Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 11-07-2019, 01:03 PM   #51
Notch1988
Notch1988's Avatar
Re: Powder Coating - A Home How to
Originally Posted by roll_the_dice View Post
Beautiful license plate. Did you do the black first then the yellow and wipe off the yellow on the lettering?
Yes exactly. Finger wiping on the plates, the valve covers and the vise from those pics.
66 GMC swb dropmember accuair
Link to my build:
My GMC Project
Notch1988 is offline   Reply With Quote
Old 11-07-2019, 01:40 PM   #52
roll_the_dice
roll_the_dice's Avatar
Thanks! This is the plate I am thinking of restoring before I put it on the truck...certainly is in good shape, but would look really good restored.
roll_the_dice is offline   Reply With Quote
Old 11-07-2019, 02:15 PM   #53
Notch1988
Notch1988's Avatar
For sure it would. Plates are VERY time consuming, I would guess 20-30 minutes just in finger wiping for your one plate. Plus you'll need to plan on how you're going to hang and hold the plate while you do the wiping so it doesn't move around on you.
Link to my build:
My GMC Project
Old 11-08-2019, 08:53 AM   #54
zicc1835
zicc1835's Avatar
wow....very nice work
zicc1835 is offline   Reply With Quote
Old 06-29-2022, 02:45 PM   #55
LNP
Some great work everyone has done. I do powder coating for a living and just want to add a helpful tip. Just heating your oven to 400 and then putting a part in it for 20mins will not necessarily be the proper cure time/temp of your substrate. Use a infrared temp gun to check the pmt (part metal temp). Each piece will cure at different times. The spindles one guy did will not cure as fast as the license plate another did for example. So you wouldnt leave them in the oven for the same amount of time. The more the density of the metal the longer it needs to be in the oven. I dont mean to disrespect anyone and hope its not taking that way. I just want to help if I can. Keep up the great work.
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
powder, powdercoat, powdercoating, sandblasting
