#51 | |
![]() Join Date: Nov 2013
Re: 5.3 swap 68 Stepside C10-Project Sky Dogggg maannnnn
#52 |
It's been kinda cold lately though
![]() Did the grinding on the firewall tonight. I also built the most bobo bodywork "booth" in my garage using 1" pvc. This looks horrendous right now, but hopefully will be pretty soon! This will be my first time doing bodywork. The plan is to do the bodywork and priming in the bobo booth and then take it to a neighbor's collision shop to do the real painting. ![]() ![]()
68 SWB 5.3 turbo build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578220 |
#53 |
Some guys have never done this......I have done so many car restorations I wore myself out but you got me re-energized....I just hope not too much!
![]() THIS WAS MY LAST PROJECT.A TWIN TURBO CAMARO.....5 YEARS |
#54 | |
Still Learning
#55 | ||
Glad I could be a bad influence! Go get after it! Quote:
I looked into southern polyurethanes, and I think I'll be putting an order in this week for some material.
#56 | |
#57 | |
#58 | |
#59 |
What color is that?? Is it seafoam green or Daphne blue? God that's beautiful.
That Camaro is nuts, and you're a bad influence making me want to build one of those. I can just feel my wallet lightening. ![]() Do you ever go to the Daytona rod runs?
#60 |
I just moved to Florida.........so no I have not...We dont like Vero Beach so I might move to another part of the state......This is another car I built....its on you tube........twin turbo in a 66 nova wagon and also an I6 Turbo in the same wagon.........I liked the 6 better
#61 |
Sea foam green........
#62 |
Here is the wagon.....The 6 cyl was making 1400 HP but it was real fast accelerating because it was a 4 valve and would rev to 10,000 quite easy. I had to be careful with it as the shift points even on the street were 9500 rpm.....no pushrods and no lift.......I used a motorcycle valve spring...This engine would out accelerate my V8 to 60 MPH......about 2 seconds even on the street. V8 was closer to 3 seconds to 60 mph.
#63 | |
Still Learning
Since you'll probably be doing all your panels inside and out it will take much more material. I have already used over 4 gallons of material on my current project but every surface is coated with epoxy and most with high build. I also bought 2 gallons of base and 3.5 gallons of clear. It's easy to spend over a budget if you're not careful. It really depends on what you want as your finished paint job. You can get a nice driver quality paint job relatively cheap. I have also read good things about SPI. They have good prices on epoxy primer. |
#64 |
Fuel cell went in the other day, and am still working on finishing the frame up. Got finished building the bobo booth, and got the primer ordered. Also finished up the sheet metal order tonight.
Got a lot of the cab gutted, and need to clean the rest, then start more dirty work. Got a shop lined up to do the paint. Looking into the turbo setup this week. The next few weeks are going to let me know if I can finish this thing by the end of March for the Daytona rod run. ![]() ![]() ![]() ![]()
#65 |
Location: Santa Barbara, California/Tuscaloosa, Alabama
Great looking truck, looking forward to seeing more progress!
#66 |
Well, haven't updated in a while. Ended up tearing my shoulder, just as all these goodies arrived! Due to get a cortisone shot next week. Hopefully that'll last me through the bodywork
![]() Anyway, the turbo, most of the piping, the fuel setup, primers, body parts, high hump. Still waiting on the cam, the rest of the piping, the intercooler, and headers need to get here. The turbo is a GT45 ebay special that everyone keeps giving high marks to. I'll take it apart tomorrow to make sure it's all clean. Either way, it beats the heck out of the old turbo I had that was smaller, and gouged inside. Expect to run about 10 psi, and 500+whp. Not big on numbers, but that's what it'll end up around. Wanted the high hump because I will be needing a 4l80 sooner than later. And yes, that's an entire room of my house dedicated to truck parts. I'm lucky in the way that's it's just me and the dog, and he doesn't do any *****ing ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#67 |
Sweet build. That hair dryer ought to make that truck move on out.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
#68 |
More goodies came in today!
Cam, springs, pushrods, retainers, etc. ![]() ![]() Also did a little work on a fender to see how it would go. The best combination seemed to be an angle grinder with a wire wheel to strip the paint, followed by a DA with 80 grit to clean/scratch it for primer. I'm still going to get the cab and bed blasted, because they're just way too much surface area. The left side in the picture is after the DA, the right side is just the wire wheel. ![]()
#69 |
Long day today, but some good results. Got all the hot side piping done except for the downpipe. The piping was from a Lincoln Mark 8 exhaust kit. Still need to clean some things up, but the dimensions are there at least.
![]() Also, I've been stripping the paint using a heat gun and razor scraper. Works really well. Should take way less time to sand the rest. ![]() ![]()
#70 |
Re: 5.3 Turbo swap 68 Stepside C10-Project Sky Dogggg maannnnn
I was thinking about using the heat gun method, but I was worried it would warp the panels. Do you think it's safe?? Nice work on the exhaust, BTW.
#71 |
I wouldn't leave it on there until the paint bubbles, but I don't think it'll do much to thicker gauge original steel unless you really roast it. In my case I had 6 layers of paint and primer, so it was a little thicker than normal. replace the razor blade often and it comes off effortlessly.
I really don't like the pipe coming from drivers side of the flex pipe, so I'm going to change it this week. Also need to mount the wastegate at a little smoother of an angle.
#72 |
Still Learning
Congrats on the turbo acquisition! Looks like you are knocking out the plumbing. Looks good. How much did the kit set you back if you don't mind? I'd like to add one to my little 4.8.
#73 |
I bought the kit from this guy, and cut up the pieces I needed. My suggestion is to go get a chop saw, because a sawzall and angle grinder is not the best route for cutting
![]() Everything on the hot side is getting wrapped, so it doesn't need to be gorgeous, but I do need to fix that one pipe next to the flex and then grind the welds smooth. The cold side piping will be tig welded because they do need to be pretty. http://www.ebay.com/itm/93-98-Lincol...8b66a1&vxp=mtr
#74 |
Well I didn't like the way the manifolds ended up, so I re-did them. Much better this time around. Now just need to clean up the welds and wrap them. I have really been slacking ass lately, I need to step it up!
![]() Also got the cam and the valve springs done. Took about 5 hours. Man, someone needs to invent a faster spring tool! ![]()
#75 |
What kind of Fuel cell is that? what are the measurment, It look like it fits well.
Stay blessed not Stressed! |
