#51 |
Re: Slosh tubz squared ....ready to take orders !
Cool. One less mod they'll need for my application.
#52 |
Garage wrench
Curious.....will the passenger side one clear a stock blower motor?
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
#53 |
67cheby
![]() Join Date: Sep 2008
I don't know, it would be close, I might get one from the parts store and see !
Posted via Mobile Device |
#54 |
i just pulled the trigger on a set for my 73, i will post pics of my install. I will be either cutting down the tub or cut a pocket to clear my hinge
Alex - Dirty AL "One Piece at a Time" Follow me on Instagram alex.barr.ios |
#55 |
67cheby
Smokedat brought it to my attention that we needed a forum member discount ! So $600 shipped to your door for forum members ! Thank you
#56 | |
too bad the front arm isnt reversable (swinging towarth the bulkhead)
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#57 |
67cheby
First 5 sets SOLD, who's next ?
#58 |
Not sure if it has been answered... How large of a wheel will fit under there? If I lay out on a 30" wheel/tire combo will it fit?
#59 |
i think he has that tire under his own truck laying out
#60 |
67cheby
the only way i know to answer this is by you measuring the top of your tire off of this picture ? Does your come up higher then that ?
#61 |
Spear and magic helmet!
#62 |
67cheby
i really think you would probably have to make a pocket in it for it to clear, i apologize i forgot about this, one way to do it would be buy another junk ac box and cut the tubz and mold that part of the extra box into the tubz for clearance....hmm maybe i need to do this !
#63 |
I'll be keeping mine & will relieve + re-glass where required.
#64 |
Would love to see it when you get it done, SCOTI. In the meantime, I'll go attempt to do something with fiberglass.
#65 | |
#66 | |
The dually will utilize taller tires as well as a notched x-member. The x-member will allow greater travel w/o rubbing. More travel + taller OD tires means contact even sooner than before. The additional height of these tubs will eliminate that problem & should only require mild 'tweaking' to clear the OE a/c box & fan motor (I'll might re-locate the accumulator as well).
#67 |
67cheby
Spent Sunday evening building boxes to ship out some SLOSH TUBZ SQUARED this week !! anyone else want in on the $600 FORUM member special ??
#68 |
i like to get them but at a later stage in my build , i want to ship a lot of stuff in one go and prolly will pack it there on the spot in the states before dropping it at the schipper
#69 | |
67cheby
#70 |
Pulled the trigger on a set! Can't wait to have fender wells again!
#71 |
67cheby
GOT IT ! they will ship out next week (hopefully tuesday), usually takes 4-5 days shipping, THANK YOU !
#72 | |
basicly put it on a flat piece of concrete ply make fill some of the corners so they are wide enough to pull the mould off and to alow the cool heat part to be removed with the tub in place , slather the whole thing in wax and celcoat and make a negative mould use that to make the dimple for the actual unit cut a hole in the tub until the piece fits perfect and glass it in from the bottom and sand flat on top that way you can use cellcoat on the outside/ visible side and need to do a lot less sanding
#73 |
PM on the way.
#74 |
67cheby
Scoti, i am picking up your TUBZ on Friday morning you will have them by next Thursday ! sorry of the wait , thanks for understanding !
#75 |
67cheby
Friday i will have 2 extra sets available to ship ! If you are interested let me know ! THANK YOU !
