Old 12-03-2012, 09:48 PM   #51
gdavis
gdavis's Avatar
Re: Roushinator's 72 C10 Stepside Restore/Build
Originally Posted by roushinator View Post
Here is this weekend's work....
New parts waiting in the boxes....
This weekends victims.
I am on grinder number 2 and I can't remember how many wire wheels to clean up all the parts.
gdavis is offline   Reply With Quote
Old 12-03-2012, 10:05 PM   #52
blkcorvair
blkcorvair's Avatar
looking good. I cant tell for sure, But it looks like the motor is sitting on old I6 perches. This pushes it back and can cause fitment issues with headers and make the Dist real tight to the firewall. A set of v-8 perches in the foward holes will correct that. Some leave it alone and like the weight moved further back. Something to look into.
blkcorvair is offline   Reply With Quote
Old 12-17-2012, 11:08 AM   #53
roushinator
roushinator's Avatar
Got some more work done this weekend.
Plasma cutter was a little disappointing. It is a 110/220 unit. I had it hooked up to 110. I am going to try it on 220 next. Should work better. Oh and we did have it connected to a much larger compressor than the one in the picture.
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 12-17-2012, 11:59 AM   #54
roushinator
I will check into that. Thanks.
Ryan...
Old 12-17-2012, 12:03 PM   #55
steelhorse
steelhorse's Avatar
Good job so far. Keep up the hard work and you will be done in no time.
steelhorse is offline   Reply With Quote
Old 12-17-2012, 12:24 PM   #56
roushinator
Thanks. Trying to do something to it every weekend. Trying to build up my skills as i go along. It is a lot of work but after each time i feel like i got something done.
I have a friend that is an expert welder (30+ years) he volunteered to come weld them in. He also is going to fix the rear cross member. I found it has 2" crack in it.
Ryan...
Old 12-17-2012, 02:10 PM   #57
True 67
nice progress.. keep it going..
True
True 67 is offline   Reply With Quote
Old 12-22-2012, 08:31 PM   #58
roushinator
Got more work done today....
Look at these springs!
Ryan...
Old 12-22-2012, 09:16 PM   #59
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I noticed in your first post on this thread that you were asking about the wheels.
I'd bet money they are Prime brand. Super Shops sold a gillion sets of them in the late 80s in the southern part of the country. I even had a set on my mini truck back in the day.
Old 12-24-2012, 08:48 PM   #60
roushinator
Got some work done....
Brakes were toast... Had to beat one side off with a hammer.
New rear crossmember.
40 years of grease and dirt....
Dirt gone......
Ryan...
Old 12-30-2012, 12:34 PM   #61
RCbowtie69
RCbowtie69's Avatar
Looking good on your start of your build.Keep the pictures coming & keep on truckin''
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 12-30-2012, 01:20 PM   #62
Xeen
Xeen's Avatar
Great progress, I am enjoying the frame and suspension work being that my own is requiring a ton of work to make right. I am looking forward to seeing the finished rolling chassis.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 01-06-2013, 08:20 PM   #63
roushinator
Did not rebuild the rear end this weekend. Wanted to wait until my rear brakes came in. I did however get a lot of work done...
Bolted new ECE rear cross member in today.
Old/bent crossmember compared to new ECE crossmember
Drilled holes and bolted in the C Notch kit....
Ryan...
Old 01-06-2013, 08:21 PM   #64
roushinator
Finally got around to mounting my new POL 19 Gal. gas tank.
New best friend. Will never drill metal again with a regular bit.
Ryan...
Old 01-06-2013, 08:52 PM   #65
Zoomin
Man of Mini-Talents
Zoomin's Avatar
You've accomplished a crapton of work. You're about to make the turn where things get more fun.
What route did you decide to go on the cab? Soda blast or ? What's the plan on the front suspension?
Keep up the good work.
Zoomin is offline   Reply With Quote
Old 01-06-2013, 09:09 PM   #66
roushinator
I am not sure about the cab just yet.... Once i get all this done i can roll in the cab and start digging into it again.
For the front suspension i have CPP tubular upper and lower control arms.
Ryan...
Old 01-12-2013, 07:31 PM   #67
roushinator
Got the notches welded in.... They better be in the right spot because they aren't going to move now....
Ryan...
Old 01-12-2013, 07:37 PM   #68
Tx Firefighter
Stick welded with 7018 or am I needing glasses ?
Old 01-12-2013, 08:42 PM   #69
roushinator
The axle c notches were stick welded in using 2 different rods. I can't remember the numbers.
Ryan...
Old 01-12-2013, 08:44 PM   #70
Tx Firefighter
Looks like 7018 rod. Its nice to see someone who still has the skill to burn rods as well as pull the trigger on a MIG gun.
Old 01-12-2013, 08:49 PM   #71
roushinator
I cant take credit for that. My friend welded it up for me. He is one of the best.
Ryan...
Old 01-12-2013, 10:09 PM   #72
Ghostryder79
Dirt gone......
[/QUOTE]
Ok. I'm having ISSUES with this...how'd you get the 40 years of grime off of there?
2007 VW GTI - SOLD, 2013 Ram 1500 Crew Cab Hemi 4x4 - TRADED (POS), 2006 Silverado 2500 Dirtymax, 2010 Kawasaki ZX-10R (wrecked), 2006 SV650, 2015 ZX-6R
1968 C10 CST LWB
"..... Long beds are like the slightly chubbier sisters to the hot chick, still cute with a lot more to like. hahahaha!" - OrtegaMotor
Ghostryder79 is offline   Reply With Quote
Old 01-12-2013, 10:32 PM   #73
roushinator
Marine Clean and a wire brush and about 3 hours
Ryan...
Old 01-12-2013, 11:53 PM   #74
Ghostryder79
Well alrighty then. Time to push the elbow grease a bit more.
1968 C10 CST LWB
Old 01-13-2013, 07:29 AM   #75
Tx Firefighter
Dirt gone......
Ok. I'm having ISSUES with this...how'd you get the 40 years of grime off of there?[/QUOTE]
I don't know if you have the work environment that can support it, but if you have a "dirty" area where you can work, I can tell you an excellent way.
Put the parts on sawhorses and coat them liberally with dollar store cheap oven cleaner. Let it sit 15 minutes or so then respray it with another coat. After another few minutes, hose it off with a garden hose. On real nasty stuff like that rearend, you will probably need to let it dry and repeat the oven cleaner deal again. Perhaps a few times, but it will get it clean. This method is cheap and easy, as long as you have patience to walk by it every so often and spray it again and wait for the chemical to do the work for you.
