Old 10-28-2013, 03:25 PM   #51
marvgarr68
marvgarr68's Avatar
Re: 68 c10 6.5 turbo diesel
Here are the update pictures. Back of cab and front of bed painted under bed undercoated. Hard line fuel lines AN fittings 1/2" suction 3/8" return bulkhead through floor. Parking brake cables and guides all new.
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
Old 10-28-2013, 03:28 PM   #52
marvgarr68
marvgarr68's Avatar
Pics of the fuel lines
Old 10-28-2013, 03:31 PM   #53
marvgarr68
marvgarr68's Avatar
More pics of fuel lines. I have not finished 1/2" line to fuel pump yet will post pics of that set up when done.
Old 11-23-2013, 07:04 PM   #54
marvgarr68
marvgarr68's Avatar
Got most of the fuel lines done fuel filter housing and lift pump mounted. Got gauge cluster painted and put in a volt gauge got ride of amp gauge. The alt is a 140 amp that would burn the factory shunt wire. I made new wiring harness for the engine and installed a high amp dist block. I made a new front wiring harness also I am still waiting for a fuel sending unit from a 72.
Old 11-23-2013, 07:08 PM   #55
marvgarr68
marvgarr68's Avatar
More pics it is raining here a lot so some got wet.
Old 11-24-2013, 03:03 PM   #56
67_C-30
I have a radical idea!
67_C-30's Avatar
You are doing a real nice job on that truck!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 11-24-2013, 06:53 PM   #57
marvgarr68
marvgarr68's Avatar
Thanks I appreciate the compliment.
Old 12-24-2013, 01:36 AM   #58
marvgarr68
marvgarr68's Avatar
Update pics painted inside of fenders. Painted core support and installed cowl panel. I have finished all the corner supports and lower splash panel have all that painted today. I will post pics of that tomarrow I will also be painting the hood.
Old 01-13-2014, 01:11 AM   #59
marvgarr68
marvgarr68's Avatar
Update I got inside painted top of dash painted right door sill/pillar painted. I got grill and hood painted and installed. New cowl seal and cowl installed all body tightened down and aligned. Fuel lines almost done just need 90 deg AN coupler. I resealed drip rail got all rust out of it also. I need to fix sill on left side and paint it.
Old 01-13-2014, 01:19 AM   #60
marvgarr68
marvgarr68's Avatar
More pics
Old 01-13-2014, 01:22 AM   #61
marvgarr68
marvgarr68's Avatar
Some more
Old 01-16-2014, 08:02 PM   #62
marvgarr68
marvgarr68's Avatar
More update got door seals and tail light lenses. Got AN 90 deg couplers for fuel line fuel line is done. Main bearings are in the mail.
Old 01-22-2014, 10:18 PM   #63
marvgarr68
marvgarr68's Avatar
started on the motor
Old 01-23-2014, 09:56 PM   #64
marvgarr68
marvgarr68's Avatar
All inside is painted everything doors, sills, pillars, everything done. Got latches, window regulators, striker plates painted.
Old 01-24-2014, 03:51 PM   #65
superduty_59
Love it! I like your pics, keep'em coming. I'm a diesel technician. I like the 6.5's but the one in my 97 4x4 crew dually is sickly. I would like to swap a mechanical pump in but after I factor in the cost of that and everything else, I think I'm going to swap in a 12v instead. I do like your idea of a mechanical 6.5 in your 68. It's different and you will like the fuel mileage.
superduty_59 is offline   Reply With Quote
Old 01-24-2014, 04:18 PM   #66
superduty_59
Also what made you want to keep the fuel tank in the cab? Most use a blazer tank under the rear of the bed.
Old 01-24-2014, 10:36 PM   #67
marvgarr68
marvgarr68's Avatar
To keep it original. Plus I like filling up the tank from sitting inside lol. It easy to swap mech pump on 6.5. The other way is hard. All you need is a 90s pump a 93 is the best if it a 4911. Get pump and lines and that's it hook up one wire and done make sure throttle bracket is on pump.
Old 01-24-2014, 10:37 PM   #68
marvgarr68
marvgarr68's Avatar
Also thanks for the kind words that is what I'm going for original but different.
Old 01-30-2014, 06:45 PM   #69
marvgarr68
marvgarr68's Avatar
Motor coming together.
Old 01-30-2014, 06:47 PM   #70
marvgarr68
marvgarr68's Avatar
More pics all brackets and parts are painted.
Old 01-30-2014, 06:58 PM   #71
superduty_59
Engine pics look nice. Coming right along!
Old 01-30-2014, 08:21 PM   #72
marvgarr68
marvgarr68's Avatar
Old 02-02-2014, 06:43 PM   #73
dieseldude4bt
I don't know how I missed this thread, your doing great work keep it up
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 02-02-2014, 07:08 PM   #74
marvgarr68
marvgarr68's Avatar
Thanks I don't have much of an update just been painting all the small stuff. When the wind stops I will be putting the back window in.
Old 02-06-2014, 06:33 PM   #75
dieseltech
Looking forward to more updates. Great build!!
1986 Chevy Wrangler 4x4
305/700r4
6" lift
37x14.50x15
dieseltech is offline   Reply With Quote
