Old 02-05-2011, 01:04 AM   #51
CORSAIR
CORSAIR's Avatar
Re: 67 gmc 4x4
Thanks for checking, Nothing better than stock wheels and Caps classic look.
Good luck with the build I will keep a eye on it for sure.
CORSAIR
"The Can't Family Lives Across The Street"
CORSAIR is offline   Reply With Quote
Old 02-05-2011, 01:24 AM   #52
Mt Man Chad
Mt Man Chad's Avatar
Re: 67 gmc 4x4
AMAzing!!!!!!!!
Can you post some pics of the drive line please!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 02-05-2011, 01:30 AM   #53
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: 67 gmc 4x4
I was thinking about the 6 leafs on my truck a little more so I went out and counted 6 on my 3/4 ton with heavy rear suspension. Due to that, I was less sure they were original. I emailed the previous owner today and he said that heavier springs were installed so that makes sense. I wonder what the lwb originally had, 4?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 02-05-2011, 01:48 AM   #54
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: 67 gmc 4x4
I love this truck. Going to be a great build.
DirtyLarry is offline   Reply With Quote
Old 02-05-2011, 10:56 AM   #55
Vintage Windmills
Vintage 4x4s
Re: 67 gmc 4x4
Originally Posted by 75gmc454 View Post
Here is a pic of that mount that has been welded:
Clint, Here is what the mount looks like on my truck. It may have been modified when the power steering pump was added. I am pretty sure the ram assist power steering was not factory but added back in the day since the bracket to mount the pump is welded construction. Are there any other V6 4x4 GMC owners on the board? It'd be nice to see more of these engine mounts. What is up with the "cage" around your upper radio hose (the part right in front of drivers valve cover)?
Old 02-05-2011, 11:02 AM   #56
Vintage Windmills
Vintage 4x4s
Re: 67 gmc 4x4
Here is another shot of the engine mount/ps mount on my truck:
Old 02-05-2011, 03:40 PM   #57
67chevy1series
67chevy1series's Avatar
Re: 67 gmc 4x4
wait both of your guys trucks are welded!?!?!?
67chevy1series is offline   Reply With Quote
Old 02-05-2011, 04:30 PM   #58
75gmc454
75gmc454's Avatar
Re: 67 gmc 4x4
Thanks for the pics Jud. I don't know if the lwb would have had different springs.
Now for the mounts. The mounts are different. That is why my motor is higher on one side. Mine has had the tabs broke off on it. You can see where it was welded in the pix. The only reason I can think it would have a taller mount is to clear the ac compressor pulley on the crank. That pulley is very close to the front crossmember. But that is just a guess. I will take more pics.
I dont know about the other bracket either. If you notice Jud my exhaust manifolds have holes that are plugged for a smog pump. That bracket may have been for that? But I am just guessing again.
Maybe someone can show us a complete power steering bracket for a v6.
Rick my drivers side motor mount had been welded, and Jud thinks his power steering bracket has been welded.
75gmc454 is offline   Reply With Quote
Old 02-05-2011, 04:33 PM   #59
vectorit
What?
vectorit's Avatar
Re: 67 gmc 4x4
My first impression of that "cage" like bracket is for the AC compressor, since I see in the cab AC vents. There were probably other brackets involved, but looks as though they may have been removed.
Probably a aftermarket style compressor, like a giant York compressor that was popular back in the day.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-05-2011, 04:35 PM   #60
75gmc454
75gmc454's Avatar
Re: 67 gmc 4x4
You can imagine how close that pass side valve cover is to the firewall. It has actually been hitting it.
Old 02-05-2011, 04:39 PM   #61
75gmc454
75gmc454's Avatar
Re: 67 gmc 4x4
It takes the same frigidare type compressor. It mounts under the alternator. It still has those brackets on the engine.
Old 02-05-2011, 05:02 PM   #62
67chevy1series
Re: 67 gmc 4x4
okay gotcha!
Old 02-05-2011, 06:19 PM   #63
nbrfd007
nbrfd007's Avatar
Re: 67 gmc 4x4
Man, that is one great truck!!
nbrfd007 is offline   Reply With Quote
Old 02-05-2011, 07:07 PM   #64
75gmc454
75gmc454's Avatar
Re: 67 gmc 4x4
Thank you. I think I sent you a message before about the compressor brackets. This truck has all of them except the two pieces that bolt onto the compressor itself. I would love to have a pic of those pieces. I am hoping to match them to something I can find locally.
Old 02-05-2011, 08:12 PM   #65
67chevy1series
Re: 67 gmc 4x4
this got moved which sucks i always love to lok at this forum but always get side tracted so now i will miss out some times
Old 02-05-2011, 08:25 PM   #66
mikey531
mikey531's Avatar
Re: 67 gmc 4x4
I still haven't figured out what gets moved where and why ???? Obviously if no one responds then it is the wrong forum. I would think that a "message" that is posted and gets 100's of views is in the right place ! Wait maybe this should be in the message board?
mikey531 is offline   Reply With Quote
Old 02-05-2011, 10:50 PM   #67
75gmc454
75gmc454's Avatar
Re: 67 gmc 4x4
Yeah, I guess they want to keep all 4x4 discussion in the 4x4 section.
Old 02-05-2011, 11:53 PM   #68
Classic Bowties
Always on the hunt...
Re: 67 gmc 4x4
Amen Brothers, I just dont see how one person with the mojo can decide when & where a thread needs to be put to bed. Take this one for example, a thread discussing a very rare short bed model which was getting plenty of views and comments is now moved and put to rest in the 4wd tech area. I just dont understand it... Mel
Classic Bowties is offline   Reply With Quote
Old 02-06-2011, 12:24 AM   #69
75gmc454
75gmc454's Avatar
Re: 67 gmc 4x4
Well, no need to worry about the change in location. We can keep up the discussion right here. I will have more pics to post in a few days.
--Clint
Old 02-06-2011, 03:29 AM   #70
Permafrost
Permafrost's Avatar
Re: 67 gmc 4x4
That's a pretty cool truck. What an awesome survivor!
Don't change a thing on that restoraton!
Post Pics, I'm hooked.... !
Too Many Projects:
'50 GMC
'62 Nova drop-top
'68 K10
'68 Chevelle SS
Permafrost is offline   Reply With Quote
Old 02-06-2011, 02:35 PM   #71
nbrfd007
nbrfd007's Avatar
Re: 67 gmc 4x4
I will take a picture of what I have. I watched that truck on Ebay with lust.
Old 02-06-2011, 06:30 PM   #72
nbrfd007
nbrfd007's Avatar
Re: 67 gmc 4x4
This is what I have. Hope it helps.
Old 02-06-2011, 10:35 PM   #73
75gmc454
75gmc454's Avatar
Re: 67 gmc 4x4
Thank you Tim for the time to take and post those pics. The two brackets in the bottom picture that bolt to the compressor are the ones that I am missing. I will save that picture and keep searching for some.
I have another question Tim. I am wondering about the engine mounts on this truck. Would only A/C trucks have that taller mount on the drivers side like the one that is shown in the top pic of post #55. The only problem with this is that the passenger side valve cover is very close to the firewall. But the A/C pulley is also very close to the front crossmember. Do you have any ideas?
--Clint
Old 02-07-2011, 12:53 AM   #74
Bob B.
Re: 67 gmc 4x4
My truck has the same A/C and power steering brackets as Tim's. The motor mounts look the same as well. I wonder if the bracket that the upper radiator goes through on your truck is a '64-'66 power steering pump bracket. The earlier V-6 trucks had the power steering pump up on top of the front of the engine. Maybe your truck wasn't built with power steering, and someone added it using pre '67 parts. I have no idea why your motor mounts have been raised. I looked up the motor mounts and brackets in a parts book, and they should be the same as my 4X2. Only V-6's with automatic tarnsmissions had different mounts.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 02-07-2011, 01:22 AM   #75
75gmc454
75gmc454's Avatar
Re: 67 gmc 4x4
Bob that could be an earlier ps bracket. My truck does not have power steering, it just has that bracket. I will take that off then.
Thanks for the info on the mounts. The only one that is raised is the drivers side. I will take that tall mount out also and see what happens. It just looks like that crank A/C bracket is going to be very close to the front crossmember.
