08-07-2017, 03:35 PM | #51 |
Re: 1972 C10 ... SoCal BBC/TH400
Good work on the engine stand!!!
Some time, if possible. I'd like to see some pictures of where there the drip rail was removed. Front and side, for reference...Thanks!!! |
08-08-2017, 12:04 PM | #52 |
Its officially...8 mile maiden voyage. No major issues, but a couple things to address.
First stop....the gas station.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914 1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161 |
08-08-2017, 12:14 PM | #53 |
68Gold/White...not sure if this drip rail removal is the best example. It looks like the previous owner removed the rail with a dull axle, then randomly welded the aftermath with a stick welder in the dark.
I added some more mig welds and some time with the grinder wheel. Then there is a "fair" amount of body filler in there to make it look presentable.
08-08-2017, 07:33 PM | #54 |
That turned out great!
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
08-11-2017, 02:17 PM | #55 |
This is a sweet truck! I love everything about this build, especially all the DIY you put into it.
08-18-2017, 12:58 PM | #56 | |
thank you
Steven '67 SWB, 250ci, 3OTT.......this is my first build...... I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71" |
08-28-2017, 02:08 PM | #57 | |
08-28-2017, 02:13 PM | #58 |
Looking real good B.
08-28-2017, 02:22 PM | #59 |
I have the US Mags - Rambler wheels. I bought this set used off another board member. I recently painted them gold.
Regarding the paint - I would certainly paint another vehicle, but I'm not sure metallic will be used. I think you just need more practice to spray a good metallic paint. Most likely my other project will get a solid color paint job. As I expected, the bugs are starting to surface with some miles. It didn't run well. Checked the timing (it was at 4 degrees) and replaced the plugs to find 7 fouled plugs and 1 plug that was cracked in half. Its running better now. The steering on the truck is horrible, so I've been working on that this week. And still have a persistent drip from the trans. But its a lot of fun to drive!!!
08-28-2017, 02:23 PM | #60 |
Thanks!
08-28-2017, 02:28 PM | #61 |
Keep up the good work B. mine should be drivable before Christmas , if all goes well. lol
09-13-2017, 12:37 PM | #62 |
Well that was short lived....
Ended up having an electrical gremlin and the truck would just shutting down. Decided it was the old MSD stuff that the previous owner had. I put in a HEI and haven't had an issue since. Update on the steering: Ended up replacing the steering box. Was fighting a couple of stubborn leaks and had a bind with the rag joint, but now it everything is smooth and responsive. Much nicer than the old worn out box. So this past Sunday I got the truck out for a cruise to test out the steering. Was just cruising down the street and got a nasty sounding misfire. I just turned around and went home. Monday night I pulled the valve cover off to find the rocker stud on cylinder #5 was snapped in half. Last night I pulled a good stud to get some measurements to order new rocker studs and found the valve spring on cylinder #1 is cracked and the spring is basically riding on itself. So now the heads need to come off and I need to figure out how to rebuild them or what to replace them with. Total miles driven on project....48
04-02-2018, 12:53 PM | #63 |
Finishing up the bed of my truck....
04-02-2018, 01:08 PM | #64 |
That's Awesome B. I finally got back to the truck, been out of it almost a year. Really hitting it hard this time around. No set dates, just lots of working on the truck. We will see how that goes. I'm glad you are posting updates, its inspiring me to keep on trukkin. LOL. Wil
04-12-2018, 04:20 PM | #65 |
So many bolts, washers, lock washers, and nuts on the bed!
But starting to look a little different....
06-26-2018, 01:40 PM | #66 |
I think this is considered a change order....LS swap in the very near future!
06-26-2018, 04:05 PM | #67 |
Yes! I'm in the process of an LS swap myself, but my engine wasn't has pretty as yours.
1970 C-10 "Old Yeller" |
06-26-2018, 04:10 PM | #68 |
Also in the process of LS Swap. lol.
07-06-2018, 06:32 PM | #69 |
Found a used 5.3/4l60e from a 2005 Silverado.
Now comes the fun part
07-06-2018, 07:14 PM | #70 |
sweet. Looking good. Is it ready to pop in or are you going to work it? Cam, springs?
07-06-2018, 10:31 PM | #71 |
Yeaa buddy! Time to change the thread title
07-07-2018, 06:10 PM | #72 |
Score that looks like a clean motor. Hope the install goes smooth for you.
Project Double Tap http://67-72chevytrucks.com/vboard/s...d.php?t=555901 69 Olive Verde http://67-72chevytrucks.com/vboard/s...d.php?t=734720 |
07-13-2018, 03:07 PM | #73 |
Been working on doing the DIY stand alone wire harness (and a little custom wire tuck) while waiting for parts to arrive.
And parts are arriving. Its like christmas in July in the bed of my truck
07-14-2018, 01:27 AM | #74 |
Nice goodies. Gonna be sweet. what oil pan is that. What you gonna do to the 5.3?
07-31-2018, 06:48 PM | #75 |
I'm not planning any engine mods to the 5.3 (yet). I'd like to get the engine in the truck and get a few hundred miles in it before I make changes.
The oil pan is a factory replacement F-Body Camaro purchased dirt cheap from Rockauto.com The wire harness modifications are done. Just need to complete the fuse box and relays. Then I'll wrap it in split loom Got a bracket mocked up to mount my DBW pedal. Need to finish weld and paint Modified the sender on my LMC bed mounted gas tank for the return line
