Old 06-28-2017, 02:21 AM   #51
71Sleeper
71Sleeper's Avatar
Re: Carving the Jake-olantern
Pro15 everything completed. Gotta love this stuff. Goes on easy and is tough.
71Sleeper is offline   Reply With Quote
Old 06-28-2017, 02:24 AM   #52
71Sleeper
71Sleeper's Avatar
Just more Pro15 being applied.
Old 06-28-2017, 02:30 AM   #53
71Sleeper
71Sleeper's Avatar
Well I had a choice buy after market trailing arms or buy a new welder. Hmmmm... New welder won out. So more welding and learning. By the time I was finished I'm getting more confident. They turned out good. This is the only pick I can find during the process.
Old 06-28-2017, 02:34 AM   #54
71Sleeper
71Sleeper's Avatar
Getting all new hardware. My local Tractor supply store knows me by name now.
Old 06-28-2017, 02:43 AM   #55
71Sleeper
71Sleeper's Avatar
Bolting up the rear. This is about the time I'm getting excited. Wish my son had more time to spend with me on the project. But being 16 now and full on Baseball and Football Not to mention new heightened interest in the other sex. Getting him involved is a challenge. Oh well one day he will come around.
Old 06-28-2017, 02:51 AM   #56
71Sleeper
71Sleeper's Avatar
And some No Limit gear on the rear. Pan hard bar kit and shock relocating kit. I need to order the rear swaybar now. Looking at the pic I need to adjust the panbar some.
Old 06-28-2017, 02:57 AM   #57
71Sleeper
71Sleeper's Avatar
Just pics of front going together.
Old 06-28-2017, 03:00 AM   #58
71Sleeper
71Sleeper's Avatar
Couple of my favorite pics.
Old 06-28-2017, 03:03 AM   #59
71Sleeper
71Sleeper's Avatar
Back to being a roller in almost 2 yrs. Man how time flies by on a project.
Old 06-28-2017, 03:08 AM   #60
71Sleeper
71Sleeper's Avatar
Almost forgot to mention I'm running the JB7 calibers on the front. Gotta place an order with Captain Fab for my rear disk kit to run the JB6 D52 calibers.
Old 06-28-2017, 03:19 AM   #61
71Sleeper
71Sleeper's Avatar
Oh and I scored a great deal on a clean gen 4, 5.3 with 799 heads. First mock up of motor to check header clearance. Will need to set cab back on also.
Old 06-28-2017, 03:24 AM   #62
71Sleeper
71Sleeper's Avatar
Plenty of clearance.
Old 06-28-2017, 03:29 AM   #63
71Sleeper
71Sleeper's Avatar
Using set of 85 c10 clam shell and engine mounts with ES bushings connected with Dirty Dingo ls mounts.
Old 06-28-2017, 08:57 AM   #64
meenaggie
What brand and part number are those headers? Look like they might give me the clearance needed for the steering shaft on the No Limit IFS setup that uses a rack and pinion that I am running on my 68 C10 with a LS6. Looks great by the way.
meenaggie is offline   Reply With Quote
Old 06-28-2017, 03:06 PM   #65
71Sleeper
71Sleeper's Avatar
The headers are some that were bought off eBay for a 70 camaro ls swap that were laying around the shop. I will get the part number for you later.
Old 07-08-2017, 11:41 PM   #66
meenaggie
Did some research and those look like the Speed Engineering LS swap headers. I was glad to see them on a C10 to get a better idea of fit.
https://www.speed-engineering.com/fe...c10-truck.html
Old 07-25-2017, 04:48 AM   #67
71Sleeper
71Sleeper's Avatar
Yes those are the headers
Old 07-25-2017, 04:57 AM   #68
71Sleeper
71Sleeper's Avatar
Got the cab set in to check engine placement. I only have about 1/2 inch more that I can move the motor back left on the Dirty Dingo mounts but I think it's good where it is now.
Old 07-25-2017, 12:49 PM   #69
Devil Pup
Devil Pup's Avatar
cool build so far. what is all the added cross bracing for on the frame? strength?
Lifted 2wd 1969 C20/ 5.3LS/4L60E :http://67-72chevytrucks.com/vboard/s...d.php?t=728388
Devil Pup is offline   Reply With Quote
Old 07-25-2017, 09:30 PM   #70
71Sleeper
71Sleeper's Avatar
Yes just added strength. trying to reduce some flex. Plus it just looks cool.
Old 07-26-2017, 12:30 PM   #71
Devil Pup
Devil Pup's Avatar
It does look cool, was just wondering what the reason was. will be following along on your progress.
Old 08-21-2017, 06:53 AM   #72
71Sleeper
71Sleeper's Avatar
Got a couple things accomplished this weekend. CaptainFab rear brake kit and No Limit rear sway bar. Can't say enough good things about both.
Old 08-21-2017, 08:27 AM   #73
71Sleeper
71Sleeper's Avatar
Just thought this was a cool pic to share.
Old 09-25-2017, 12:51 AM   #74
SierraMtns
SierraMtns's Avatar
Cool build.
Why did you go with 85 c10 engine mounts?
SierraMtns is offline   Reply With Quote
Old 10-06-2017, 12:22 PM   #75
Steve Cole
Just curious if you have the exhaust hooked up yet or if not, do you see any issues with how close the header/exhaust pipe is to the starter? I am thinking of getting a set of those headers but a little concerned how close they are in that area. Thanks.
Steve Cole is offline   Reply With Quote
