Old 04-20-2015, 09:51 PM   #51
cableguy0
Re: '04 5.3L in a '01 V6 Camaro.
Sometimes its cheaper to spend more money. Starting fresh is the better choice. Chasing an electrical gremlin will cause you to lose your mind later on. Considering it would probably take 10 hours or so to redo a harness yourself if not longer. Wiring is time consuming especially when terminating harness connectors.
Good luck with that rear....
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 04-20-2015, 11:19 PM   #52
clinebarger
Probably longer with a truck harness, The PCM is on the opposite end from a F-body. Your right....It would have been a nightmare!
I'm going to weld the axle tubes, Trick Flow diff cover, New Moser axles, Gears, Bearings & a used "Cone" Posi.
Being behind a automatic will help with longevity, T56 cars seem to tear them up more frequently. I'm not going to run drag radials or drag race it. It should be OK.
However, I'm not wearing rose colored glasses. When I put a 6.0L or 6.2L in it later on I will buy a 8.8" Ford housing for the car.
clinebarger is offline   Reply With Quote
Old 05-03-2015, 10:03 PM   #53
clinebarger
Scored an SLP filter lid, It fits the V6 base. The V6 lid is offset and will not work on a V8.
Old 05-03-2015, 10:09 PM   #54
clinebarger
Trick Flow diff cover.
Old 05-03-2015, 11:43 PM   #55
oldman3
oldman3's Avatar
Sweet looking cover...Jim
oldman3 is offline   Reply With Quote
Old 05-28-2015, 11:22 PM   #56
clinebarger
Got my engine harness from BP Automotive today. Man.....I'm IMPRESSED!!!!
The attention to detail is phenomenal, Bill got everything exactly right down to the Vacuum Line for the HVAC controls, To the Harness Bracket on the Evaporator Box.
Has the TAC module to Pedal harness integrated into the Engine Harness ($50 extra) But well worth it once I saw it done.
I will take some pics with my Camera later, Here is some fuzzy Cell Phone pics for now.
Old 05-29-2015, 02:06 PM   #57
jessemthompson
Looks great. Mine should be shipping from BP today, I can't wait to get it.
jessemthompson is offline   Reply With Quote
Old 05-31-2015, 08:21 PM   #58
clinebarger
Got the car to the shop yesterday, 6 miles with no coolant at all, Engine died a block away....Coasted up to the bay door Only ran 3 stop signs & a right on red without stopping.
Started with rebuilding the Diff, I found the noise it was making...Driver side Carrier bearing was shot. I originally thought it was a Axle bearing.
Everything set right up with the original shims. .030" pinion shim & original 1-piece carrier shims.
Replace the rear rotors & pads, AC-Delco Rotors & GM (PBR) pads.
Old 05-31-2015, 08:31 PM   #59
clinebarger
The Diff build went so smooth, I decided to go ahead & pull the engine/trans today. These cars are unbelievably easy to pull engines on. Took 1.5 hours. I'm sure it is a nightmare without a lift though.
Old 06-05-2015, 07:26 PM   #60
clinebarger
Getting really close, Engine/Trans is in, wired, Exhaust done, Fuel system done. New brakes all the way around, Shocks & Struts, Power steering hoses, A/C hose assembly, Radiator hoses, Modified the Battery cables.
Need...
Alignment
Tires mounted & balanced
Wire Cruise control
Waiting for PCM from BP
Old 06-05-2015, 07:33 PM   #61
clinebarger
More.
Old 06-05-2015, 07:40 PM   #62
clinebarger
A/C hose assembly.
Old 06-05-2015, 08:46 PM   #63
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
wow! fantastic job as usual Chris! Can I come look at her week after next??
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-06-2015, 06:58 PM   #64
clinebarger
Your welcome any time John.
Old 06-06-2015, 07:03 PM   #65
cableguy0
I wanna come over and play.. Looking for any help. Just need relocation help and a place to live. ... Looks good. That car should be lots fun.
Old 06-07-2015, 01:26 AM   #66
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I second that, and I'll expand it to any member whose build doesn't suck, and who has a comfy couch or a guest room. I work for myself, which I can do from anyones garage.
PS I need the WIFI password too.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-07-2015, 06:31 PM   #67
Clyde65
Clyde65's Avatar
Thank You Chris, I'll let you know before I do though!
Clyde65
Rebuild of Clyde
support our troops!
Old 06-07-2015, 08:32 PM   #68
clinebarger
Come on down guys, Ya'll will have to fight over who gets the pool table & which one gets the floor.....Dinner is at Noon, Supper is at 7:00
Old 06-09-2015, 10:09 PM   #69
jessemthompson
Br3w I have a guest room, a comfy couch, wifi password and a garage for you. Your advise here has been invaluable!
The camaro is coming along beautifully clinebarger! Can't wait to hear you have it running. Hopefully I'll have some updates to my build this weekend. My harness is due in tomorrow. I have my fingers crossed that the weather will cooperate with me along with my 2 yr old son.
Old 06-10-2015, 07:45 PM   #70
clinebarger
Thanks man! Good luck on your build!
Started the engine up yesterday, Drove it to the Alignment shop today. Engine runs really good, Sounds great, I'm really excited!!
Only a short list of things so far....
Gas Gauge reads backwards.
A/C Clutch fuse blows when relay is commanded on.
Needs the MAF rescaled in the tune.
Exhaust hitting somewhere.
Going to get it home, Then send the PCM back to Bill @ BP.
Old 06-11-2015, 06:32 AM   #71
jessemthompson
Congrats clinebarger, you'll get the little things worked out over time. There always seems to be a few things that need sorting out.
Old 08-29-2015, 12:26 AM   #72
Low Elco
How did this work out? Rubber flying in the streets of Texas?
Low Elco is offline   Reply With Quote
Old 08-29-2015, 10:19 PM   #73
clinebarger
Not yet, I drove it to the house right after the front end alignment, Drove/Ran very well! I didn't get on it because the Trans & Gears are still breaking in, Parked it in the garage.....Been there ever since.
It has been TOO HOT for me to mess with it, 100 degrees & 50% humidity doesn't work well in my non-insulated metal garage, Soon as it cools down I will get back on it!
Old 09-05-2015, 01:43 AM   #74
whitels1
whitels1's Avatar
Nice work!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 09-14-2015, 08:06 PM   #75
clinebarger
Finally got it finished up Saturday, Put a couple hundred miles on it so far, Very happy with it, Lights the tires at will with the old ****y touring tires, The high performance tires I have should calm that down.
To do list....
Gas gauge still reads backwards....Not sure if I will/can fix that?
Need to swap out the Compressor Clutch, I have a good used one.
Re-torque header bolts.
Buy a key fob, Open the door, The alarm goes off 'til you turn the key on.
Mount & Balance tires.
Car in the driveway doing final fluid checks.
