#51 |
Re: 1965, L6 292 Engine Power Steering Pump Set-Up
Im still looking for this setup ps brackets ........... ..
#52 |
![]() Join Date: Oct 2013
Mike,
Ebay is a good source, need to be sure it is the correct one, lots of people do not know what a correct one is. They are not cheap. Good luck. Les |
#53 |
Yes I know I found one for a 235 but its no use to me im not trying to pay an arm and a leg for one but I may have to
#54 | |
ron |
#55 |
Its in the junk yard at a pull your part ill go back and pull it off should I get take the pump as well?
#56 | |
if not just list it on here where the junk yard is thanks ron |
#57 |
I'll go pick it up tomorrow maybe someone else could use it... how much should I ask for it?
#58 |
i would say it would be equal to what one would pay for a 292 one would be. you have to be a member to sell it on here though.ebay is a place to sell it or c/l
ron |
#59 |
Ok its gos to a 250 in line 6 cylinder I also got the a/c brackets what's the guys name on here that might know of someone looking for these setups and how do I search for him on here im new to this site...thanks mikke
#60 | |
get a membership for here to place an ad in parts for sale or list on ebay or c/l I did send you a PM (private messages)yesterday top right of the page where you sign in ron |
#61 |
Many years ago I had put PS on a 68 with a 250. Got the pump and bracket off one vehicle and box from another. No issues that I can remember.
Now the brackets are getting as rare as hens teeth.This time on the 66 I had a double pulley on the crank. Put a double pulley on the water pump. Rear belt stayed unchanged from crank to water pump to alternator. Front belt from crank to water pump to steering pump. Had to cut down and modify an elaborate bracket from an 85 Buick IIRC which had the adjustment slot. |
#62 |
![]() Join Date: Nov 2013
corvetts 65-72 power steering pulley is same as 292 chevy c/k 10 G.M. # 3834720 .and they have a remake off set for around 28.00 cp#38810
#63 |
![]() Join Date: Jul 2015
Planning the power steering conversion for my 1963 C20, with a cross member from a 1974 C20.
Should I order a pump/pulley from a 63 C20 or from a 74 C20 (inline six 292). Not sure if the 292 in my truck is the original motor. And, is it better to have the pump without the reservoir? Any advantages here?
1963 C20, small window, long bed 292, 4-speed |
#64 |
I just picked up a PS bracket from Davis Speed Equipment. It’s not OEM, but is high quality, 1/4 steel and includes hardware and clear instructions. He’s got variants for different positioning of the pump and alternator and low profile and a few others. For me it was well worth the $143 for model 10003. There are also new brackets for A/C units. Great service and excellent phone help. 608-469-4927. Good luck.
#65 | |
Question on the pump - does your pump have the stud at the 5 o’clock position? I have been trying to find the correct pump, and I am just not sure which one I should purchase. Some of the pumps on Rock Auto do not have that stud, or it’s at the top of the pump. Did you buy your PS pump recently, or did it come with your truck? Any chance you have a part number? I wonder if the PS pumps from other cars would work, like from a Nova or Camaro.
#66 |
Is there a hydro boost setup that connects the power steering to the brake vacuum booster? A parts guy mentioned that to me on the phone.
Is that a required setup for these trucks? Don’t you need an extra connection on the PS pump for this?
#67 |
Post Whore
![]() ![]() Join Date: May 2015
hydroboost doesnt connect to a vacuum booster...it is the booster..no vacuum needed
ive seen people run the bypass line from the booster to a T in the steering box return line line...but ive heard some complaints about cavitation issues , and some have no isuues... a true hydroboost pump has 2 return line fittings..one for the booster and one for the steering
#68 | |
#69 |
Post Whore
this is a hydroboost...it replaces the vacuum booster
the pressure line from the pump goes to the hydroboost...and then to the steering box...from the steering box back to the reservoir...there is also a return line from the booster itself that goes back to the reservoir,,, most use a inline cooler on them as well in the return line between the steering box and the reservoir
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-13-2021 at 11:03 PM. |
#70 |
Post Whore
heres a pic of the hose setup..i didn't have the return from the hydro hooked up in this pic so I drew it in red
the blue arrows point to the lines going to the cooler
#71 | |
So, I take it, if I buy this PS pump, I will not need to worry about this so-called ‘hydro-boost’. https://www.rockauto.com/en/cart/
#72 |
Post Whore
not sure what pump is in your link...the page is empty...but if you get a reg ps pump youll be fine....ive even seen hydroboost pumps used with no hb and with the extra return port plugged off and unused
#73 |
Maybe the link was bad.
#74 |
Post Whore
that pump has one pressure line and one return line...so thats good for you..wether itll fit your truck , i havnt a clue
#75 |
Can anyone confirm - can I remove this stud and use a bolt in its place?
I cannot get the bracket on there. That stud bolts into the pump; I’m just worried about getting it to seal and not leak.
