Old 06-28-2013, 08:57 PM   #51
northern 85
northern 85's Avatar
Re: Project: Tiki Express, '65 C10 Panel Truck Build
Any updates? Hows the wagon?
northern 85 is offline   Reply With Quote
Old 06-29-2013, 12:40 AM   #52
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Well, I would have liked to had some positive news but not so much. Back in the beginning of April, coming back from a Nova meetup, the engine went south. I had to pull it, rebuild it, which led me down the path to fix a few other things I wasn't really happy with. I have a week or two left to hopefully have the wagon back on the road.
My plan is after getting the wagon back on the road, I will get back to the panel and finally get it back on the road, having sat for the last year and a half on the side of my house.
Once it's on the road, I need to get back on my '68 truck...
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-29-2013, 07:11 AM   #53
northern 85
Thats progress,what kind of build on the wagon engine?
Old 06-29-2013, 11:59 PM   #54
chevy_mike
chevy_mike's Avatar
Just a mild build on the 250 Inline 6. Also redid the booster/MC setup, front hard lines redone, HEI setup, rewiring the engine compartment and installed my custom built Speedhut gauges.
Old 06-30-2013, 07:03 AM   #55
northern 85
Wow everything looks sweet!
Old 06-30-2013, 10:13 AM   #56
63suburby
63suburby's Avatar
Originally Posted by chevy_mike View Post
Yeah, it didn't help that I bought another car... I SOOOOO need to get back on the panel.
New toy, '64 Chevy II wagon
Ive got a 66 wagon same color
63suburby is offline   Reply With Quote
Old 07-17-2013, 06:08 PM   #57
chevy_mike
chevy_mike's Avatar
Looks like the wagon is back on the road. Here's how the engine turned out
Now I need to get a couple house things done and back to work on the panel!!!!
Old 07-17-2013, 07:52 PM   #58
northern 85
Very nice work!
Old 07-28-2013, 02:11 AM   #59
mosesburb
I had a V-8
mosesburb's Avatar
Looks great Mike!! Very clean.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 07-31-2013, 09:52 PM   #60
71chevymike
71chevymike's Avatar
Nice panel. I'm in the process of purchasing a '65 panel to build myself. It will be my first ground up build, so I've been looking for places to get parts, not having much luck. I do love those panel trucks.
71chevymike is offline   Reply With Quote
Old 07-31-2013, 11:13 PM   #61
DouglasRaymond
Very nice looking panel, like the slots. Wagon is cool too.
DouglasRaymond is offline   Reply With Quote
Old 11-09-2015, 03:51 PM   #62
chevy_mike
chevy_mike's Avatar
Okay, it has been a LOOOOONG time since I posted any updates or really did any work on the panel. I managed to get it into my garage in Feb. 2014 (yes... 2014!) and had some health issues that really kept me from doing any work on it. Having resolved most of the health stuff, I am starting to get back to this project.
I had picked up a set of later model 15x8 factory steel wheels and had planned to go with the trim rings/baby moon caps with wide white walls. I got the wheels stripped, primed and painted. Then I was floored at the cost of wide whites. I was looking at $1000 -$1200 plus install. I just can't bring myself to do it. I thought about doing standard black wall tires but it wasn't going to be the look I had in my head. That put the project on hold for a bit.
I then figured out that a number of the rear axle wheel studs were screws up and I would need to pull the axles and figured I would replace them all with longer ones while I was at it. Then I really started thinking, if I am pulled the axles, do I really want to stay 6 lug or swap over to 5 lug? I did some searching for wheels I liked that were also reasonably priced. I found them. Discount Tire sells MB Old Schools and I got a 17x8, 4.5" BS wheel to test fit. It fits just like the 15x8 wheels I have. I am going with a 235/60-17 tire which puts me almost identical to the 235/70-15 I was going to run. With that I ordered new Tom's KA axles which should be here any day.
Well everyone likes pics so here are a few to get ya goin'
15x8 steelies, painted with trim rings and moon caps (will be for sale in classified)
New 17x8 Old Schools! Loving these. Classic look with modern flair.
Hopefully you will start seeing more updates.
Old 11-09-2015, 10:38 PM   #63
earl84
Love the look of those new rims.
earl84 is offline   Reply With Quote
Old 11-24-2015, 03:16 AM   #64
The_Hub
The_Hub's Avatar
Just read through your build. Glad to see you're getting back at it. Have you thought of doing regular black tires with white lettering? I went with cooper cobras lettering facing out. Looks good and I'm ready to see some more progress on it!
The_Hub is offline   Reply With Quote
Old 11-24-2015, 11:54 PM   #65
chevy_mike
chevy_mike's Avatar
Okay, a few updates, yes really updates!!! As for wheels and tires, I have committed myself to the new ones, since I now have all 4 wheels and tires.
This past weekend I swapped out the old 6 lug axles, bearing and seals. I decided that since these new wheels are open and you can see the brakes behind them, I didn't like having drums in the rear. I bought a new set of caliper brackets from CaptianFab (thanks for the quick shipping) and took the rotors and caliper setup off my stalled '68 C10 project. Figured I could put them to use now. Put in a new set of Tom's KA axles (way beefier than the stock ones), new bearing and seals. Painted and installed the caliper brackets, rotors and calipers. Just need to install the diff cover and fill with fluid, then the rear end is done, outside of the e-brake.
On the fronts I got the rotors and calipers painted and installed. Ordered a Corvette master cylinder (going to run manual brakes as I like them in my '65 C10 truck). Need to build some lines and bleed everything.
Since I am staying with a manual trans, I decided I wanted to do another AX15 5 speed swap. I found a recycle yard in Kansas that had a low mileage one for a good price and had it shipped out. It came in today. I'll document it in this thread but I have a write up about the install in my '65 C10 truck I sold. Here is the info AX15 Install
Well everyone likes pics so here they are!
New wheels and tires test fitted (17x8, 4.5 BS with 235/60-17 tires)
Painting parts
Rear axles, caliper brackets and brakes mounted
AX15 trans
With the Thanksgiving weekend here, not sure if I'll get much done as will be doing family stuff. Still, getting closer and closer!!! Stay tuned...
Old 11-26-2015, 02:06 AM   #66
Captainfab
60-66 Nut
For some reason I haven't thought about Toms for axles too. He's not that far from me but I have yet to need to visit him yet.
Old 11-27-2015, 11:29 AM   #67
AJCK87
The motor looks great! This is a nice looking panel. Do you have any detailed pictures of the passengers side barn door latch? Both of mine are in different states. Both look like they have a bit broken off
AJCK87 is offline   Reply With Quote
Old 01-28-2016, 01:15 PM   #68
chevy_mike
chevy_mike's Avatar
Well not much of a progress update. Lots of stuff going on. I have done some of the brake line stuff but still need to finish that up. What I have been doing is buying parts. The biggest one was picking up a late model 350, 1 piece rear main, Vortec heads, roller cam engine for this project. I am going to swap that in. I just ordered the Novak adapter for the trans, new flywheel, clutch and new mini starter. I also bought a Dakota Digital VHX gauge kit (black face, blue LED). I have on order and awaiting it to ship, a FiTech Go Street EFI kit. Yep, going EFI in this panel!!!
Well hopefully I'll get the parts and start getting this thing together...
Old 01-28-2016, 01:41 PM   #69
midnight rambler
midnight rambler's Avatar
dam looking good
midnight rambler is offline   Reply With Quote
Old 05-07-2016, 04:51 PM   #70
1955 mancave
1955 mancave's Avatar
anything new on your panel ? I love your build , of course building one my self i'm going to follow this build.
1964 1 Ton flatbed service truck (sold)
1964 C-10 panel (project complete frame up build)
1957 210 post pearl orange
1955 mancave is offline   Reply With Quote
Old 05-07-2016, 04:58 PM   #71
1955 mancave
Wow! Almost 100 views and no comments... guess there's no love for the panel... LOL
I know how you feel, I'm like hmm and I know there are panel lovers out there. lol
Old 05-08-2016, 08:53 PM   #72
chevy_mike
chevy_mike's Avatar
Well, not much going on. Got side tracked with another toy...
Old 05-08-2016, 11:16 PM   #73
midnight rambler
Nice SS
Old 05-09-2016, 10:28 AM   #74
chevy_mike
chevy_mike's Avatar
Originally Posted by midnight rambler View Post
Nice SS
Thanks. Not a real SS, just a clone. Was done by the previous owner.
Besides the wheels, tires and bed cover, I also added Dakota Digital VHX gauges, Lecarrea steering wheel and Retro Sound radio.
Old 05-09-2016, 11:31 AM   #75
midnight rambler
I like it
