Old 04-03-2014, 08:30 PM   #51
PEDROSKI
PEDROSKI's Avatar
Re: My daily driver/beater : How I turned lemons in lemonade
New here, but I have read majority of your threads from start to finish.
Old 04-05-2014, 12:50 AM   #52
Zane M
Kevin, you should be proud of what you have done with what you have available to you.
Within your budget constraints, you have put together a solid truck. I am sure it feels solid going down the road, and it doesn't puke or dribble fluids when it is parked.
It may not be pretty to most, but it is a very respectable work in progress. You haven't skimped on the important/safety items, while staying within the budget you need to follow.
I'm not trying to sound sappy, but you are an inspiration for the budget minded. I have 2x into my truck that you have into yours just taking care of essentials to keep it running and reliable. But along the way, after following your builds, I have taken the mantra that just because the budget is tight, you don't have to be "ghetto". I don't skimp on important things like brakes, ball joints, etc., but will go for "good enough" on non-essential items utilizing what I can find in the wrecking yard or online sources such as ebay or local classifieds.
Zane M is offline   Reply With Quote
Old 04-05-2014, 07:58 AM   #53
Greenlee
Greenlee's Avatar
You guys with your "no oil leaks" policy are making me feel bad about my truck!
I have this annoying oil leak coming from the oil pressure sending unit. Oil drips down the back of the motor around the starter area. I originally thought I must have a bad rear main seal. But, I checked it when I had the transmission out and the seal was dry and it was coming from the oil pressure sender. I replaced the sender and put the fittings back together with Teflon tape and it still leaks just as bad as before. What sucks is it is at the back of the motor and is very hard to get to. Okay, I'm done ranting in your build thread now.
Greenlee is offline   Reply With Quote
Old 04-05-2014, 10:12 AM   #54
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Fixing a leaking oil pressure seeding unit it a pretty straightforward job. It sounds like you covered the bases when you did it. I'd strongly suspect the back edge of your intake manifold is leaking if you're still getting oil from that area.
Old 04-05-2014, 02:13 PM   #55
Greenlee
Greenlee's Avatar
Good point. I guess I shouldn't assume it's the sender. I crawled under the truck this morning and cleaned everything real well. So, hopefully, I will be able to see where it's coming from.
Old 04-05-2014, 08:36 PM   #56
Average Joe
Average Joe's Avatar
Cool build! Every time I read one of your threads I learn something new or a different approach to doing something. Great work.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 04-13-2014, 12:03 PM   #57
rusty76
rusty76's Avatar
Anything new to add this week? Got to get my fix man....lol. Hope all is well.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 04-13-2014, 01:32 PM   #58
Tx Firefighter
Nothing new or exciting. I've been using it to haul fencing supplies lately for some improvements around the place.
Right now it's sitting in front of my shop in the rain while I'm inside building the 4x4 engine.
Last winter I dedicated all my time and money to building on my dually, but I think this coming winter the stepside is gonna get a warm spot inside the shop for a rehab with some cash and labor infusion. I've been researching air suspension lately....
Old 04-13-2014, 02:13 PM   #59
rusty76
rusty76's Avatar
Cool man. I felt the need to check in. I'm interested in seeing what you may come up with for air suspension that would be neat. Keep us updated. Thanks.
My build thread
Crossmembers CC
Old 04-13-2014, 09:38 PM   #60
Hankster
Hankster's Avatar
Just found and read this thread! I been wanting some info on this thing! I love it. Keep up the good work man!
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 04-13-2014, 09:59 PM   #61
chewiebarker
chewiebarker's Avatar
Thanks to Rusty for turning me on to this Low Buck Build thread.
It is amazing what someone can do with a little determination and know how! I appreciate your practical approach on this truck and for turning a difficult situation into something to admire. Sounds like your stepson could learn a lot from you - and not just about resourceful, creative fabrication! Good luck to you. Subscribed!
1971 K20 Suburban
2012 LS1500 4WD Suburban
2003 Honda Accord LX V6 (don't tell anyone)
MY 'BUILD' THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=618915
chewiebarker is offline   Reply With Quote
Old 04-14-2014, 04:48 PM   #62
rusty76
rusty76's Avatar
You are welcome!
My build thread
Crossmembers CC
Old 04-18-2014, 11:18 AM   #63
jhama78
jhama78's Avatar
Gotta love a 'phoenix' style build. I'm digging the 'out of the ashes' budget build ya did on this rig man.
-j-rod
'06 3500 LWB CC 4wd, 8.1 Allison
jhama78 is offline   Reply With Quote
Old 04-18-2014, 11:38 AM   #64
Tx Firefighter
Wait till y'all see the 4 wheel drive I'm building now. It was ready for the junkyard. Trashed interior, beat up body and dead engine. Phoenix indeed.
Old 04-18-2014, 12:22 PM   #65
tommyd241
tommyd241's Avatar
You always have the coolest, most resourceful builds!
'68 SWB Fleetside
'98 K1500 Silverado
tommyd241 is offline   Reply With Quote
Old 04-18-2014, 12:42 PM   #66
Malo83
Cruzzzn' Vet
Malo83's Avatar
Cool build Kevin! like your style
Malo83 is offline   Reply With Quote
Old 04-18-2014, 03:53 PM   #67
crashz
crashz's Avatar
I'm inspired every time I see your build threads. Great job restoring that turd to a nice driver!
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB
1987 GMC V3500 Dump, 6.2L diesel, TH400
1983 GMC K2500 - awaiting its restoration and Cummins swap.
crashz is offline   Reply With Quote
Old 04-18-2014, 04:27 PM   #68
Tx Firefighter
Originally Posted by crashz View Post
I'm inspired every time I see your build threads. Great job restoring that turd to a crappy driver!
Thank you for the words. But, I fixed them for you.
Old 04-18-2014, 04:48 PM   #69
K5owner
Awesome build considering the circumstances. I hope your step son is running his tail off and gets his kicked in by his DI and C.O once he gets to his MOS. We had a guy who didn't live up to his word like that in our unit and the nightly tune ups wore him out to the point he want AWOL. Couldn't of happened to a more deserving jerk.
K5owner is offline   Reply With Quote
Old 04-19-2014, 08:11 AM   #70
Jake Wade
Jake Wade's Avatar
Nice build! One of the few you could actually get more $ for than you put into it.
Jake Wade is offline   Reply With Quote
Old 04-19-2014, 12:06 PM   #71
powell72
powell72's Avatar
Kevin, I really enjoy your build threads. Cheap, dependable, cheap, detail oriented, and cheap. You always add a really simple style that just works too. Nice job.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 04-23-2014, 09:12 PM   #72
Randy S. Hager
Randy S. Hager's Avatar
Kevin you sir are an inspiration to me since I have so much work I need done to my 82 SWB. I have my 35mpg Saturn to drive so I should have no excuses to get to work. After I get back from overseas I'll jump in with both feet and chip away at it until I'm done. GREAT WORK!
Randy S. Hager
Venus, TX
Randy S. Hager is offline   Reply With Quote
Old 04-23-2014, 09:34 PM   #73
Tx Firefighter
Randy S. Hager
Venus, TX
Randy. Thank you. Your post means a lot to me. You've been a member here for four years and finally made your first post in my thread. Lurk no more !
No real updates on the truck right now. I'm researching wheel, tires, and suspension mods. It needs some modern rolling stock and lower ride height. Looking at 18/20 combos right now. I think this winter will be stepside time. I like to do one major project per winter. Last year was my dually.
My view yesterday as I was mowing around my shop.
Old 04-23-2014, 09:42 PM   #74
Randy S. Hager
Almost wanted to yank the fleet side off and go find a stepper. Since I've met you face to face several months ago I've kept track of your dually build and then saw this build. I'm going to keep mine an inline 6 (250) but want to do dual TBI. (1bbl units) Gota do some trading and get some more parts acquired after I get back from Italy. Get to have some totally tax free money to get me going in the right direction.
Old 04-23-2014, 10:36 PM   #75
Sodell
Sodell's Avatar
Tex, I have learned a lot from your builds and you always seem to take the time and give good advice. I am an older guy and came to this sight looking for advice to drop my truck (never thought I would say the word "drop") and you were one of the guys to immediately give me helpful advice..keep up the good work! I am glad you decided not to sell your stepper, keep at it in spite of your stepson.
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
