03-06-2012, 06:02 PM | #51 |
6>8 Plugless........
Re: Cummins 12 Valve swap
Here's a 12v in my Longhorn.
Here's a 24v in a 76 K30. Here's a 12v in a 84 K20.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
03-07-2012, 12:15 AM | #52 |
Thoes are some nice looking trucks Ryan. Any more from anyone else?
03-07-2012, 08:52 PM | #53 |
I'm glad this thread got revitalized, it has sparked me up and I have set a lofty goal: This summer I plan on getting the engine/transmission in and running, and hopefully going down the road.
All this while moving, it might be a rough summer. I will make sure to take some pics when I get more involved. For now this is all I have. |
03-07-2012, 09:37 PM | #54 |
I've had the same goal for 2 years now. Hope yours goes better then mine. Hope it goes well for you and make sure you keep us up to date. Woody
03-08-2012, 09:22 AM | #55 |
For those of you performing this swap, what have you done with the steering? Did you just install the motor high enough to clear the stock stuff, install a rack for more clearance or what? Ive got my motor in I modified the crossmember to set the motor down and back as far as possible, now its right in the way. If you are using a rack (which I would really like to do), what one are you using? Thanks.
68 lwb to swb Cummins swap in the works. I promise it will be cool someday. |
03-08-2012, 10:55 AM | #56 |
Gotta love it! Mine is still in the planning stage ,but getting closer to the starting gun!
mark |
03-08-2012, 10:56 AM | #57 | |
Mark |
03-08-2012, 11:15 AM | #58 | |
03-08-2012, 04:22 PM | #59 | |
03-08-2012, 10:21 PM | #60 |
Thanks Mark. I left the front all stock, rebuilt the motor mounts. The steering is all stock as well. Like Ryan said, I was also worried about geting the oil pan lower than the front cross member, too many bumps and things, this way it might hit the cross member not hte oil pan.
03-09-2012, 12:24 PM | #61 |
Im in the middle of a move right now, the pics will have to wait.
Im not worried about the oil pan being low, Ill shorten the sump or build a new one. Im trying to get that 1000+ lb chunk of iron as far down and back as possible.
03-09-2012, 09:14 PM | #62 |
it can't help but be cool.
03-14-2012, 06:44 PM | #63 |
this really isnt that hard of a swap i didnt have to touch a front crossmember just clipped the right rail for a/c compressor. of corse had to make a new trans mount and crossmember, the only cutting i did was to take off the pinch weld in the trans tunnel. it worked real nice that the motor is low enough that i didnt need a body lift and the oil pan sump is flush with the bottom of the crossmember. good luck with this build
03-14-2012, 08:44 PM | #64 |
From a performance and handling stand point it's best to get the motor down and back as far as possible no matter what motor is being used. The Cummins motor is most likely the heaviest motor ever put into this 45 year old truck that never handled well to begin with. That is my motivation for where I'm trying to place the motor. I realize it can be accomplished differently.
03-15-2012, 01:06 PM | #65 |
i didnt mean any offence i was putting in my 2 cents about how easy it can be . im impressed with anybody that can make these trucks handle good or great
03-15-2012, 07:36 PM | #66 | |
03-15-2012, 08:36 PM | #67 | |
03-15-2012, 10:57 PM | #68 |
Nothing. It's all heavy duty for a BBC. I haven't even installed the power steering cylinder. It's a little tough at first crank but then it isn't so bad.
03-16-2012, 10:03 AM | #69 |
Power steering by Armstrong.
03-16-2012, 10:21 AM | #70 | |
11-09-2012, 10:06 PM | #71 |
Did ya get it done? Keep us updated!(:
Posted via Mobile Device |
11-21-2012, 11:35 AM | #72 |
Delayed slightly due to buying a 100 year old house, re-habbing it, then moving. But, I still have made some progress. The front clip is off the C10, engine and tranny out, and test fitting has begun.
I will post some pictures when it looks like I have done something other than take things apart. |
03-05-2013, 01:32 PM | #73 |
Any update on this? I'm interested in doing the same swap
thanks Matt |
03-07-2013, 06:51 PM | #74 |
Yeah, slowly chipping away at it. Currently clearancing the firewall to fit the engine as far back as possible. Once done with that then tranmission tunnel so I can get the trans bolted up. Then mounts and crossmember.
I bought a house last year as a resto project and it sucked all my time up. However, I am damn near done with it and ready to get this thing farther. |
03-25-2013, 11:31 AM | #75 |
