Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 07-03-2016, 09:36 PM   #51
oneshotkyle
Active Member
Re: New! Choppin' Block Suspension to Lay Frame
Wow, looks great thanks for the post. You should start a build thread. Looks like you have top notch taste. Keep us onlookers informed. Just a couple ?? What size rear tire in the pics, looks like a ton of inward room. Are you doing body drop too?
oneshotkyle is online now
Old 07-03-2016, 09:40 PM   #52
Jcoleman7827
Thanks! The rear tires are 405/25/24 on a 24x15 wheel. The axle is getting narrowed right now taking 8" off each side while the frame and suspension are at powder coat. Yes, that is with their body drop also, you can see the new frame horns bolted on up front.
Jcoleman7827 is offline
Old 07-04-2016, 12:50 PM   #53
Pro Performance
Pro Performance's Avatar
What's up with the choppin block setup for 67-72's. This seems like the way to go for us guys that are gonna convert long beds to short. These seem to be an excellent option without the wait. Wish there were more customer write ups to see hear the pros/con's.
[QUOTE=Jcoleman7827;7642718]I've been installing the kit on my 72 over the last couple weeks. Overall I would definitely recommend the kit, it went on pretty easy and I would only buy it from AZPro due to all of their help.
The cons I would say are there are no formal directions but AZProPerformance has their own version that helps a lot, however it's not detailed like the PB ones I've seen.
Also, I didn't get it as quick as I had hoped and when I did get it the frame stiffener was the wrong one and it took 2 more weeks to get the correct one. I believe even after that it was still faster than getting a PB kit.
Thanks for posting Josh and glad oneshotkyle was able to get some good feedback from a customer. Frame looks great!
There will eventually be a complete install video, but is taking longer than expected, since they have been overwhelmed with getting the kits out the door. We are here to answer any questions you have though and walk you through the process.
Have a great 4th everyone!
Pro Performance is offline
Old 07-04-2016, 12:54 PM   #54
oneshotkyle
Active Member
On the front kit. Do we know any specifics on oil pan needed for ls engine or headers that will work?.
Old 07-04-2016, 12:55 PM   #55
Pro Performance
You will want to go with the F-body pan. As for headers, anything that is close fitting, like the Hooker manifold style, etc. Others will work, but this is one example.
http://www.azproperformance.com/Comp...-Swap-Kit.html
http://www.azproperformance.com/Hook...-8501-HKR.html
Old 07-19-2016, 06:46 PM   #56
Jcoleman7827
I have most of the kit all together now and it went very smooth. I can't say enough good about Travis from azproperformance for answering all my questions as this was my first time taking on a project this big. The fuel cell and air tank are still at powder but they will be red as well.
Old 07-19-2016, 08:27 PM   #57
Bennett68C10
Bennett68C10's Avatar
That frame looks awesome!
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline
Old 06-03-2017, 01:02 AM   #58
Pro Performance
We have these kits in stock, with more on their way. Also, the 73-87 kits are now all available as well!
Old 06-06-2017, 02:29 AM   #59
Pro Performance
Another customers frame going together with these kits.
Old 09-18-2017, 03:09 PM   #60
bdydrppup
Any Idea if I could use this rear kit in a suburban?
bdydrppup is offline
Old 09-18-2017, 07:31 PM   #61
Pro Performance
It won't work in a suburban because the back half length for a short bed (and body mounts) won't be correct for what is needed on a suburban.
Old 09-19-2017, 04:24 PM   #62
gmduran1
Do you have anything in works for a 59 Apache?
gmduran1 is offline
Old 09-19-2017, 04:52 PM   #63
Pro Performance
They have it on their list to complete, but may be a little while until it is done and ready to ship. When they do, we will make sure to post it up here.
Closed Thread
