#51 | |
Re: The first year for two-tone paint?
Try looking for threads (like this http://67-72chevytrucks.com/vboard/s...d.php?t=612113 ) on adding bodyside moldings lower (BX2) and belt (B85) with the site search box. The lower is well defined and positioned by the body line it runs along. The upper is a bit more difficult as to location and the fact it curves down at the rear along the bedside and IIRC a little at the front as well. In the middle of a lot here but I will try and see what I can find out later. My assembly manual has all the layouts (short long and longhorn) but are measured from the factory waterline references which can be difficult to duplicate.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#52 |
![]() Join Date: May 2014
Thanks Tim, that definitely helped, and shows me I'm about 1-1/4" off. Looks like I need to redo all the white on cab, one fender and one door
![]() I'm going to have to read through those links again to see if I can figure the correct cutoff points on doors and cab
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
#53 |
Just went and did some measurements. I think I may still be good on the door and cab. Was just way off on the fender.
The bottom of that blue tape is where the white needs to go up to. I just stuck that beat up trim on to see how it would look. Moving it also seemed to help with the optical illusion that the parking lamp stamping was off. The bottom trim certainly isn't in line with each other, but that must be normal. It's following the contour lines in the fender
#54 |
I repainted to get the white correct, but my prep must have been bad. Some of the new paint peeled right off. I prepped by wet sanding with 800 on everything I was going to repaint. I thought that would be enough to scuff up the clear. I guess now I'll remove all of the white, te prime and paint. Time to buy more base and clear
#55 |
How come my SPID doesn't list a paint code? 69 stepside. It just lists the vinyl trim as blue. Yet the dash pad, steering col and wheel, seats, and instrument panel are black. The interior cab is white, the doors are white with blue panels (not turquoise), and blue panel back of the dash by the windshileld. The paint was so worn and faded, I couldn't be sure if it was white or turquoise. Same with the cowel, kind of a turquoise over white. None of the rubber had any kind of overspray or leakage on it (as though it was re-painted).
#56 |
![]() Join Date: Sep 2007
Ok so i gotta chip in here. I have an oramge 67 short stepper with very few options but it does have a white top. .some board members here say that the pillars werent paintes to match the top till 68 but my w/shield pillars are painted white which looks to me all original. The white goes all the way down to the stainless trim underneath the back window. Door window frames are painted white as well. Truck has never been repainted that i can see
1967custom |
#57 | |
Vinyl trm partsd ar often changed as is paint both exterior and interior. Often though a color change can most easily be seen inside. Several of your own posts support this being a white with blue vinyl truck too. If you have pictures of the truck and SPID post them up.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 09-24-2014 at 06:46 PM. |
#58 | |
IIRC the paint breaks suggested it was done at the dealer level or later. What does your SPID show for a paint code? Is it a slightly brighter white or does it match your front bumper?
#59 |
Heres my spid
You got a good memory. I dont see why it couldnt have been painted at the dealer. Its the same white as the bumpers. All faded just like the bumpers too.
1967custom |
#60 |
I just remembered so i took a pic right away. I pulled my busted windshield out a couple weeks ago and noticed the pinch weld where the gasket goes is painted whit also. ( well most of the pinchweld anyways) that tells me that the white was from the factory maybe?
Theres no bodywork or bondo anywhere on the truck except on the right door by the rocker and all the orange is original. I didnt find any mutiple layers of paint so far
1967custom |
#61 | |
#62 | |||
See code and description from a shipper on a 12/21/66 truck pictured below. Being as the truck also had an optional red interior thus red paint inside in 67 it all seems factory. Of course more and better pictures would be more defining. This leads me to believe it may have been a running change in early 67. Your serial number is relatively high but I do have two higher from Fremont in 67 extendng up to near 165000. All I can say is document it well if you are planning on painting anything. The exterior is 514 Red and the 526 Off White. As it happens with the red interior the sheetmetal was the same red as the exterior with a darker flat red forward of the dash pad. The light red, as most reds do, fades to a red-orange color so it will look a little different if painted as delivered.
#63 | |
![]() Join Date: Oct 2008
#64 |
New to forums. Dealer from Texas repainting a 1969 C10 long bed. Know a fair amount about C10s but can't quite get a clear answer on the 2-tone paint. The option code is 537. Question is .... in addition to the roof, is the rocker area below the lower belt line also supposed to be white?? Thanks in advance for replies!
#65 |
![]() Join Date: Oct 2009
537 should be white top only, rest lt blue.
#66 |
jocko - thank you!
#67 |
At the body shop.
Ok so 68 two tone questions.
Old blue has a white roof and white grille, the newer bed on it appears to be gold under the blue. But with a white grille and roof would the tailgate have been solid blue or ??
" That didnt make it any newer " " Dont antique the equipment " |
#68 | |
1969 Paint code 537 denotes a truck painted in the Conventional Two-Tone scheme of 507 Light Blue body color with a 521 White roof.
#69 |
The tailgate would be solid on a Two-Tone truck in 68 matching the primary body color. To be correct the "White" is actually code 526 Off White/ Ivory on the roof, grille and bumper if applicable.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 08-03-2017 at 11:12 PM. |
#70 | |
At the body shop.
Ok thank you. I was wondering. It' looks like a cst gate but is hammered. When I get a replacement i wanted to paint it right, but also thought half white and blue would kinda match the grille and roof.
#71 |
Any trim level 68 pickup (solid or two-tone) has a solid paint tailgate, in most cases wth Off-White letters.
#72 | |
![]() Join Date: Feb 2009
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#73 | |
At the body shop.
I know the bed doesn't belong to the truck nor the gate to the bed. Or the trim for that matter. Thanks.
#74 |
![]() Join Date: Nov 2022
ttt
still all very interesting and relevant |
#75 | |
