Old 05-12-2014, 07:26 AM   #51
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: First look at my K10 with 2-1/2" Skyjacker lift
You should be able to run disc brakes on the Rally wheels and also 71-87 6-lug wheels. The only problem I've heard of are some Wheel Vintiques rims and possibly with some drop spindles. Otherwise you should be fine. Not sure if you tried it, but do a little searching to find out for sure. Check out the threads below.
http://67-72chevytrucks.com/vboard/s...d.php?t=503975
http://67-72chevytrucks.com/vboard/s...d.php?t=398068
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 05-12-2014, 08:26 AM   #52
CUSTOM/10
CUSTOM/10's Avatar
The set-up that I have won't fit under 15's ( I got them from a friend ) If I was going to buy a kit I would have done my research and bought something that would fit. I already bought new tires & rims that should be in today !
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is online now   Reply With Quote
Old 05-14-2014, 05:30 PM   #53
i82much
Do lifts normally settle after a little while? Seems like you gained almost four inches in the front, not sure whether that is because your old springs were sagging or if the new springs haven't settled yet.
I just purchased the Skyjacker 2.5" with the rear leafs for my 72. Your truck is absolutely beautiful, I was thinking of painting it blue with the white roof but it is tough to look at yours and not want to copy it!
i82much is offline   Reply With Quote
Old 06-13-2014, 11:30 PM   #54
imjeff
imjeff's Avatar
Originally Posted by derotoreut View Post
I just completed the installation of my Skyjacker lift. I installed new front and rear springs. Now I'm in the process of evaluating my wheels. I installed 2-new BF Goodrich tires on Rally wheels and two on original steelies. I was hoping to use the original white steelies that I had, but I don't care for the 3" backspacing. It pushes the tires out too much past the fenders for me. They are original 15X8 drum-brake steel wheels with 3-nubs. Looks like I'm going to go with the 15X8 Rally wheels with 4" backspacing. Just sets the tires in a little more. I do like the lift though. The lift gave me about 3" more height with my original tires. With the new 33's, I get a total of about 5" over what I had originally.
My plan will be to blast and paint the rally wheels either white or body color. Feel free to voice opinions.
Does anyone know what the backspacing is on the 4-nub 15X8 steelies is? These are the wheels that can be used with disc brakes.
Pic-1 is before lift kit
Pic-2 is after lift kit with original wheels and original 31x10.5x15 tires
Pic-3 is after lift kit with original wheels and new 33x12.5x15 tires
Pic-4 is after lift kit with rally wheels and new 33x12.5x15 tires
Thanks for all the pictures! I pulled the trigger on five CL 15 x 8 rallys the other night to replace my aging Centerline Hellcats (I'm not really a cast wheel guy on trucks). My wife suggested powder coat as my Fathers Day present since I'm generally too cheap to do it, but really like it. I really like the orange, but since I have a LWB with orange top I thought it would be too much on mine. I will post some pics when I get it all together with the new 33/12.50 15 BFG A/Ts (on a 4" lift). Between all your pics and Tx Firefighter's advice on powder coating you guys saved me a ton of time and money wondering which way to go. Thank you!
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 06-14-2014, 09:51 PM   #55
derotoreut
derotoreut's Avatar
Just a warning that you may get some minor bubbling out at the seam on the Rally wheels. You may want to ask the guy who does your powder coating about it. Mine warned me about it ahead of time. I solved it by using clear 3M self leveling seam sealer over it afterwards. It's a two part epoxy sealer that filled the gap nicely and will prevent any future rusting in that area over time. Unfortunately I don't have a close up picture of it after I installed it. If you want to see a picture I could get one after the weekend (Father's Day you know tomorrow ). Good luck and I can't wait to see the end results.
~ Dan
Old 06-14-2014, 09:58 PM   #56
whitels1
whitels1's Avatar
Truck looks great!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 06-16-2014, 07:40 PM   #57
derotoreut
derotoreut's Avatar
Originally Posted by whitels1 View Post
Truck looks great!
Thanks a lot. Nice work on the LS swap! In my next life I would love to do a 67 SWB with a LS. Never satisfied I guess.
~ Dan
Old 06-25-2014, 06:58 PM   #58
imjeff
imjeff's Avatar
Got my rallies back from powder coat. Only one of the five bubbled. My powder coated offered to strip and repair or discount. Being a frugal (wife says cheap) man, I tool the discount.
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
Old 06-25-2014, 07:00 PM   #59
imjeff
imjeff's Avatar
Uploaded the wrong pic. Will post pics once I wrestle them on.
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
Old 06-25-2014, 07:20 PM   #60
derotoreut
derotoreut's Avatar
Well you know which one to use as a spare. They look good though. I'm looking forward to seeing how they look on your truck. Keep us posted. Lots of pics are always a nice thing.
~ Dan
Old 06-25-2014, 08:32 PM   #61
imjeff
imjeff's Avatar
Since I don't want to hijack your thread and since my caps and rings will be another project and so people can find a title like yours in a search for stance I will leave you with this sneak peak. No ring on rears and no center on either, but I like it better already! I've got some ideas for the rings and caps that I will include on another thread. Thanks again for the inspiration!
Jeff
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
Old 06-25-2014, 11:15 PM   #62
mud.man.rj
mud.man.rj's Avatar
Looking good, nice and clean, looks so high for 2 1/2" too.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 06-26-2014, 12:19 AM   #63
imjeff
imjeff's Avatar
It's a 4" lift. Not the OP, his is on a 2 1/2.
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
Old 06-27-2014, 10:48 PM   #64
mud.man.rj
mud.man.rj's Avatar
Good one, no wonder it seemed taller.
5.0 4spd std.
7" lift w 35's.
Old 10-23-2021, 01:06 PM   #65
danielwkade
Thanks for keeping records with that height chart. I'm seeing an initial 3.5in lift in the front and 1.25in lift in the rear, is that correct? I'd be very surprised to get those numbers if I bought a 2.5in lift.
danielwkade is offline   Reply With Quote
