Old 04-25-2015, 06:59 PM   #51
silverbear
silverbear's Avatar
Re: 86 K10 LWB - Frankie
I was only able to finish up the passenger door panel before a rain storm rolled in.
After.
In the truck with the dash.
86 Chevrolet K10 350/SM465 Frankie SOLD
1995 GMC Yukon GT SOLD
1996 GMC Yukon GT
2010 Suburban 1500 4x4 5.3l/6L80e. Sold
2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e
silverbear is offline   Reply With Quote
Old 04-25-2015, 07:01 PM   #52
silverbear
silverbear's Avatar
Kick panels and A piller trim.
1996 GMC Yukon GT
Old 04-29-2015, 10:47 PM   #53
Greenlee
Greenlee's Avatar
Nice work! The dash and carbon fiber look great.
Greenlee is offline   Reply With Quote
Old 04-30-2015, 11:55 AM   #54
silverbear
silverbear's Avatar
Thanks!
1996 GMC Yukon GT
Old 05-14-2015, 08:27 AM   #55
silverbear
silverbear's Avatar
Got some more work completed on the interior this past weekend.
A big THANKS to BGOOD70 for spraying some clear coat on my glove compartment door and ashtray assembly. I will attempt to get those parts installed this coming weekend.
1996 GMC Yukon GT
Old 05-28-2015, 06:24 PM   #56
silverbear
silverbear's Avatar
A few more interior details. I got the ash tray assembly and glove box installed. I started the detail work on the door panels. The goal is to have the upper portion os the door panels match the passenger side trim of the dash.
1996 GMC Yukon GT
Old 05-28-2015, 07:25 PM   #57
y5mgisi
Second Chance Program
y5mgisi's Avatar
Looks nice!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 05-28-2015, 07:27 PM   #58
silverbear
silverbear's Avatar
Originally Posted by y5mgisi View Post
Looks nice!
Thanks.
1996 GMC Yukon GT
Old 05-29-2015, 08:05 AM   #59
bgood70
bgood70's Avatar
Looking real good Chris.
bgood70 is offline   Reply With Quote
Old 11-16-2015, 10:56 AM   #60
silverbear
silverbear's Avatar
So about 6 months ago I discovered a crack in the radiator tank. I don't drive this long distances so I made due for a couple of months. I found a good deal on a new aluminum radiator so I picked it up about 3 months ago. Since I am upgrading the A/C, I also picked up a parallel high flow condenser. Both of those items sat in my garage for 3 months because I have been sooooo busy helping out others that I didn't have time to work on my own projects. So this past Saturday I decided it was time.
Empty core support.
Condenser mounted. Still need to work out the lines for this but that will be another day.
The radiator mounted. Need to reroute one heater hoes and fab up some mounts for the fan shroud.
Size:  47.1 KBName:  20151114_152925.jpg
1996 GMC Yukon GT
Old 01-20-2016, 07:54 PM   #61
silverbear
silverbear's Avatar
Well like most of my projects for this truck... something does not go as well I as I was hoping for and then the time line gets extended or in this case, one of the old parts gets damaged and then I have to get MUCH deeper into my pockets to fix it. In the process of modifying the fan shroud to work with the new radiator, I managed to run a bolt right through the tank on the brand new radiator. So I had to pull it back out and take it to get welded back up. Got that back in and mocked up my new heater hoses and then had to wait a few days for the pipes I wanted to get bent for me. I am not set up to bend 5/8" and 3/4" stainless steel tubing. I got those back and installed and then found a crack in the old intake manifold. So now I guess since the intake has to come out, I will address my oil leaks. Intake is getting replaced. Valve covers getting cleaning, refinished and new gaskets. Oil pan getting cleaned, painted and new gasket. After all of that with a little help Bgood70 got the timing and the carb fine tuned and now Frankie is running smooth.
Here are a few pics of what i was trying to do.
1996 GMC Yukon GT
Old 01-20-2016, 08:02 PM   #62
silverbear
silverbear's Avatar
Here is where I ended up, for now. I know there is a lot more to address but I happy to be making some progress.
1996 GMC Yukon GT
Old 01-25-2016, 09:52 AM   #63
Greenlee
Greenlee's Avatar
Looking good!
That's a bummer about the new radiator and intake-- 1 step forward, 2 steps back.
Old 01-26-2016, 03:39 PM   #64
silverbear
silverbear's Avatar
I forgot to include this pic. I found a shop that made these up for me (very reasonable price) so I would not have to pull the radiator back out when I get ready to re-install the A/C system. They have the correct O-ring style fittings on the ends so connecting up the new hoses will be simple.
1996 GMC Yukon GT
Old 03-05-2016, 06:40 PM   #65
silverbear
silverbear's Avatar
So I have been trying to get a radio installed in Frankie. The dash bezel I had was cut for a single DIN radio but it didn't seem to be in the right place to match the cut out in the dash panel. After searching and waiting I found what I what I wanted, a dash bezel out of a late 80's Suburban or Blazer with the factory opening for a 1.5 DIN. So I made this plate to mount to the dash.
1996 GMC Yukon GT
Old 03-05-2016, 06:51 PM   #66
silverbear
silverbear's Avatar
While I was at it, I made some 6x9 speaker brackets fro the rear cab corners.
1996 GMC Yukon GT
Old 03-05-2016, 06:57 PM   #67
silverbear
silverbear's Avatar
And this is how the radio install finished up. Still need to mount the 6x9s and the new brackets.
Sorry for the rotated pic. When the pic uploads is rotates to this angle.
1996 GMC Yukon GT
Old 06-14-2016, 10:56 AM   #68
silverbear
silverbear's Avatar
I am collecting parts and getting ready for some upgrades. i traded off some old lawn mowers I had laying around in my barn for this 14 bolt FF, 3.73 gears and posi. Then after hunting salvage yards for a few weeks, I found the backing plates and rotor assemblies I needed to convert my 10 bolt front axle.
Here are the before pictures:
This axle came out of a 99 Express 2500. So I knew I would need to move the spring perches and shock mounts.
1996 GMC Yukon GT
Old 06-14-2016, 11:00 AM   #69
silverbear
silverbear's Avatar
And after a few days of sanding and wire brushing along with grinding and welding... and then some paint, the after pictures.
I still have some prep work to do but I was excited to share my progress.
Those 13" drums are monsters!
1996 GMC Yukon GT
Old 06-14-2016, 02:29 PM   #70
68Timber
I know the pieces fit
68Timber's Avatar
The detail work looks great!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 06-14-2016, 04:56 PM   #71
made2drag
made2drag's Avatar
im loving the carbon fiber vinyl...interior is looking sweet
made2drag is offline   Reply With Quote
Old 06-14-2016, 06:42 PM   #72
LT7A
Dash pad looks great. When I started reading this build, I kinda thought, this guy has got a lot of work in front of him. The changing out of multiple body parts, multiple times would doom most projects. Way to stick with it! That is now a really solid rig.
Old 06-14-2016, 06:49 PM   #73
silverbear
silverbear's Avatar
Thanks guys. It has been slow going at times but I have an ultimate plan for this truck and it will take me a while to get it the way i would like...more to come.
1996 GMC Yukon GT
Old 06-24-2016, 09:39 AM   #74
silverbear
silverbear's Avatar
Still have not been able to start my axle swap but I did get a few more items checked off. I got the rear speakers installed and I had to replace the starter. My original one has been noisy for a while but it still worked, so I didn't mess with it. About three weeks ago the noise got worse and it finally quit working.
1996 GMC Yukon GT
Old 07-13-2016, 03:33 PM   #75
made2drag
made2drag's Avatar
Attachment 1506544
Attachment 1506546
the radio install looks killer!
