Old 01-10-2012, 03:47 AM   #51
Tyz082
Re: Operation : In to Deep!
need some advice from the wise,
i bought that disc brake conversion kit and i got the 5 lug 4.75 rotor pattern.
my thought was, more options for rims.
the rear i was going to keep stock, drums, but they are 6 lugs.
here are my options i have deduced.
1. buy (2) 5 lug rims for the front and (2) 6 lug rims for the rear
2. convert the rear to disc and buy a new prop. valve
3. any other ideas????????
suggestions??
UPDATE FOR THE DAY
have taken off the cross member and started polishing the frame rails... again
Tyz082 is offline   Reply With Quote
Old 01-10-2012, 03:54 AM   #52
Tyz082
This is why i wanted to have a redo on the crossmember, my blast man didn't do the greatest of jobs. but for 200 bucks i cant complain too much. In his defense when it was all assembled most of this would have been very difficult to see.
Old 01-10-2012, 10:49 AM   #53
67cheby
67cheby
67cheby's Avatar
i say go ahead and switch the back , it will make your life much easier in the long run !
67cheby is offline   Reply With Quote
Old 01-11-2012, 02:21 AM   #54
Tyz082
Why do you say that aside from working on drums is a b****
Old 01-11-2012, 12:47 PM   #55
67cheby
67cheby
67cheby's Avatar
mix matching the 5 and 6 lug wheels
Old 01-11-2012, 09:10 PM   #56
Tyz082
got ya, thanks for the input. weighing my options, this seems like the best way.
Old 01-14-2012, 06:41 PM   #57
Tyz082
Bought a pressure blaster, gotta say its the best 120 bucks I've spent so far.
This thing rocks!
In the process of priming the A-arms now. next up, springs and crossmember.
Old 01-14-2012, 07:06 PM   #58
sharpmark
i'm with 67 cheby-change the diff now as it gives lots more options for rims and won't drive you nuts in the future if you have a flattie.
you are doing everything else properly so why scrimp on the diff?
great progress by the way
cheers mark
1969 stepside-305/4spd/12 bolt posi
http://67-72chevytrucks.com/vboard/s...d.php?t=477157
1968 pontiac lemans convertible-350/pwrglde/10 bolt
1934 oldsmobile sedan-350/350/12 bolt posi
1930 model a pickup-350/350/jag ind
1928 model a roadster-283/350/9"
sharpmark is offline   Reply With Quote
Old 01-14-2012, 07:15 PM   #59
litew8
litew8's Avatar
heck ya. Looks real nice. Wish I had one of them!
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 01-14-2012, 08:07 PM   #60
Tyz082
Right on mark thanks for the input and compliment. litew8, harbor freight or tractor supply is the place to get one of these cheap, no complaints, works great! I'm gonna hafta do some more research before i decide how to go about the rear end situation.
Got the first coat of primer on! thats about it for the evening. takin the family to dinner. MMMMexican! lol
Old 01-14-2012, 10:01 PM   #61
litew8
litew8's Avatar
Don't have the space or compressor - hence "wish".
Old 01-15-2012, 04:39 PM   #62
Tyz082
lol got ya!
Old 02-22-2012, 10:27 PM   #63
litew8
litew8's Avatar
Any updates
Old 02-22-2012, 11:55 PM   #64
CharlesUFarley
If it's not too late, I say wait on the frame painting until you have finished building. Then tear it down and paint it last. Most peole here start with modest plans that spiral into frame notches, air bags, shock relocation, air tank mounts....etc. etc. etc.
Get it how you want it...make sure everything fits and bolts in as planned so you don't have to cut or weld on a painted frame or body. Then when you have every part installed and adjusted correctly, strip it down and paint it.
CharlesUFarley is offline   Reply With Quote
Old 02-23-2012, 12:39 AM   #65
JamesRKing72
JamesRKing72's Avatar
Looking great. I'm about to start on my '71 that has been in the family for 35+ years. Been sitting in a country field for about 20 years and doesn't look so good now. Wish I had a garage/workshop like yours, would make my life a lot easier. :-)
1971 Cheyenne, The Blue Jay.
The Blue Jay build thread-
http://67-72chevytrucks.com/vboard/s...d.php?t=516989
JamesRKing72 is offline   Reply With Quote
Old 05-31-2012, 12:59 AM   #66
Tyz082
sorry guys, no updates. my pickup has taken a back seat to work hours and some other household projects, sealing the deck, painting the house, opening the pool, etc.
hope to get back on this bad boy in the fall. I forgot where i left off.
work has been crazy busy. 7 days a week 12 hours a day. dont give up on me yet boys!
Old 06-01-2012, 06:06 PM   #67
Tinkermc
thinking about the 5 lug front and 6 rear, means you need to carry to spars and that you can not rotate the tires very easy. If it were me I'd go 5 all the way around
Tinkermc is offline   Reply With Quote
Old 07-17-2012, 02:11 PM   #68
XxCHEVYMANxX
XxCHEVYMANxX's Avatar
Nice progress man! You might have already figured out your rear end situation, but cpp also has a 5 lug axle conversion kit. It lets you use stock 70's drum brake parts.
John
Mild Custom 68' Work Truck Build
Facebook LoL
1977 Trans Am (Project)
1965 Chevelle (Project)
XxCHEVYMANxX is offline   Reply With Quote
Old 07-18-2012, 03:14 AM   #69
ZUBZ
ZUBZ's Avatar
same here Tyz....we in winter at the moment and been really cold so not much happening this end either....
ZUBZ is offline   Reply With Quote
