Old 10-10-2018, 08:19 PM   #51
nlped
nlped's Avatar
Re: Extreme or Mild Dropmember
Yeah, so!!!, the longtube chevelle headers don’t fit for $h!t. The motor seems to sit to low in the frame to clear the PB engine mounts (dropmember side, not the ones on the motor), and the back of the PB lower control arms. I’m going to email Nate and see if raising the engine a touch might fix my problem. Looking at the referred to thread, mine hang lower than Adam’s (BossHogg1969) appear too. I’m going to do some adjusting on my next off day and see what I can figure out. Maybe between Nate and some tweaking, I can make theses work...’cause they are purty.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 10-12-2018, 08:16 PM   #52
nlped
nlped's Avatar
After measuring and tweaking, I think my motor is at least 3/4” lower than the stock BBC location. I can’t even use a set of stock cast iron manifolds as it sits...
Carter
Old 10-13-2018, 04:06 PM   #53
gringoloco
A guy with a truck
gringoloco's Avatar
Whoa, that’s no bueno. Are you sure you don’t have the SBC mounts? Definitely get with PB and see what they say.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-13-2018, 05:15 PM   #54
nlped
nlped's Avatar
That's exactly what I think the problem is, but I can't get anyone from PB to confirm that the BBC mounts are taller than the SBC mounts... I know the stock mounts certainly raise the mounting location between the 2.
Carter
