Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 04-27-2014, 07:34 PM   #51
mud.man.rj
mud.man.rj's Avatar
Re: 70 GMC 4wd version
I was trying to remember as it was a few years ago on my 71 4wd that I pulled the small block and dropped in a 454 and just had to use big block mounts as they were a bit taller and still ran the big distrib, but you never know what someone else does to modify something before you get it. The frame mod is easy if you can weld.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 05-11-2014, 04:23 PM   #52
70stroker
70stroker's Avatar
Got the 396 66 chevelle oil pan on and it solved my problems. For anyone who looks at this thread later down the road, I used stock sbc motor mounts that came with the frame, and a 396 66 oil pan with no trouble, i have about 1/4 inch of clearance. I did move the stock crossmember forward 2 inches to help with any firewall clearance i might have also so i can use a factory square body front driveshaft.
Starting to make forward progress. Also the boyd welding fuel tank came in.
70stroker is offline   Reply With Quote
Old 05-12-2014, 07:01 PM   #53
mud.man.rj
mud.man.rj's Avatar
Nice to see the car pan worked out for you.
5.0 4spd std.
7" lift w 35's.
Old 05-12-2014, 10:04 PM   #54
Ozzy2013
Ozzy2013's Avatar
Originally Posted by 70stroker View Post
thanks for all the kind words guys. i dont really need the capabilities of the 4wd because i have my 05 crew cab for that, however as of right now i have put 400 miles on the orange truck in the last 5 years, mainly because i dont really enjoy a lowered rig anymore. i enjoy 4wd so much more then i ever did a 2wd, so thats my reasoning on that.
also yes it would make sense to sell the orange truck and just buy a body, which this frame had untill i offered to just buy the frame not the whole truck. my reason for using the body of the orange truck is because that was my highschool truck. i have alot of great memories in that thing, now that i have two young ones i would like to make more memories in it, i am hoping it now being so low to the ground will bring the love back for the truck i once had.
not to mention the orange truck was a original 4wd cab, that someone swapped to the 2wd frame well before i ever got it, so my title has always said 2wd anyhow.
Im doing the same thing got to love the Monday morning quarter backs .Why are you doing it ?I would do it like this or that .Dude its yours and thats what you want is the only why that matters .My truck has a lot of sentimental value too and the body wont take months of body work.Cant wait to see yours done !
Ozzy2013 is offline   Reply With Quote
Old 05-13-2014, 01:24 PM   #55
cmabolt
cmabolt's Avatar
Lookin good keep cranking. Frame turned out terrific. The boys tanks are very nice! Good choice.
Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636
Easier to beg forgiveness than ask permission!
cmabolt is offline   Reply With Quote
Old 08-31-2014, 04:48 PM   #56
70stroker
70stroker's Avatar
Its been awhile guys, I have been busy putting 1 ton axles in my wheeler an 78 dodge power wagon. But im back it it now. Yesterday I got my trans crossmember modified to work with the 241 transfer case so the front shaft wont hit now. Today I tore apart the front shaft and installed new u joints, and also finally cut my plug wires to length and crimped on the ends, man that was the first time I built my own wires and what a pain in the rear.
On a side nit can someone post a pic of how the front u joint attaches to the dana 44 yoke. Is it u bolt straps or is it strapswith bolts. Thanks in advance
Old 09-01-2014, 02:38 AM   #57
mud.man.rj
mud.man.rj's Avatar
Depends on your diff, one is threaded for the bolts and straps, the othere yoke isn't threaded so the u bolt will pass rt threw. Just have a look to see if threaded or not to see the type.
Old 09-01-2014, 12:58 PM   #58
Ozzy2013
Ozzy2013's Avatar
What kind of trans crossmember are you using?
Old 09-01-2014, 01:46 PM   #59
70stroker
70stroker's Avatar
Alright ill take a look. Its the factory crossmember.
Old 09-01-2014, 02:50 PM   #60
Ozzy2013
Ozzy2013's Avatar
So if i cut the rivets that hold the factory bell housing crossmember thats what you are using for a transmission crossmember?
Old 09-01-2014, 04:13 PM   #61
70stroker
70stroker's Avatar
Bell hosuing crossmember? Do you have a pic
Old 09-01-2014, 04:24 PM   #62
BigRed76
BigRed76's Avatar
The crossmember he is using is the factory auto trans/4 speed crossmember. The bellhousing crossmembers were only for the three-on-the-tree trucks.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 09-01-2014, 04:25 PM   #63
70stroker
70stroker's Avatar
If you look in post 40 my crossmember was silver in those pics
Old 09-01-2014, 11:44 PM   #64
Ozzy2013
Ozzy2013's Avatar
Thanks ill look for a crossmember from and auto or manual 4 speed truck thanks!
Old 09-07-2014, 04:32 PM   #65
70stroker
70stroker's Avatar
Well today i got the rear ends swapped out......... sorta. I guess the 2 and 4wd spring perch width is different? Csn anyone verify this? i managed to get the 4wd one in the 2wd frame by ratchet strapping the springs closer together, which is fine because its going to scrap once i get the body off, however i wantto do the 4wd correctly.
So i started to grind off all the old perches and bump stop brackets on my 2wd axle. Got about half way then it started to rain so i had to pull the corvette in, and i wasnt about to grind right next to it.
So few questions.
2wd vs 4wd spring perch width, different or did the po just screw up mine when he did his homemade axle flip?
Where can i buy spring perches to weld on?
What should the pinion angle be when i weld on my new perches?
Anyone know where i can buy and angle gauge to determine pinion angle? Link?
Thanks in advance
Old 09-07-2014, 04:35 PM   #66
70stroker
70stroker's Avatar
Heres a few pics from today.
Disc brake brackets from captainfab.
Old 09-07-2014, 07:23 PM   #67
BigRed76
BigRed76's Avatar
The spring perches on 2WD vs. 4WD are different. I think the 4WD perch width is like 40" where the 2WD is like 42 1/2" or something. I ran into this a while back on my 4wd build. As far as the pinion angle I measured mine while it was bolted up to the springs before I cut the perches off. Then I bolted the axle up with new perches, centered the axle, set the pinion angle, then welded them onto the axle. I bought a magnetic angle gauge from harbor freight and it works just fine.
Zach
Old 09-07-2014, 10:20 PM   #68
cmabolt
cmabolt's Avatar
4x4 = 40.5" spring perch. Swapped my 72 Ho52 for a Dana60 from 71. Bolted right up.
Chris
Old 09-08-2014, 06:04 AM   #69
70stroker
70stroker's Avatar
Chris
Awesome guys so i d 4x4 is 40.5 can anyone confirm what 2wd are, so i can take the difference and move them that much. Its hard to get an accurate measurement with the pumpkin in the way
Old 09-10-2014, 10:46 PM   #70
70stroker
70stroker's Avatar
Does anyone with a 4x4 rear mind take a tape measure to there diff for me? I need a measurement of where the tube slides into the pumpkinout to the center pin of the leaf perch.
Old 09-10-2014, 11:07 PM   #71
cmabolt
cmabolt's Avatar
I'll get you a measurement tomorrow.
Chris
Old 09-11-2014, 08:15 AM   #72
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
From where the tube slides into the pumpkin to the middle of spring perch is right at 12". Hope this helps. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 09-11-2014, 09:34 AM   #73
cmabolt
cmabolt's Avatar
Sent you a pm with measurements
Old 09-14-2014, 12:15 AM   #74
70stroker
70stroker's Avatar
Got the new perches tacked in and test fitted, tomorrow ill pull it clean it and paint it, providing i can figure out what im gonna do with shock mounts
Also seen this truck this weekend, way to tall for my liking, but still a nice looking truck
Old 09-14-2014, 02:11 PM   #75
mud.man.rj
mud.man.rj's Avatar
The silver/black Chevy is nice, what style shocks are you going with, factory or something else.
