Old 01-23-2016, 06:28 PM   #51
Jeramy
Jeramy's Avatar
Re: Green Beater
So today's update is brought to you by the word "rework" as in i didn't do it right the first time.
for starters had to replace the speedo cable because i routed it wrong and exhaust gets hot...who knew?
next up was completely redoing the rear brakes because this genius right here didn't replace the wheel cylinders even though he knew better. This time we replaced everything inside of the drums. drums have been resurfaced
third in line was once again to replace the passenger side header gasket. 5th times a charm maybe.... keeps blowing in between center exhaust ports. may change out to my other set of beefier headers i have see if that helps
last in line was replacing the 8 month old starter that likes to work only when it feels like it. New one seems more eager to please.
1981 Silverado C10 LS/4l60e
My truck may be loud and ugly but I love her like bacon
Jeramy is offline   Reply With Quote
Old 01-31-2016, 04:24 PM   #52
Jeramy
Jeramy's Avatar
Re: Green Beater
tried to fix my speedometer problem this weekend by buying a used 30 buck 1980 100mph speedo but turns out it don't really work. don't think the seller intentionally sold me a bad one was just in his shed to long. i took alot of pictures but am not going to post them as the project was a flop.
i did also pull my passenger side header as it had blown the gasket at the center ports again. a little grinding on the outer edges of the center ports and some checking with a straight edge was my quick fix. so far so good. put 50 miles on it yesterday and no signs of leaking. seated the gaskets same as always with a heat cycle and a retorque. time will tell.
while i had the header off i rerouted some of the wiring and cleaned up the appearance on passenger side also.
Old 02-03-2016, 01:02 AM   #53
Jeramy
Jeramy's Avatar
Re: Green Beater
piece of junk speedo quit on me this morning...and then i got a speeding ticket.
then a friend came by my work and gave me a replacement that works great
getting really good at swapping these. only took 10 minutes to do swap after work.
Old 02-14-2016, 06:49 PM   #54
Jeramy
Jeramy's Avatar
Re: Green Beater
fixing to start engine build number two. going to take a 1972 350 block to the machine shop to punch 30 over and cleaning in next week or so. get the crank checked and then order up a bearing and gasket kit
ordered in a new set of tires. mickey thompson sportsman s/t in 245/60-15 and 275/60-15
also ordered new window seals and sweeps
Old 02-18-2016, 01:27 PM   #55
Low Elco
Re: Green Beater
Go to nearest speedo shop and buy something. Take receipt to court to verify broken speedo and fix. Usually gets it wiped. Good luck!
Low Elco is offline   Reply With Quote
Old 02-18-2016, 09:56 PM   #56
Jeramy
Jeramy's Avatar
Re: Green Beater
unfortunately no speedo shops near hear. just paid it and moved on with my life.
Old 02-20-2016, 09:21 PM   #57
Jeramy
Jeramy's Avatar
Re: Green Beater
got the new window seals installed. makes the windows really stiff to roll up and down
also a few pics of new tires
245/60-15 front
275/60-15 rear
8" rallys
truck is not parked on even level ground
Old 02-25-2016, 09:44 PM   #58
Jeramy
Jeramy's Avatar
Re: Green Beater
dropped block and pistons off at machine shop for bore and hone to .030 over.
when i get it back i will scrub it down really good then install cam bearings and freeze plugs myself. if i have time will build the short block this weekend then just a matter of finding time to swap out.
Old 02-26-2016, 10:40 PM   #59
Jeramy
Jeramy's Avatar
Re: Green Beater
Did not get my block back today so no work will get done on it this weekend. Plus my connecting rods will not be here for about another week.
Old 03-04-2016, 09:54 PM   #60
Jeramy
Jeramy's Avatar
Re: Green Beater
got my new connecting rods but still no block. called the machine shop and was supposed to be done today but nothing by time i had to head home from the store. hopefully can pick it up monday.
Old 03-05-2016, 01:08 PM   #61
Matt Man
Matt Man's Avatar
Re: Green Beater
Like the new tires, looks like a 80's street machine.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 03-05-2016, 07:34 PM   #62
Jeramy
Jeramy's Avatar
Re: Green Beater
Thanks Matt kinda had the same thought the other day
Old 03-07-2016, 09:56 PM   #63
Jeramy
Jeramy's Avatar
Re: Green Beater
Got my block back today. Looks like new... i love new parts. Now to start the assembly process. What I have is a completely bare block so cam bearings then core plugs, plasti-gauging and what not. The what not is my most favorite part.
Have to get my shed straightened out and the block up on the engine stand. Then away we go
Old 03-16-2016, 07:54 PM   #64
Jeramy
Jeramy's Avatar
Re: Green Beater
Got the cam bearings installed into the block and after another day of hunting for mounting head finally got it on the stand 3/13. took a grinder to it and removed some of the casting flash from it. Proceeded to get a piece of it in my eye which i had removed by eye doctor today. that sucked.
dropped pistons and rods off at machine shop to be assembled today along with the crankshaft for polishing.
Old 03-16-2016, 08:04 PM   #65
Zach079xxx
Zach079xxx's Avatar
Re: Green Beater
Just read through this and couldn't help but smile when I read you said you don't need a speeding ticket and then the very next day you got a speeding ticket.. hahahah thats the luck of the draw. Keep the updates coming, and we want pictures of this new 350
85' GMC Sierra Classic
Built 350; Weiand intake, Holley 600, Thumpr Cam
Built 350 turbo with shift kit & 2500 Stall
Thumpin' away
Zach079xxx is offline   Reply With Quote
Old 03-16-2016, 08:07 PM   #66
Jake Wade
Jake Wade's Avatar
Re: Green Beater
Why are you putting together another engine?
Jake Wade is offline   Reply With Quote
Old 03-16-2016, 08:21 PM   #67
Jeramy
Jeramy's Avatar
Re: Green Beater
FINALLY SOME PICTURES!!!!
i would label each but pretty sure you guys know what is what
Old 03-16-2016, 08:30 PM   #68
Jeramy
Jeramy's Avatar
Re: Green Beater
PRW chrome moly roller tip rockers in a 1.52 to 1 ratio. Got the set new for $100. Should be a nice upgrade over factory stamped rockers.
Old 03-16-2016, 08:44 PM   #69
Jeramy
Jeramy's Avatar
Re: Green Beater
the engine in the truck now was never intended to be a permanent replacement. i did a quick hone the block and slapped rings and bearings in it. As such it has problems like only 20 psi oil pressure when warmed up at hwy speed. I am sure due to excessive bearing clearance. i cut to many corners on first engine so i could keep the truck on the road. trying not to do that this time.
post number 8
Old 03-16-2016, 08:48 PM   #70
Jeramy
Jeramy's Avatar
Re: Green Beater
ain't it though
Old 03-17-2016, 08:12 PM   #71
Jeramy
Jeramy's Avatar
Re: Green Beater
got my head and main stud kits in the mail today. would be nice if crank and pistons are ready tomorrow but not gonna hold my breath.
Old 03-19-2016, 02:16 AM   #72
LT7A
Re: Green Beater
Keep at it man. I like this rig.
Old 03-19-2016, 01:42 PM   #73
Jeramy
Jeramy's Avatar
Re: Green Beater
Thank you.
Old 04-03-2016, 09:05 PM   #74
Jeramy
Jeramy's Avatar
Re: Green Beater
have not done much with truck or engine lately. assembled the crank into the block today after plasti gauging it. Main studs are so much nicer to work with than bolts.
Old 04-03-2016, 09:46 PM   #75
SkinnyG
SkinnyG's Avatar
Re: Green Beater
Do you need to clearance the block for the timing chain?
Just a heads up, if you haven't.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
