#51 |
Re: 1968 C10 5.3 swap, the easy way.
What AC condensor did you use?
#52 |
tell me more about what you have determined works with the fuel system..
#53 |
I used a Boyd Welding aluminum tank with in tank pump. Used summit AN 90's coming out of tank and AN tube nuts with 3/8 aluminum tubing and summit AN to quick connect to connect to Corvette filter regulator. I mounted all this to top of tank. From filter/reg I used fuel repair tube from auto zone. Grazed on AN fitting and connected short section of braided stainless fuel line to 3/8 steel fuel line along frame rail. Used another 1 1/2 foot section of braided to connect to fuel rail on engine with russel fitting. Good luck. Jim
Posted via Mobile Device |
#54 |
![]() Join Date: Oct 2011
#55 |
I agree to use the boyd welding EFI tank. What I am going to to is use the non efi tank and cut a hole and drop in a LS1 Fuel pump assembly to save money and use the factory quick disconnects. I get the fuel pump ass. used off ebay for 50$. My intake has a built in FPR so I had to tun a return line back to the tank and ran a generic fuel filter in line that uses quick disconnects.
#56 |
#57 |
Cool. Didn't see what year engine you used. I just got mine running on the Boyd tank about 2 weeks ago. Had been running with a frame mounted pump under driver seat. Took suction from in cab tank with a return from the filter regulator run back to a modified stock sending unit. Kept getting pressure buildup in tank and fumes in cab. Guessing from fuel heating up. New o-ring in sending unit didn't fix it. Like that your AC runs cold. Will be swapping out my condensor when get done with my current job. Appriciate that link.
#58 |
Drove 200 Miles yesterday and got 19.5 mpg. Thats awesome as I was driving 75 mph the entire time.
#59 |
#60 |
I am impressed...keep up the good work...I like
#61 |
Truck and auto performance nut
Better catch that big plastic box on the drivers inner fender....looks like its sliding off!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#62 |
Any more changes, updates or "issues"!!
Thanks for the detailed build.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#63 |
Awesome! I got my lq4 couple of weeks ago...my t56 came in on Monday. I wanted to see if you like the dirty dingo mounts, and do they work with what is on the frame now, or what else do I need? Would you mind posting the link of the ones you got? I noticed that their site does not really show one for just 67-72 trucks.
Also, what intake did you use? Posted via Mobile Device
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
#64 | |
72 C10 - Multicolor, 4.8 ls, NV3500. Sold 72 K5 - Under Construction |
#65 |
this is how I want my swap to be...nice and simple. im gonna use this as my inspiration for my 74. im just concerned about the wiring and fuel system.
#66 |
YES, those two items MUST be addressed, just throw more money at the problem, easy fix !!!
#67 |
awesome build.. im attempting a 2001 5.3 swap into my 67 c10.. just got the complete engine, trans, harness, & ecm today.. im nervous. i hope it goes in as easy as you make it look! lol
#68 |
I've been deployed for the last 5 months and haven't been on the forums. Big update! My truck now has new paint! Baby blue and white. When I get home ill do a step by step how to for a budget fuel system.
#69 |
#70 |
wow!!!! man i am inspired!
#71 |
We used the boyd welding carb tank and simply dropped in a LS1 fuel assembly I got off ebay for 50$
#72 |
#73 |
Very cool build...any new pics of the truck with paint and wheels
#74 |
Here is the latest updates. It will be completed in about 2-3 weeks. Getting all wheel disc brakes and coverted to 5 lug for the new wheels. I am still deployed..When i get back very soon ill help finish it up and drive it from Missouri to new mexico
![]() [ATTACH] |
#75 |
[QUOTE=vannatta20;5956715 I am still deployed..[/QUOTE]
Thank you for your service! ![]() |
