Old 02-25-2013, 09:38 PM   #51
Daniellane
Re: 1991 1 Ton Crew Cab 4x4 Build
shortbed it. paint it pearl white. paint the bumpers white. tint the windows. or wait thats what i would do with this nice truck
Daniellane is offline   Reply With Quote
Old 02-25-2013, 11:54 PM   #52
91V3500
lol thanks, I thought about making it a shortbed but I think I'll leave it a longbed for now. Maybe the next project - 2wd shortbed crew.........hmmmmm
91V3500 is offline   Reply With Quote
Old 02-27-2013, 11:06 PM   #53
arttarango
I also have a 3500 crew cab 4x4 truck and it is in original condition, but the computer was stolen from it. I have been searching for a complete computer for 3 years with no luck!! Can anyone please help???
Thanks,
Arturo Tarango
915-731-6953
arttarango@hotmail.com
arttarango is offline   Reply With Quote
Old 02-28-2013, 12:27 AM   #54
Devillusion
Devillusion's Avatar
Thanks,
Arturo Tarango
915-731-6953
computer for a tbi crew? what specs? what number on the computer? shouldn't be that hard to find?
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 03-02-2013, 11:56 PM   #55
91V3500
Started working on the rear of the frame today. Being at the beach and having a salt spreader on this truck for the last 6 years have really taken their toll on the frame but it's still structurely sound. I got the rivets out of the rear spring brackets so they can be removed to install the shackle flip kit. While the bed is off I plan to sandblast and paint the frame, install the 2nd fuel tank, and paint the back of the cab and front of the bed.
Old 03-08-2013, 10:49 PM   #56
91V3500
I finally started taking my "new" bed apart so I can get it home and start cleaning it up. I picked this up for $300 and while it's not perfect, it's in a lot better shape than what I had.
Old 03-15-2013, 07:33 PM   #57
91V3500
I have my Off Road Design shackle flip kit bracket installed. Now I have to cut the leaf spring perches and shock mounts off of the 14 bolt rearend. The perches have to be moved inward 1" per side. The 3/4 ton trucks had the perches mounted 1" further out than on the 1 ton trucks. I ordered new perches from DIY4X.com and a rear disc brake conversion kit.
Old 04-01-2013, 11:02 AM   #58
91V3500
I'm going with disk brakes on the rear, I have the brackets and the rotors, and it's time to order the calipers. The auto store needs to know if it's JB6, JD6, JB7, or JD7. The "JD" are for the hydroboost system, which is what I have, and I believe the "6" have a lower stopping power rating than the "7". Should I get the JB or the JD and should I get the 7 for the front and the 6 for the rear?
Old 04-14-2013, 01:55 PM   #59
91V3500
Well, thanks for all of the help! For future reference, I went with the JB6 for the rear and will replace the front calipers with the JB7. Hopefully this setup will not require another proportioning valve because the JB7 takes more fluid than the JB6. I ordered steel-braided brake lines from OffRoad Design that runs from the brake block on the rear over to each caliper. They should be here this week so I can finish up the disk brake install and drive the truck over to the sand blaster.
Old 04-17-2013, 09:58 PM   #60
91V3500
Nothing exciting happening. I just picked the truck up today from the sandblaster. They only charged $120 to blast the rear of the frame from the cab - back.
Old 04-18-2013, 02:10 AM   #61
bohmankid
bohmankid's Avatar
Man I really like those tires. I'd love the wheels if all chrome! That's just me.
I'd that rear shackle flip ORD? How many inches?
bohmankid is offline   Reply With Quote
Old 04-18-2013, 02:25 AM   #62
y5mgisi
Second Chance Program
y5mgisi's Avatar
Good call on getting the frame blasted!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 04-18-2013, 03:11 PM   #63
91V3500
Isn't that rear shackle flip ORD? How many inches?
Thanks, I wanted chrome but I got a really good deal on the black, plus the chrome on the KMC wheels is cheap.
The rear shackle flip is ORD, mine is the 2.5" with a 6" shackle, supposedly gives 4" total lift. ORD said not to run a 4" shackle flip kit with 8" lift springs.
Old 04-18-2013, 03:25 PM   #64
91V3500
Yeah, I played around with a grinder and a wire brush to try to remove some of the rust, I wanted to do it myself because I didn't want to drive it the ten miles to the blaster with no taillights, and I can't tow it with these wheels because it won't fit on my trailer anymore lol. But I ended up driving it like it is, and blasting it was definately the way to go. It turned out better than I expected. I know a full frame-off resto would be better, but I don't have the time or space for all of that right now, and I need to get this truck back on the road ASAP and keep it drivable while I continue to work on it.
Old 04-19-2013, 01:18 AM   #65
Truck Guy99
Do you need seatbelts still? Go to seatbeltsplus.com. Also check out cupholdersplus.com. Let me know if this helps! BTW, WICKED truck man!
My names Tye. No Chevy right now
Truck Guy99 is offline   Reply With Quote
Old 04-19-2013, 08:59 AM   #66
91V3500
Thanks, I do still need seatbelts. I found some webbing on Ebay for about $25 per roll but I'm a little nervous about it. I'll check out your links!
Old 04-29-2013, 10:41 PM   #67
91V3500
I ordered a sample of "torch red" colored seatbelt from seatbeltsplus.com, it matches perfectly! I'm gonna order enough to do all of the seatbelts. Thanks for the link!
Old 04-29-2013, 10:50 PM   #68
91V3500
Got some paint on the frame from the cab-back. Started putting the rear disk brakes on tonight. I've never worked on one until now, but it's so easy to work on this 14 bolt full floater I think everything I own from now on will get one! I think I have about $400 total in the rear disk brake kit. That's with all new calipers, rotors, pads, and stainless steel braided brake lines from ORD. Try that on any other axle.
Old 04-29-2013, 11:05 PM   #69
AntiGov
AntiGov's Avatar
looking good man....
88 3+3 454 400 205 410 drw to srw still in pieces
90 3+3 350 400 205 410 srw
84 1/2 ton lb 6.2 4x4 parts truck
AntiGov is offline   Reply With Quote
Old 04-30-2013, 12:05 AM   #70
Truck Guy99
Glad I was to be of help! Now about that finders fee.........
Old 04-30-2013, 09:02 AM   #71
91V3500
Just send me a bill lol!
Old 04-30-2013, 09:33 PM   #72
91V3500
1000 lb drums are gone!
Old 05-12-2013, 10:04 PM   #73
91V3500
With this wheel/brake combo I can change the brake pads without removing the wheels lol!
It took me all week, but i got the brake lines finished up and the lines bled. Brakes work great! I also sanded the back of the cab to get it ready for some paint.
Old 05-22-2013, 09:17 PM   #74
Mr. 250r
Mr. 250r's Avatar
Just wondering if your new perches were 3 hole or not since the shackle flip moves the axle forward you could've used the front perch hole to put it back in the stock location, personally i can't stand when axles are moved forward or backwards lol but just preference but its really nice truck so it doesn't matter
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 05-22-2013, 10:24 PM   #75
91V3500
Thanks, yeah the spring perches were 3 hole, I did use the holes that move the axle back, hopefully it's right, it's centered with the rubber bumpstops, I'll find out when I get the bed back on. I can't stand it when the tire is not center either lol!
