Old 11-29-2016, 05:26 PM   #51
sangell
Re: 1971 C-10 Cheyenne
Originally Posted by RenoKeene View Post
Just found this thread. We appreciate you being here, good dad with mad skills and determination. I had a feeling the one piece shaft was going to be a problem as I have a background in metallurgy and harmonics but I was too late to the party.
Folks like you make this place kinda special, thanks.
Well thank you very much, I try my best.
sangell is offline   Reply With Quote
Old 11-30-2016, 05:47 PM   #52
Ian71GMC
Hello from just across the state line! You and your son have done some great work! Oh, and I'm an Eagle Scout, too.
1971 GMC C2500 - 350 SB - 700R4
1972 Chevy C10 - 350 SB - TH350
Ian71GMC is offline   Reply With Quote
Old 11-30-2016, 06:19 PM   #53
sangell
Thank you. We pass through Harrisonville often as we own land that we hunt on just North of Urich MO.
Old 12-12-2016, 04:45 PM   #54
sangell
Well after being on the road for only two weeks the truck is back in the shop/garage. The original plan was to redo the interior this winter however I got thinking that with the interior and glass removed this would be the best time to paint the truck, and if we were painting the truck now would be the best time to make the conversion to a short bed so we are diving in head first. Truck is getting a combo of spray in heat/noise reducer and hush mat, new carpet, door panels, all new rubber seals/gaskets, and glass for the interior. The exterior is getting new front fenders, short bed sides, bumpers, and paint. The body, interior from the glass up, and engine bay will be single stage satin black while the bumpers, grill, mirrors, door handles, and wheels will be gloss black for a little bit of accent.
This past weekend was getting the interior and glass gutted then some rust repair done. The roof header panel was worse than we thought so we put in a patch panel. While the old piece was out we took the time to clean up what we could and paint on some rust encapsulator and then used the Eastwood inside frame spray on stuff in the rest of the roof. The panel is not done yet but getting closer.
Old 01-03-2017, 02:11 PM   #55
ChuckLee
Good job man! It's funny how things snowball when you start tearing it apart. It's so much better to do everything at once if you have patience, garage space, the finances to buy parts, and a lot more drive!
I'm in the same boat, it's all torn apart, so now is the time! I'm just trying to decide where my "for sure limitations" will be before I start putting things back together.
Things i've decided to cave in on while it's torn apart: fixing/painting whole
frame, fixing/painting whole body, suspension bushings etc, wiring, etc.
Things i am still on the fence about during my build/ls swap: turbo lq4 build or NA lq4 build, cheapo $1,000 airmaxxx air ride.
All in all, I love what you've done so far. You are clearly much more experienced than I, so I'm learning as I read yours. I wish I had the metal working skills and experience you have, but I'm a absolute novice there.
question: your top bed rail near the cab.......what happened to it? it looks bent in the middle.
LS Swap build thread http://67-72chevytrucks.com/vboard/s...d.php?t=722579
ChuckLee is offline   Reply With Quote
Old 01-03-2017, 03:10 PM   #56
sangell
Well as we got more into it we found more issues and being that I suck at body work we went with a new from clip including a core support. We got the new parts "fitted" as best we can then blew it apart to cut the frame down. We have decided to have the cab and doors blasted which will happen next week sometime. The new bed parts will be picked up in the next week or two which will included short bed sides, tail gate with the embosed CHEVROLET and a new header panel.
Old 01-03-2017, 03:17 PM   #57
sangell
Thank You, your truck is super cool. We plan to do a single 78mm turbo on the 5.3 in the next year or so.
While the body is off and since we have the material laying around we are going to make tubular cross members for the rear three and new rear shock mounts and a new adjustable track bar.
The rear bed header panel is bent and even has five holes in it, I'd say it lived a hard life. We will be replacing it.
This is my son's truck so the turbo is his call, if it were me I would do a NA bigger cubic inch LS like a 408 or along those lines.
Old 01-18-2017, 01:38 PM   #58
sangell
We got the frame cut down, the exhaust will pass through the frame in the same location so it's getting an oval fish plate on the inside, 4"x.120 wall DOM sleeves, and straps both top and bottom. I ordered the bed header, Chevrolet stamped tailgate, and bedsides today to be picked up early next week.
We have a decent amount of 2"x.120 wall DOM laying around and we both prefer tubular cross members over stamped so we made some.
Old 01-30-2017, 03:26 PM   #59
sangell
Got the exhaust pass through and c notches done, the frame cleaned up and painted, having removable cross members sure made it easier. It'll be back to a roller tonight and tomorrow the bed comes in to be assembled as a short bed.
Old 02-06-2017, 04:19 PM   #60
sangell
Got the cab, doors, cowl, and trans tunnel back from the blaster and all of that cleaned up and in epoxy primer. The new short bed got assembled but then taken back apart simply because its too heavy for the two of use to move and it takes up less space in pieces. A picture of Nick cleaning up the paint gun.
Old 02-07-2017, 03:17 PM   #61
big_al_71
big_al_71's Avatar
Projects with the kids are always awesome
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 04-03-2017, 10:26 AM   #62
sangell
Just been working on sheet metal replacement and getting the cab/doors ready for paint, they have been blocked with 400g and we are hoping to finish up with the 600g this week, then its onto the front clip. Got some parts back from powder coating, wheels, vent window frames, mirrors, and door handles.
Old 04-26-2017, 10:55 AM   #63
sangell
Cab, doors, hood, and front fenders are ready for paint. Hoping to have the bed ready by the weekend. Got the tires mounted on the new wheels yesterday.
Old 05-01-2017, 09:01 PM   #64
ChuckLee
Wow! Sounds like you will have some exciting pictures to show not to long from now!
Old 05-01-2017, 09:45 PM   #65
kehstr
kehstr's Avatar
what color are you painting it?
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 05-01-2017, 09:54 PM   #66
sangell
Satin black.
Old 05-25-2017, 11:02 AM   #67
sangell
Things are moving along, paint is done and we are close to finishing up the front and rear suspension upgrades.
Old 05-28-2017, 07:10 PM   #68
kehstr
kehstr's Avatar
are you not going to do A/C on this truck?
@Chad's Fab
Old 05-28-2017, 09:10 PM   #69
sangell
Not right now, maybe down the road.
Old 06-02-2017, 02:19 PM   #70
sangell
Getting closer, hoping to get it to the alignment shop tomorrow afternoon. We are leaving on the Hot Rod Power Tour Sat June 10 and doing the long haul.
Old 06-02-2017, 02:30 PM   #71
nastety92
Wow what a transformation. Your son must be so excited to start driving the truck again. I hope to do something like this will by son some day. He is 6 right now so I have a few years.
Your doing a great job and he will remember this Forever.
Nick
nastety92 is offline   Reply With Quote
Old 06-02-2017, 07:19 PM   #72
1968aj
what satin paint did you use?thinking of doing the same to mine.
1968aj is offline   Reply With Quote
Old 06-06-2017, 10:22 AM   #73
sangell
I used UreKem from thecoatingstore.com
Old 06-06-2017, 10:25 AM   #74
sangell
It's not quite done but it's close. My son and I are leaving long hauling the Power Tour starting Saturday. Total trip will be 1800 miles for us.
Old 06-22-2017, 04:22 PM   #75
sangell
Some pics of the truck on the Hot Rod Power Tour, ended up at 2208 miles.
