Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 06-29-2015, 03:38 PM   #51
puller
Re: 1970 3/4 step side puller build (blue blood)
So I have been working on engine during this time and have it assembled almost ready to go in truck. Its a 454 crate motor from Gm. I changed pistons to 9-7-1 compression Ported the peanut port heads to flow 260cfm at 600 lift put a factory holley cast iron intake on off 60s 427 vet motor and ported some vortech exhaust manifolds to make it a stock looking torque monster.
puller is offline   Reply With Quote
Old 06-29-2015, 03:41 PM   #52
puller
I even found a duel snorkel air cleaner and added holes to rear so it would look old and still make hp
Old 06-29-2015, 03:46 PM   #53
puller
Also I have a set of hooker 1 7/8 headers that I had jet coated brand new in box if anyone is interested? I need to run cast iron intake and exhaust manifolds because I plan to do some stock class truck pulling with her
Old 07-16-2015, 11:22 AM   #54
puller
Have the motor finished! Decided to run March serpentine set up and really happy with kit. Beats the heck out of stock stamped pulleys that I had problems in the past throwing belts at high rpm.
Old 07-16-2015, 11:27 AM   #55
puller
here are pictures
Old 07-16-2015, 11:38 AM   #56
puller
Also started cutting gauges into instrument panel. Though 2 5/8 auto meters gauges would fit but figured wrong. They are in but not real happy I could not keep them level with each other because of rear backing panel. I should have bought 2" gauges!
Old 07-23-2015, 09:42 AM   #57
puller
Its been like Christmas morning around my shop! UPS just keeps dropping off cool stuff! But my credit card is hot. Was better when Santa Clause did not charge my Card LOL. Just installed power brake master cylinder for disc brakes and received a text from body shop with some blue paint getting put on fenders
Old 07-23-2015, 01:09 PM   #58
Bladeboy1998
Awesome! This is by far my favorite build on the forum, this and 1972gmc's k2500 build!
Bladeboy1998 is offline   Reply With Quote
Old 07-24-2015, 09:26 PM   #59
swamp rat
swamp rat's Avatar
I love it when color starts showing on these build threads!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-28-2015, 10:08 AM   #60
puller
I spent the week working on brakes. Should not have been this hard but nothing matched up from swapping in dana 60 front. Ended up bending all new front lines. Also thought I had wrong calipers but finally figured out that I was a dumb ass and was not putting shim in right place to hold caliper LOL
Old 07-28-2015, 10:13 AM   #61
puller
Also picked up fenders. Only inside of them finished so I can install engine spray outside truck all at once when we get that far....
Old 07-28-2015, 10:19 AM   #62
puller
I installed my dash and started some of the wiring. Truck has new painless wiring harness and so far fits nicely. Also had to cut hole in floor to put high hump in to clear trans better.
Old 08-17-2015, 12:47 PM   #63
puller
Its all the little things that take a lot of time. I thought I would have motor fired by now but being I changed back to exhaust manifolds they did not fit between my fabbed motor mounts. Had to pull manifolds and cut mounts to get motor to fit. But look at all the fire wall room! Moving engine ahead helped that problem.
Old 08-17-2015, 01:00 PM   #64
puller
Being moved engine ahead went with hydraulic clutch setup from Novak. Nice kit but does not bolt up with out some fabbing like most things!
Old 08-17-2015, 01:07 PM   #65
puller
Finished exhaust. Made some 2 1/2 to 3" collectors and fabbed exhaust all stainless. I mig welded exhaust this time. Not as pretty as tig but do not own tig welder and did not feel like pulling exhaust off to bring to welding shop.
Old 08-17-2015, 01:11 PM   #66
puller
Also made new throttle linkage. Worked great till I tried to put air cleaner on Grrrr Back to drawing board!
Old 08-17-2015, 03:20 PM   #67
Bladeboy1998
Awesome! Making some progress!
Old 08-18-2015, 12:55 PM   #68
ERASER5
ERASER5's Avatar
So what gas are you running with the SS wire?
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 08-19-2015, 04:59 PM   #69
4spd
4spd's Avatar
Where did you get the 10 leaf rear springs from? Were these from a donor truck or bought new?... Thanks! Love the stock puller/resto combo
87 Chevy K20 - 350 Turbo 400 SOLD
72 Chevy K20 - 350 4spd, 2.5 skyjacker lift, 33 inch BFG's, Extreme bend hooks and Slots - SOLD 2016
85 Chevy K30 - 350 4spd
4spd is offline   Reply With Quote
Old 08-20-2015, 09:27 AM   #70
puller
I just added leaves to stock springs. I bought one set of add a leafs and the rest where just used leaves I had from donor truck. I did switch to Off Road Design flip u bolts. They are supposed to be stronger. I also changed spring perches to solid iron blocks because I twisted and crushed stock ones in past pulling days!
Old 02-02-2016, 12:24 AM   #71
twistedchevy
Bump
Mine: 72 c20 Chevy suburban, 02 5.3 w/4l60e , factory ac and 50gal tank.
70 k10 Chevy burb, 04 5.3 w/4l60e np241, with dual 30gal saddle tanks and rear 30 gal tank
Dads: 67 c10 step side(project)
72 c10 GMC burb 350/400, with 67 Chevy front clip(grocery getter)
Ours: 67 c30 tow truck
70 c10 long bed 383stroker w/digital gauges(work truck)
twistedchevy is offline   Reply With Quote
Old 02-15-2016, 09:23 PM   #72
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Awesome truck, any updates?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-16-2016, 11:45 AM   #73
puller
Truck is painted!! Here are a few pics
Old 03-16-2016, 11:55 AM   #74
puller
Here is picture of box with fuel tank and bed wood installed. Body shop is doing final buff and I am picking truck up Friday will post more pictures. Excited!
Old 03-17-2016, 10:24 PM   #75
ND_guy
Tool Addiction=Money Shortage
ND_guy's Avatar
Sexy looking rig. I enjoy seeing your attention to detail.
1967 K20 400TBI SM465/NP205
posi front, Detroit locker 4.56 rear
ND_guy is offline   Reply With Quote
