Old 09-25-2015, 09:36 PM   #51
Mapearso
Re: 72 C10 SWB -- Project "KISS"
Tailgate trim done ...
Mapearso is offline   Reply With Quote
Old 09-25-2015, 09:37 PM   #52
Mapearso
Grill done ...
Old 09-25-2015, 09:37 PM   #53
Mapearso
Brick by brick ...
Old 09-26-2015, 09:53 PM   #54
Mapearso
Rear window out. Thankfully not a spot of rust.
Just the windshield left to remove... and then off to paint
Old 11-20-2015, 02:33 PM   #55
Mapearso
Paint Jail --
Old 11-20-2015, 02:39 PM   #56
Mapearso
And the bed --
Old 11-27-2015, 11:16 PM   #57
Mapearso
POR-15 the frame today
Before -- Blasted it with a pressure washer, then wire brush and wire wheel. The differential was a PITA for sure
Old 11-27-2015, 11:17 PM   #58
Mapearso
And after ....
Old 11-27-2015, 11:17 PM   #59
Mapearso
Long day... I'm sore!
Old 11-28-2015, 01:06 AM   #60
dfwright
dfwright's Avatar
Looks like the soreness was worth it. They look so good when the frame gets all cleaned up and has a nice coat of paint on it. The console restoration turned out super-nice, and the look of that polished grill has me contemplating having mine polished. Did you have any dents in the grill or trim that needed to be dealt with? And if so, did you do that, or did the shop which did the polishing do that?
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 11-28-2015, 11:09 AM   #61
kingstrider
kingstrider's Avatar
Was the trim anodized after polishing? Or clear coated to keep it from oxidizing?
1972 Cheyenne Super swb:
http://67-72chevytrucks.com/vboard/s...d.php?t=684318
kingstrider is offline   Reply With Quote
Old 11-28-2015, 11:53 AM   #62
Mapearso
Thanks. Couple of very minor dents in the grill. The rest was clean.
Old 11-28-2015, 11:55 AM   #63
Mapearso
Neither. I assume it will need a little elbow grease every once in a while.
Old 12-01-2015, 11:11 PM   #64
bdk1976
Nice build!
bdk1976 is offline   Reply With Quote
Old 12-17-2015, 09:16 AM   #65
jessemthompson
Looking good and moving along quickly.
jessemthompson is offline   Reply With Quote
Old 12-17-2015, 09:29 AM   #66
ol_skool_chevy
ol_skool_chevy's Avatar
Im in for the ride
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 12-20-2015, 06:52 PM   #67
Mapearso
More work on the frame and undercarriage
Took these cool shots --
Old 12-20-2015, 06:55 PM   #68
Mapearso
And check out this tranny pan / cooler
"INTEGRITY TRANSMISSION KOOLERS, INC."
Old 12-20-2015, 09:04 PM   #69
flashed
That pan is so COOL.
flashed is offline   Reply With Quote
Old 01-08-2016, 11:43 PM   #70
Mapearso
More ...
Old 01-09-2016, 01:52 PM   #71
Stickman
Stickman's Avatar
Looking Good
Stickman is offline   Reply With Quote
Old 01-09-2016, 10:01 PM   #72
Mapearso
Originally Posted by Stickman View Post
Looking Good
Thanks. Chipping away at it!
Old 01-10-2016, 08:57 PM   #73
71cheynne402
What did you use to restore your console
71 Cheyenne 72 k5 71 jimmy 72 k10
71cheynne402 is offline   Reply With Quote
Old 01-11-2016, 02:42 AM   #74
Mapearso
Scuffed it up good with scotchbrite
Sprayed some adhesion promoter
Then SEM Landau Black Color Coat Paint
For the trim, I just cleaned the ring up with some 0000 steel wool and wd-40
I got a nice ashtray from the junkyard
I used some 3M marine teak for the woodgrain
New hardware from local store
Old 01-21-2016, 01:50 AM   #75
Mapearso
And awaaaaay we go!
510 gettin laid down
