12-04-2011, 07:14 PM | #51 |
Re: '72 K5 Blazer CST = Yet another Build
Finally a little bit of an update, been hard at work and no time to work on the Blazer. Well Finally I've had some time, this past week, and was able to get some things worked on.
I made my decision on the wheels a while back, went with the 15x6 wheels, should look good. Out of the 5 wheels set I bought only 3 were good, they are cleaned and coated and waiting on 2 buddies to join them. I cleaned up the front end of the frame, plugged some holes that were drilled into it for some reason. Got it back to the stock set-up for tow hooks. The holes cleaned up. Then welded. Sanded, primed, and re-shaped the tow hook hole. Frame is now off to be blasted then coated. I cleaned up all the front and rear axle parts so I could put them together. Got some bad news on the rear posi, one plate was cracked on both sides. |
12-04-2011, 07:23 PM | #52 |
So now I have to wait for some more parts to come in. Don't know if I had mentioned this before, but ratio's were off on the gears the front had 3.07 and the rear had 3.73. I figured I'll stay with the 3.73 and just need to replace the front ring and pinion, now I'll be replacing the rear as well. Not a problem, just wait for parts to come in then put them back together. I just need to have them done by the time my frame gets back. The housings are waiting patiently.
I also cleaned up my axles. I got a few other small things cleaned up. Hopefully I will have some steady update for a while. Til next time. |
12-04-2011, 07:53 PM | #53 |
Really nice work on those axles. I'm about to restore mine, and am curious…what method(s) did you use to clean then up? And what products did you use to paint them? Did you have the axles powder coated?
12-04-2011, 08:36 PM | #54 | |
12-06-2011, 08:36 PM | #55 |
Frame is blasted, going to smooth out some imperfection then will be coated. It turned out nice, all the stamped codes on it were very clear. Not to much pitting on it at all, really just at the spring mounts.
12-27-2011, 07:13 PM | #56 |
Little update to the Blazer. The frame is done and in the garage, now slowly putting it back together. Still looking for wheels, Have not had much luck with that, but still looking. May have to go a different route, again, like some 16x6.5 6 lug steels and see if I have better luck.
Only one picture today of the frame sitting on the floor with all the stuff being worked on around it. Also a few for Randy, the work I did on the diff cover you sent me. |
12-27-2011, 07:22 PM | #57 |
One more thing to add, I've been working on the original hubs. I have two sets, they are not working the way I would like them to so going a different route on those as well.
Picked up a set of these, going to pull them apart and paint the inner knobs the same blue that matched the original plastic knobs. So at a distance they will look stock but have the strength of a modern manual hub. |
12-27-2011, 07:25 PM | #58 |
youre attention to detail is amazing, thanks for posting up the pics
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
12-27-2011, 07:51 PM | #59 |
12-27-2011, 08:34 PM | #60 | |
AND you're a mountain biker (I see that yellow Specialized in the corner)?? Working on my Blazer and riding my mountain bike are two of my favorite things in this world.
12-27-2011, 08:43 PM | #61 |
Did you remove the rubber pieces where the leaf springs mount into the frame in when you powder coated? Or if you removed them, how did you get them out?
12-27-2011, 09:38 PM | #62 |
Yes I removed them prior to blasting and coating. I dug them out in pieces until the remainder popped out, they are 2 pieces per side so you have to do the outside and inside of the frame for a total of 4 pieces. I think they are about 1.5" each bushing. Yes it was time consuming, some people just burn them out but I didn't want to make that much of a mess. Besides it was old rubber so not that bad. Yup, thats my bike but not much down hill riding here so it will go back in use when I move back to WA State.
12-27-2011, 10:37 PM | #63 | |
Did you get replacement bushings to put in after the powder? Where did you find them?
12-27-2011, 11:35 PM | #64 |
VA72C10
Looking good!!!
Looking for a 67-72 swb or blazer project in or around VA. |
12-27-2011, 11:47 PM | #65 | |
I sure did, I got them direct from energy suspension their black poly bushings. Hopefully you will see that in my next update.
12-29-2011, 09:56 PM | #66 |
Equal opportunity joke ofender
I may have a couple rims here. what size hub hole are yours? I will check them out tomorrow and let you know.
Richard
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
12-29-2011, 10:51 PM | #67 |
12-29-2011, 11:08 PM | #68 |
Just checked out Energy Suspension's website and there seem to be a lot of options…what size bushings did you get?
12-29-2011, 11:31 PM | #69 |
12-30-2011, 12:08 AM | #70 |
To be honest, I'm new to this and not sure what I need. My Blazer is a '71 and I need to replace all the leaf spring bushings front and rear. That's all I know.
Thanks. |
12-30-2011, 01:00 AM | #71 |
Ok, this is what I got for mine (all in black bushings, they are better than the red in my opinion) for the front part #3.2105 it will have everything you need for the front springs. For the back part #3.2106, it will have everything you need for the rear springs. Those will work for you as 71 and 72 Blazers are pretty much the same. Hope that helps you.
To replace the bolts, I just got zinc coated grade 8 bolts locally. |
12-30-2011, 12:58 PM | #72 |
Monte,
I have a total of 4 rims here with the 3.5" hub but only one that I would feel comfortable saying is worth reusing.the rust on the back side of the rim appears to be just surface, no pits or flakes. The others have some pitting issues and one of them was a bit wider. I have attached some pics of it including the measurements. rim measures 6.5" outside to outside on the flange and backspacing apears to be 4 or 4.25" depending where you actually look. i dont know if there were two different sizes that close so I will leave it at that. I have no use for the rim so its yours if you pay for the ride. I would need your zip for a quote. Let me know if you want it. Richard
12-30-2011, 01:02 PM | #73 | |
Thanks I appreciate it. I got the bushings out of the frame and some of the leaf spring ones out no problem. But there are several that are a different design. They have a steel sleeve around them, and the inner sleeve has small teeth on the ends. I can't get them out. Any tips?
12-30-2011, 01:10 PM | #74 | |
Richard,
Thank you for taking the time to check the wheels out. That is usually the problem, finding wheels that are still worth using at a reasonable price. Thanks for the offer but your only good wheel is not the same as what I have, My wheel mounting surface is the smooth type. It's funny, I have found more of the "rare" 15x8 wheels around here than anything. Quote:
12-30-2011, 01:12 PM | #75 |
No problem.
