Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 05-12-2014, 09:46 AM   #51
Clrussell
Clrussell's Avatar
Re: 69 4x4 burb daily driver
Old spring set up
61 apache
Clrussell is offline   Reply With Quote
Old 05-12-2014, 09:47 AM   #52
Clrussell
Clrussell's Avatar
And the new
61 apache
Old 05-12-2014, 09:51 AM   #53
Clrussell
Clrussell's Avatar
Rolled the 14 bolt under it yesterday afternoon and went to bolt it in. Realized spring perches are 1.5" wider on the 14 bolt than the suburban is, so tonight I've got to pull it back out and take it over to the shop where I can cut them off and move them. I should have measured before I tried putting it under there, I assumed it would bolt right up.. Wrong..
Does anyone run a flex fan anymore or a clutch fan? The burb tries getting hot if your not moving very fast, it currently has a clutch fan on it that was on the 350 and I never had problems out of it.
On a positive note, while I was under the dash wiring up my tach a while back I noticed the speedo cable was unhooked. I hooked it up and now the speedo / odometer work!
61 apache
Old 05-13-2014, 09:44 PM   #54
Clrussell
Clrussell's Avatar
Finally afe some noticeable progress the last couple days. Got my spring perches moved to fit my leaf springs, then installed the 14 bolt. Got it setting on the 35s and backed it out of the garage to clean the garage up some. Set the good on by myself(which is a pain btw)
Here's a progress shot outside
61 apache
Old 05-13-2014, 10:42 PM   #55
Bigdav160
Bigdav160's Avatar
I like it.
Some people would like something prettier,
Some would like thing safer,
I think it's just right
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-17-2014, 08:07 PM   #56
Average Joe
Average Joe's Avatar
x2 ^
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 06-01-2014, 11:55 AM   #57
Clrussell
Clrussell's Avatar
Finally had time to make some really good progress yesterday. Got the rear discs on and plumbed, installed front springs, front shocks, the 8 lug 44 is now under it. Rear is pretty much complete, need to get an inch taller block to make the ride height level. Installed new seals in the rear, cleaned the diff up and filled with new fluid. The factory driveshafts bolted in, rear I had to use a 1310/1350 conversion u-joint which will work for now until I decide what I'm going to do on trans/ transfer case. I forgot to pick up my front axle joints so we didn't start on brakes or anything on the front end yet.
61 apache
Old 06-01-2014, 11:56 AM   #58
Clrussell
Clrussell's Avatar
One sitting in the parking lot
61 apache
Old 06-01-2014, 11:58 AM   #59
Clrussell
Clrussell's Avatar
Shows how much taller the front is. I was actually hoping for this since I didn't really like how low the rear fenders sat on the tires. Easy fix though
61 apache
Old 06-01-2014, 11:59 AM   #60
Clrussell
Clrussell's Avatar
Still need a big block power steering bracket..
61 apache
Old 06-15-2014, 08:40 PM   #61
Clrussell
Clrussell's Avatar
Ordered an aftermarket ps bracket off ebay, fit perfectly. Got all my brakes finished up minus the power booster/ master cyl. Installed all new ball joints, tie rod ends, spicer axle joints, packed all the bearings and all new brakes. Took it to the muffler shop Friday and got my 2.5" exhaust with x pipe installed and ran to the flow master 40 series. I've drove it about 50 miles this weekend, man I missed this thing. Hopefully picking up a front bumper this week and mounting my lights in it.
61 apache
Old 06-15-2014, 08:42 PM   #62
Clrussell
Clrussell's Avatar
Another view
61 apache
Old 06-15-2014, 11:18 PM   #63
mud.man.rj
mud.man.rj's Avatar
Sub is coming along nice.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 07-08-2014, 09:10 PM   #64
Clrussell
Clrussell's Avatar
Installed my power brake bracket / booster and master this evening. Holy crap this thing stops now!
61 apache
Old 07-08-2014, 09:11 PM   #65
Clrussell
Clrussell's Avatar
Picked up a front bumper a couple weeks ago, brackets just got here today. Built a receiver hitch last night and ran out of welding wire. Hope to finish and install that tomorrow along with my trailer brake controller and plug in.
61 apache
Old 07-09-2014, 08:07 AM   #66
Cobalt964ruf
Cobalt964ruf's Avatar
looking good
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's
1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's
Cobalt964ruf is offline   Reply With Quote
Old 07-09-2014, 03:35 PM   #67
Clrussell
Clrussell's Avatar
Got my hitch installed, about to start wiring up the trailer plug and brake box.
61 apache
Old 07-11-2014, 09:57 PM   #68
Clrussell
Clrussell's Avatar
Hauled a project home tonight with the burb, swapping a ls engine/ trans into it for a customer. Got my front bumper on too since the last pics.
61 apache
Old 07-20-2014, 07:38 PM   #69
Clrussell
Clrussell's Avatar
Took the boat to the lake this weekend, was really impressed how the burb handled it. About 110 mile round trip. I'm going to need a heavier clutch before I do that many more times. That and fix my front driveshaft since it's extremely loose in the slip yoke.
61 apache
Old 07-27-2014, 12:56 PM   #70
Average Joe
Great towing pix! I'd say you nailed it on your wheel/tire/lift choice. Looks great.
Old 07-28-2014, 07:56 AM   #71
Clrussell
Clrussell's Avatar
Thanks, I love it. Drives great and isn't to tall. Tire height and gear combo seems perfect for towing. 55mph is 2500 rpm.
61 apache
Old 08-05-2014, 12:22 AM   #72
Cumminpwr11
Southern Nevada Coal Roller
looks good. Did you say what wheel size and type that is? Looks great. I am going Dually Sub with my 4x4. Keep up the great work. I am getting inspired.
Chris
Chris
72 Suburban, 1 ton dodge chassis 4wd cummins, DTT 47rh 89%, PDR VE 3200 spring, PODS, Piers Turbo.
36 Chevy P/U rat rod project. 4bta cummins
Cumminpwr11 is offline   Reply With Quote
Old 08-05-2014, 06:02 AM   #73
Clrussell
Clrussell's Avatar
Chris
It's a 20x10 wheel with 35-12.5 Hercules mud terrain. The tires are something new so we ordered a set to try em out. So far I've been really impressed considering how aggressive they are. Good street manners and not to loud.
61 apache
Old 09-01-2014, 05:12 PM   #74
Clrussell
Clrussell's Avatar
Well it's been a while since an update.. In the last couple months I've put about 3500 miles on it and a couple mechanical fuel pumps. I finally gave up and put a holley red fuel pump on it..
Sadly to report I'm going to sell it. We got the wife a new car and I bought a cheap diesel to drive. To many vehicles to keep em all. I'm a lot more a attached to my 71 pickup than the burb. I love driving the suburban though, I probably enjoy it more than I have any of my nice trucks. Everyone stops to talk to me when I'm somewhere.
61 apache
Old 09-14-2014, 12:23 AM   #75
Average Joe
Say it aint so
