re: 93 s10 v8 swap
New question:
Anybody else ever used the corvette radiator they offer in the kits from v8 s10? I'm wondering whether or not you can use the stock radiator mounts and hold downs?
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 07-21-2011, 10:26 PM   #64
chevy2racr
chevy2racr's Avatar
Re: 93 s10 v8 swap
I'm using the corvette radiator, no on the stock hold downs and such. look around you'll find pics of how they made their mounts, pretty simple really, with the new body ones its a bit more of a pain...
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 10-13-2011, 10:49 AM   #65
brothers69c-10
Suburban Hick
Re: 93 s10 v8 swap
Its been a while since i worked on the truck. My brother ran into some financial issues so it kinda got put on the back burner. A couple weeks ago i mad a bracket for the fuel pump and started running fuel lines. I have the radiator support bolted on and have one fender halfway bolted on. There is a possibility the frame may be bent after all. I never found any stress marks and it cross measured fine, but there is some problems with getting the front clip to line up straight. Anyway here are some pics of how the truck looks like at the moment.
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 10-13-2011, 02:06 PM   #66
Dieselwrencher
Re: 93 s10 v8 swap
Looking good Mathew! Any plans to fire it up before snow hits the ground?
Ryan
Old 10-14-2011, 09:42 AM   #67
krazy_texan
krazy_texan's Avatar
Re: 93 s10 v8 swap
not sure if i have chimed in on this but if you need any help i might be available though it looks like it might be a little late in the game i have built 2 v8 s10s and 2 v8 ford rangers and i have the book for the s10 swap just give me a shout. looks like you have a pretty good start though
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 10-15-2011, 10:39 PM   #68
brothers69c-10
Suburban Hick
Re: 93 s10 v8 swap
Yes ryan i'm hoping once i get the 78 squared away i can get back to working on this. It would be nice to hear this thing run and maybe move around under its own power.
Krazy texan- I appreciate the offer and will keep you in mind. It seems like everytime things start going good i run into some other problem lol.
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
