Old 01-10-2012, 02:30 AM   #51
markeb01
Senior Enthusiast
markeb01's Avatar
Re: All about heaters.
NOTE - since this posted at the top of a new page, be sure to check the previous page if you are looking for OEM installation schematics for 1960-63 heaters.
In response to the earlier questions asking about late model heater motor options, I swapped my original for one out of a Pontiac Fiero. The main thing I was looking for was one that rotated in the correct direction. At the time it seemed the only models I could find were those in S10 pickups and the Fiero. The advantage of the Fiero over the S10 is that they are all mounted in the trunk, so they are clean and look like new compared to one that’s been mounted under the hood for a couple of decades.
The heater case required some minor trimming, but the much larger plastic fan fit into the case without modification. The motor itself is the newer permanent magnet design. On high speed airflow is about twice that of the original fan and motor. The rubber hose is presumably for motor ventilation. It doesn't go anywhere in my installation, so I just pointed it downward to keep dust out.
I don’t have any decent photos, but here’s what it looks like installed on an economy heater:
Old 01-10-2012, 06:11 AM   #52
kevinc
kevinc's Avatar
i have a unit I'm going thru right now. When restoring a deluxe heater, what color and finish did they come from factory?
1988 C1500 Regular Cab, Long Bed, 2WD.
kevinc is offline   Reply With Quote
Old 01-10-2012, 08:56 AM   #53
benwah
benwah's Avatar
[/QUOTE]
Good to know, I have a cheap heater in my 62. Good luck finding a Fiero around here! I havn't seen any of them in the several junkyards I frequint in years. What is a deluxe heater worth if I were to get one in a yard? $10?
benwah is offline   Reply With Quote
Old 01-10-2012, 09:46 AM   #54
Rich 5150 69
Rich 5150 69's Avatar
Originally Posted by clemdaddy View Post
had this search for air conditioning blower motor and found out that the blower motor from 70's-80's trucks and subs is exactly the same as the factory 64-66 motor. new replacement part...
i know this thread is about heaters but the air motor has more windings and slightly faster speed which blows more air.
deluxe heater motor on left... factory air motor on right.
got a new air motor over the counter at napa. seems like a decent swap out.
of course, i could be wrong.
clem
Sense Clemdaddy posted the pics of the fan motors, I will piggy back with Van Pershing`s fan /hub quick fix which is one thing I did...after the fan started screaming at me last year.
http://www.persh.org/pickup/HeaterFan.htm
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 01-10-2012, 10:01 AM   #55
Rich 5150 69
When Bubba327 changed out his heater core for the larger core he had to open up his upper lid the accomidate the larger core, as shown in the pic above....my upper section is already larger/factory but has a notch in it for a block off plate, I`m assumming that this would be a later design as to cut costs one box fits all...? I ended up with a smaller core only because I could`nt find a larger core locally, made a quick plate from alumimun. Anybody have pics as to how the factory hung the core in the box.....?
Old 01-11-2012, 01:03 AM   #56
Captainfab
60-66 Nut
There are formed steel 'C' shaped straps at each end that fit over the tanks on the ends. These are attached to the top cover with screws. Sorry I don't have any pics........
Old 01-11-2012, 03:34 PM   #57
65Guy
Hey mark do you have assembly manual pics for 65 with deluxe 3 lever heat?
65Guy is offline   Reply With Quote
Old 01-11-2012, 03:41 PM   #58
markeb01
Senior Enthusiast
markeb01's Avatar
Sorry, I only have the 1960 Accessory Installation and Chevy Truck Shop manuals.
Old 01-11-2012, 04:20 PM   #59
1963c-10
1963c-10's Avatar
I just rebuilt the deluxe unit in my 63 w/the Ranco heater valve installed on the core if anybody needs any literature on it or the install.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 01-17-2012, 12:58 PM   #60
1963c-10
1963c-10's Avatar
BURBLUV Maybe this will help
Old 01-27-2012, 03:26 AM   #61
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Here's some pics that CaptainFab posted of his Deluxe heater:
66 C20 Service Truck:
Old 01-27-2012, 09:38 AM   #62
1963c-10
1963c-10's Avatar
That deluxe heater captainfab has is a little different than mine. My heater control valve is on the top of the unit. The cable is not exposed....runs through the firewall into the heater box assembly
Old 01-28-2012, 01:03 AM   #63
Captainfab
60-66 Nut
The '60-'63 deluxe heaters are different than the '64-'66 deluxe heaters. The cable you speak of does indeed go to a heater coolant flow control valve located on the heater core itself. The cable in the pics that Jon posted above, controls a flap that regulates the amount of air entering the heater box from the cowl area.
Old 02-08-2012, 02:45 AM   #64
Twiztid_66c10
quick question i have a 66 with a deluxe heater and am wanting to put a economy heater in it for the space under the hood. can i hook my old deluxe controls up some how or will have to also get the eco controls?
1966 C-10 long wide- currently with 2 3/4 sectioned crossmember, 3 inch cupped a arms with 2700 bags, 67 master cylinder, in the middle of a v8 swap,
soon custom rear wishbone set up and bags
1942 chevy/divco ambulance
1937 chevy truck
Twiztid_66c10 is offline   Reply With Quote
Old 02-29-2012, 11:41 AM   #65
jbgroby
jbgroby's Avatar
In one of the earlier post it was stated that 60-63 did not offer a deluxe heater set up, But according to the options catalog I have they did. This is the 1960 edition page.
jbgroby is offline   Reply With Quote
Old 02-29-2012, 12:16 PM   #66
markeb01
Senior Enthusiast
markeb01's Avatar
I can't confirm on a 66, but I installed a deluxe heater in my 1960 first, and replaced it later with an economy model. The factory operating controls were identical, except the deluxe model used four levers, while the economy model only used two of them. In fact the economy panel only came with two levers, but the 4 lever deluxe panel could perform the same functions. Two of the 4 deluxe levers just wouldn't be connected to anything.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 02-29-2012, 12:32 PM   #67
markeb01
Senior Enthusiast
markeb01's Avatar
You know Jake that first picture is just weird. I've seen it before but never took the time to analyze it. I can't envision any way that could be installed as shown. The long upper intake would obviously have to be connected under the hood to the plenum intake on the upper firewall, but the defroster ducting would have to be inside the cab. And of all the heaters I've seen, the economy models are the only ones to have the fan motor inside the cab. The deluxe models are under the heater core on the engine compartment side of the firewall as shown.
It appears what they did was rotate the fan housing outlet to the side so it could connect directly to the defroster valve, and left out the elbow duct that actually connects the two parts inside the truck. It was probably just slapped together to have a picture for an advertising brochure, figuring nobody would know what it's suppose to look like anyway. But it sure is confusing from a historical documentation standpoint.
Old 02-29-2012, 02:33 PM   #68
A.T. RockDriller
A.T. RockDriller's Avatar
Was that maybe the design used for the cab-over...or LCF...?
Or am I jes' smokin' the tall grass..?
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 02-29-2012, 05:28 PM   #69
jbgroby
jbgroby's Avatar
nah what it is,they turn the under hood part (drawing) so the buy could see what goes under the hood. That's all.
Old 03-10-2012, 06:18 AM   #70
Vernski
The reason the picture is weird is because it's for a tilt cab, take a look at Areotrucks post #32 I looked at the flyer and wondered the same thing then I read it was for a tilt cab....Vernski
Vernski is offline   Reply With Quote
Old 03-10-2012, 10:53 AM   #71
j.kirn
I have a complete NOS deluxe 1 in box i will have to post pics when i get a chance to get to it
j.kirn is offline   Reply With Quote
Old 03-10-2012, 03:02 PM   #72
A.T. RockDriller
You might be able to rotate that blower motor..as they should be clocked for different apps....and use it for the standard pick-up cab....and use the defroster plenum where it should go. Meaning....maybe....that that tilt-cab NOS heater would give you a new set-up for your truck....possibly minus a piece or two. Nothin to complicated..
I think.
BTW...j.kirn....Is it the GMC or the Chev brand...?
Les Hunter
Old 03-11-2012, 02:41 AM   #73
j.kirn
chevy
Old 03-11-2012, 11:35 PM   #74
ABX131
ABX131's Avatar
I was told using a blower motor out of a suburban that has rear air and heat vents in an earlier truck, like my 63' will give you a ton of force through the shorter ductwork...the motors should be interchangeable.
ABX131 is offline   Reply With Quote
Old 03-12-2012, 11:03 PM   #75
tc64
tc64's Avatar
so where does the cable go on the economy heater? do you have to take the cover off?mines been just sticking out the firewall since i got it.
tc64 is offline   Reply With Quote
