Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 08-28-2012, 02:46 PM   #51
jstplyn331
jstplyn331's Avatar
Re: '72 Blazer 4wd getting all the best
Originally Posted by CTENTA1 View Post
diggin those valve covers
Yea the Coil covers are nice, but make sure you have the room to bolt them on. If I was installing a LS1 in the 2wd crossmember. I would hit the firewall and they would not work. They are as big as a big block Valve cover.
Build Thread,
jstplyn331 is offline   Reply With Quote
Old 08-28-2012, 04:21 PM   #52
hilljob26
hilljob26's Avatar
can you get a pic of the channel which you mounted your engine mount to..i dont mean to sound like an idiot,,just tryin to see exactly what you had to do..the price of that mount is far better and looks way better then anything out there..as far as where you mounted the engine,,anychance you have a measuremnt from some point on the frame to give me an idea
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 08-28-2012, 04:38 PM   #53
jstplyn331
jstplyn331's Avatar
The Frame, Channel. I can get a pic. But it will be awhile it is at a place getting stuff done, and I don't get there often.
If you look @ the Mount. You will see it has a bracket that slides on the end of the tube. You see the (4) bolt holes. We made a C Channel that slides in the frame notch. This allowed us to bolt that were we needed it, and then we bolted the cross member to it.
If that don't help I will try and post pictures the only ones I have right now is it sitting on the bottom rail of the frame.
Build Thread,
Old 08-28-2012, 04:42 PM   #54
jstplyn331
jstplyn331's Avatar
Had to upload this pic. I am a little excited to see the gauges in the Billet housing so much I could not wait to show it with the the cut out it is getting to flush mount the shift indicator, and with the powder coating, and polishing done.
I took this about a month ago, and forgot to show it off. Ow well it is getting a lot of work done right now.
Build Thread,
Old 08-28-2012, 04:50 PM   #55
hilljob26
hilljob26's Avatar
are you using the newer column as well...i am pondering the idea,,as i am wanting to try using the remote locks and everything
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 08-28-2012, 05:06 PM   #56
jstplyn331
jstplyn331's Avatar
Yeh, I think I put that on the first post. It shows I am doing an Ididit Black powder coated column.
I don't know what that has to do with Remote Locks though?
Build Thread,
Old 08-28-2012, 05:20 PM   #57
fxdxharley
Just a nother gear head
fxdxharley's Avatar
You can use the ididit fob for other functions like door lockes etc.
2013 HD FLHX
2000 chevy 2500 6.0l 4x4 3dr
2000 harley fxdx
71 Jimmy 4x4- future crawler/ woods rig
71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589
fxdxharley is offline   Reply With Quote
Old 08-30-2012, 09:49 PM   #58
Classic383
Classic383's Avatar
I noticed the push button start! Where did you get that one from? I am looking into one too because the stock ignition switch no longer fits in mine. Awesome Build! keep the updates coming.
1972 K5 383 Stroker 4x4 in progress...STILL
1978 K10 6" Lift on 36" Swampers, 350, 350
1976 K10 Step Side 4" Lift on 37" Swampers, 350, 350, 3/4 Ton Axles
Classic383 is offline   Reply With Quote
Old 08-30-2012, 09:58 PM   #59
jstplyn331
jstplyn331's Avatar
No I am using the Remote start / Alarm Push button RFID keypad for the locks windows etc.....
Build Thread,
Old 08-30-2012, 10:00 PM   #60
jstplyn331
jstplyn331's Avatar
I did a search and found them in China, I contacted them as they are a supplier and they allowed me to purchase just one. I think it is rather good quality. I will find out soon.
I paid about 375.00
Build Thread,
Old 10-16-2012, 08:20 PM   #61
jstplyn331
jstplyn331's Avatar
Just got it back from powder Coating, Time to install Run all the new braided lines hook up everything and fire it up
Build Thread,
Old 02-13-2013, 11:38 PM   #62
hilljob26
hilljob26's Avatar
how has this build been goin,,im intersted to see your progress
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 02-13-2013, 11:54 PM   #63
boonedogs72
boonedogs72's Avatar
Who made the fuel tank? What's the capacity?
boonedogs72 is offline   Reply With Quote
Old 03-08-2013, 05:24 PM   #64
jstplyn331
jstplyn331's Avatar
Sorry about the late response, the tank is made by Boyd Welding, and I believe it is a 15gallon, you can go there and see. they are nice. www.boydwelding.com
Build Thread,
Old 03-08-2013, 05:27 PM   #65
jstplyn331
jstplyn331's Avatar
Yeh no more pictures, this project has turned a corner.
I found out from the Body guy even before he got started that the frame May be tweeked, He thinks It has either seen a ditch or something. As I do not want to find out, and or put up fighting it all its life if it is true, redoing all that has been done, crossmember, etc....
I am thinking about swithing gears and using everything on my 67 truck. gotta love the interchangable parts.
Build Thread,
Old 03-08-2013, 08:21 PM   #66
amcgeh01
amcgeh01's Avatar
Well, I just happened to come across a 37 gal tank made by these folks in Oregon.. You can check out the link & the prices but you get what you pay for. I am super happy with mine and it gives me almost an 800 mile range @ 22 mpg... http://www.nwmp.com/index.php?option...-gmc&Itemid=17
In-work on my 5.3L/4L65E/NP208 case conversion into a 1972 GMC JImmy 4x4... Not as simple as it looks folks..
amcgeh01 is offline   Reply With Quote
