Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-13-2012, 09:52 PM   #51
Scottshotrods
Re: Dyno'ed 768hp 1305ftlbs & ran a 10.99@122
One more thing for you we have a customer in Texas who has a 67 stepside with a little over 1500 hp running one of our bolt in ifs kits.He runs VERY LOW 8s almost in the
high 7s.
Justin
Scottshotrods is offline   Reply With Quote
Old 09-13-2012, 10:14 PM   #52
NewType72
NewType72's Avatar
pics and vids? or a link possibly?
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 09-18-2012, 06:37 AM   #53
bcdeutsch731
bcdeutsch731's Avatar
Originally Posted by Scottshotrods View Post
Very cool Brett
Justin
Thanks for all the help Justin, and for the great suspension kit. Everything on your kit went together smooth.
1969 C10, 2005 LLY Duramax, Wagler Competition built motor, Bullseye Power triple Turbo's, Rossler th400, Neal Chance Racing Converter, Danville Performance tunning.
8.3@168mph 1700+ HP
bcdeutsch731 is offline   Reply With Quote
Old 09-18-2012, 06:40 AM   #54
bcdeutsch731
Here are some pictures I took last week of the new rear suspension I made. Looking to get back to the track this week. I installed a Mark Williams 11" rear end with a 2.91 gear.
8.3@168mph 1700+ HP
Old 09-18-2012, 10:29 AM   #55
vin63
It's Better With Nitro
vin63's Avatar
Nice job, Brett!
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 09-18-2012, 11:22 AM   #56
kpeztruck
kpeztruck's Avatar
Nice work Brett, that truck should work well, and be bullet proof! I still run stock trailing arms, that I converted to coil-overs, with an anti-roll bar. The adjustable instant center with the 4-link should give you more options to help it work better with the BIG diesel in the front. Can't wait to see new video of some passes. Good luck, and be careful. Paul
kpeztruck is offline   Reply With Quote
Old 09-18-2012, 04:23 PM   #57
Super73
Super73's Avatar
Very nice!
One question I have for you. Is there any reason you mounted the single heim for the wishbone vertical instead of horizontal? When doing mine, the chassis guy knew I do my fair share of street driving and mounted it horizontal. The rod end has more strength that way for a side load. IE the ball can't pull out of the end unless the whole end breaks. He Talked to the mfg about the load rating both directions. If memory serves me it was like 3-1 ratio. The front has two so it shares the load the single on is seeing. Just sharing .vbut it really does look great.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-18-2012, 07:00 PM   #58
bcdeutsch731
Originally Posted by Super73 View Post
Very nice!
Super73, no reason at all. I just saw pictures of it like this and that is how I did it. My rear heim is a 5/8 chromoly joint, I think my tabs will bend before that heim lets loose.
8.3@168mph 1700+ HP
Old 09-18-2012, 07:08 PM   #59
bcdeutsch731
Thanks on the compliments guys.
My chassis guy was a no show tonight, so now I'm trying to find the best place to start with the 4-link bars.
Any of you know anything about 4-link suspension?
L/F=1500 R/F=1420
L/R=1000 R/R=920
Wheel base 114"
Tires M/T slick 31x13.0-15
Truck balance on jackstands with angle iron on them so it came to a point ^ 71" in front of rear axle center line.
Axle center line to ground is 14.312"
Front bracket lower hole is 4.687" off ground
Distance from axle center line to lower hole on front bracket is 23.25"
If someone can help what else do you need to know?
Brett
8.3@168mph 1700+ HP
Old 09-18-2012, 09:00 PM   #60
Marv D
Registered Truck Offender
Marv D's Avatar
For what it's worth. I run pfhat tires on all my junk but I've always started with:
Botton bars level with the track, and set the wheelbase with bottom bars
Drivers side top bar parallel, set pinion angle with this bar,
Start with everything neutral, add preload with passengers side top bar if it drives right at launch.
We have very different animals but this has worked well me with for small block 9 and 10 second cars and trucks. Last weekend the truck went a 1.43 sixty and the Nova typically goes in the high 1.2's But again,,, I'm running some pretty pfhat stickeys ande a very different power curve
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 09-18-2012, 10:30 PM   #61
NewType72
NewType72's Avatar
Can't help much in the fab area but as for confidence holy cow that rear end just looks gourgeous great work and such a nice looking setup
- Dylan
(209)-985-7721
Old 09-18-2012, 11:41 PM   #62
Captainfab
60-66 Nut
Once again, Nice work
Was the rear end change mainly for the gear, or was the 14 bolt showing weakness?
Old 09-18-2012, 11:43 PM   #63
ChopperCity256
ChopperCity256's Avatar
Love it! Seeing this is sparking some thoughts..
ChopperCity256 is offline   Reply With Quote
Old 09-19-2012, 07:11 AM   #64
bcdeutsch731
14 bolt was changed out for the gear and also I got it for a steal off racingjunk. If I break this one we have bigger problems then the rear end!! The Pinion gear on this MW is the size of most ring gears.
8.3@168mph 1700+ HP
Old 09-19-2012, 12:11 PM   #65
vin63
vin63's Avatar
L/F=1500 R/F=1420
L/R=1000 R/R=920
Wheel base 114"
Brett
Brett, I would try starting out with the IC right around 63" and 2" above the ground and see how it likes it. Make all of your pre-load and shock adjustments (increasing firmness incrementally on the compression and rebound) according to how the truck launches first before making additional 4-link changes (so that the truck launches straight). Keep detailed notes for each adjustment. Have fun testing the new suspension.
Old 09-19-2012, 11:42 PM   #66
Super73
Super73's Avatar
At your ride height, can you give us the following:
Axle center height
Height of the lowest hole for all four rod ends (front/rear hole for upper and lower bars)
What is the spacing for each hole (5/8" centers?)
Length of both upper and lower arms
My 4-link is set long and low. 5" off the ground and 60ish inches.
Old 09-21-2012, 07:02 AM   #67
bcdeutsch731
Axle center height 14.31
Height of the lowest hole for all four rod ends (front/rear hole for upper and lower bars) rear lower=5.87 rear upper=16.92 front lower=4.68 front upper=9.68
What is the spacing for each hole (5/8" centers?) 13/16"
Length of both upper and lower arms lower=22" upper=22.75
Thanks for any help. I have some 4-link software that I have been playing with. I just did't know what a good starting point would be.
Brett
8.3@168mph 1700+ HP
Old 09-21-2012, 07:08 AM   #68
bcdeutsch731
Vincent,
thanks for the help and also thanks for the shipping refund.
8.3@168mph 1700+ HP
Old 11-01-2012, 06:46 AM   #69
bcdeutsch731
Little update on the truck. I would like to thank Vincent (vin63). I set my IC at 62" out and 2.6" up and the truck hooks great. I have been fighting trans problems all year. The Allison would not hold up to all the power, so I started talking with people and they told me I need to get a BTS 4R100 trans. I had an adapter made to go from the Duramax to the Ford 4R100. Had Brian build me a trans and installed it with a PCS trans computer. I went to the dyno last week to get the trans all dialed in and the truck dyno'ed 960hp on the small race tune. Witch is 40 more hp then the Allison on the small tune. On the big tune the truck made 1105hp. I went to the track last Wendesday and on the small race tune it ran a 9.62@146. On my 2nd run I blew a boost tube. I was so happy to get the trans problems figured out. This Saturday was a Diesel Shoot Out at my local track. My first run of the day on my small tune I ran a 9.43@148 with a 1.44 60ft. The best thing is my front tires come off the ground about 2" off the line. That has been a goal of mine since I started this project 3 years ago. On my 2nd pass I ran a 9.59@146 with a 1.43 60ft. I thought since the trans was working so good and the track prep was great I would put it on the big tune and see if I could get a 8.9@15x. When the truck hit 3rd gear I herd a snap and the motor hit the rev limiter. Well that bullet proof trans is not so bullet proof. I snapped the input shaft in half. Brian told me he has never had one break before and they are made out of 300M material. He is having some new shafts made out of Jasco 1000 material, I'm not even sure that is how you spell it. He said I will not have to worry about those shafts breaking.
8.3@168mph 1700+ HP
Old 11-01-2012, 06:48 AM   #70
bcdeutsch731
Here are some videos of the 9.43 run.
8.3@168mph 1700+ HP
Old 11-01-2012, 06:50 AM   #71
bcdeutsch731
Here are some videos of the 9.59 run.
8.3@168mph 1700+ HP
Old 11-01-2012, 01:33 PM   #72
bcdeutsch731
Here is a slow motion of the start.
8.3@168mph 1700+ HP
Old 11-01-2012, 03:03 PM   #73
vin63
vin63's Avatar
Congrats on the ET, Brett! I had set up a BBC 4-link C-10 drag truck a couple of years ago and ended up with the IC at 59" and about 3" above the ground, so I figured the extra weight of the Duramax/Allsion up front would shift the IC forward and down a bit for your chassis.
Sorry to hear about the transmission troubles - 1300+ ft-lbs can really do some damage. I ran a racing TH400 behind my fuel altered for awhile, but ended up going to a 3-disc glide clutch and a Lenco from the torque my blown Pontiac is making. How important is the OD trans for you?
Old 11-02-2012, 07:12 AM   #74
bcdeutsch731
Thanks,
My motor will rev to 5500 but I shift it at 3600 to keep it in the torque band. When shifting at 3600 I'm hitting OD at the 1/8 mile mark and the whole back half of the track is in OD. I have never tried to make a run reving it out. I looked into a Bruno/Lanco but it was just to much money. I should try to figure it out on a calculator to see if it will work.
Tire size 31
Gear 2.91/1
1/4 mile speed 150-160
8.3@168mph 1700+ HP
Old 11-02-2012, 09:29 PM   #75
vin63
vin63's Avatar
It might save a little to go the route of a full racing TH400 and a Gear Vendors, but at 1300 ft-lbs, which ever trans direction you go, it's going to be pricey. I would probably lean toward the Bruno/Lenco combo, but check with this guy, Mike Stewart...he's built all of my racing automatic transmissions, including the TH400 I had behind my blown Pontiac (I was making about 1800 hp/1500 ft-lbs at that time) in the fuel altered. He builds the stoutest transmisisons for some of the heavy, high horsepower door cars in the fastest street car scene, as well as the traditional NHRA racers from Sportsman to Top Alcohol classes.
http://mikestransmission.com/index.html
