Old 12-28-2016, 09:08 PM   #51
palposity
palposity's Avatar
Re: 1984 K30 Project Plow Truck
Sadly, Cletus was sold after a series of ill-fated decisions on my part a few years back. and this is the worst winter so far since I sold Cletus. I was pleased to have the experience building it though and ready to get more momentum behind my other truck. Just need this darn cold winter to go away so I can spend more time on it.
I do want another K series sooo bad right now! I guess I will have to live vicariously through you!
Project #1 "Pops"--1980 Chevrolet Scottsdale C10 3rd Generation in the same original owner family. GOAL: Restore to "almost" original.
View Project Pops HERE
Project #2 "Cletus"--1986 Chevy K20 4.10 Gear Ratio GOAL: Restore into a heavy duty work/plow rig
View Project Cletus HERE - SOLD
DD--2008 Duramax CCSB
palposity is offline   Reply With Quote
Old 12-29-2016, 05:45 PM   #52
MTCK
MTCK's Avatar
Ah bummer well I know how that goes. If I had unlimited funds and space I would never sell a truck but neither of those things are true.
Bet this is as light as the ass of this truck has been since it rolled off the factory floor and headed for the upfitters. Also installed a rear view mirror. Being able to see directly behind me will be nice. I hope I'm not giving up too much traction. Big storm headed this way!
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 12-30-2016, 05:45 AM   #53
MTCK
MTCK's Avatar
Sure is nice being able to see out the back! She earned it tonight.
-Marcus
Project Plow Truck
Old 12-30-2016, 05:46 AM   #54
MTCK
MTCK's Avatar
Plowed six hours tonight and already got a foot. Supposed to keep coming through Saturday.
-Marcus
Project Plow Truck
Old 12-30-2016, 05:48 AM   #55
MTCK
MTCK's Avatar
Traction wasn't an issue at all. Seeing while driving between houses was.
-Marcus
Project Plow Truck
Old 12-30-2016, 05:49 AM   #56
MTCK
MTCK's Avatar
Glad I can defrost between pushes. It would be a mess otherwise.
-Marcus
Project Plow Truck
Old 12-31-2016, 04:37 AM   #57
MTCK
MTCK's Avatar
Another 4 hours of plowing the 4-6" we got overnight. Mostly uneventful until I was plowing back at the barn and a Ram5500 roll back truck with a Nissan Pathfinder on the back got stuck in the drive. First time I had to put it in low range but she pulled him right out. Should have good wrecker karma for a while now.
-Marcus
Project Plow Truck
Old 12-31-2016, 09:56 PM   #58
joe231
joe231's Avatar
CHEVY ONLY
Old 01-13-2017, 05:50 AM   #59
MTCK
MTCK's Avatar
Got a break in the snow so I decided to do a little maintenance and clean up the plow. It looks pretty shabby.
-Marcus
Project Plow Truck
Old 01-13-2017, 05:53 AM   #60
MTCK
MTCK's Avatar
No sooner did I tear it apart than the weatherman said never mind the cold and clear here comes more snow. Now I need to hustle and get it back together.
-Marcus
Project Plow Truck
Old 01-13-2017, 08:50 AM   #61
Greenlee
Greenlee's Avatar
You are are making all that snow look kind of fun! Makes for a good excuse to go out and play with your trucks.
Greenlee is offline   Reply With Quote
Old 01-14-2017, 04:09 AM   #62
MTCK
MTCK's Avatar
Haha it's lots of fun! Replaced a solenoid / valve and check valve so hopefully it works as good as it looks, which is ok.
-Marcus
Project Plow Truck
Old 01-14-2017, 04:10 AM   #63
MTCK
MTCK's Avatar
Got all the plow parts back together and the pump / valve assembly painted. It will go together in about 5 min tomorrow.
-Marcus
Project Plow Truck
Old 01-14-2017, 04:12 AM   #64
MTCK
MTCK's Avatar
Pretty comfortable with how this whole thing works now that I've taken it apart a couple times.
-Marcus
Project Plow Truck
Old 01-15-2017, 12:47 AM   #65
Jaysonb
Jaysonb's Avatar
Plow looks good!
Jaysonb is offline   Reply With Quote
Old 01-16-2017, 07:23 PM   #66
400/400
Nice work on the plow! Looks like your getting good use out of it. I've only had mine on the truck 3 times so far this winter.
1979 K25 350/SM465/205/44HD/14FF
1985 K20 400/400/208/10/14
1987 V10 TBI350/700R4/208/10/10
'85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968
400/400 is offline   Reply With Quote
Old 01-17-2017, 03:41 AM   #67
MTCK
MTCK's Avatar
Thanks guys! She is earning it this winter. I got oil pan and trans pan heaters that I need to install but I've been parking at the hanger which is a way better option. More snow tonight then dropping to minus a bunch tomorrow.
-Marcus
Project Plow Truck
Old 01-17-2017, 03:42 AM   #68
MTCK
MTCK's Avatar
Oh and the plow functions flawlessly after the repairs I made, more importantly.
-Marcus
Project Plow Truck
Old 05-23-2017, 04:07 AM   #69
MTCK
MTCK's Avatar
Plow truck is pressed into daily driver duty. Took the studs off and grabbed the 255's off the crew cab while my Tacoma is getting some PM done. I kind of like it.
-Marcus
Project Plow Truck
Old 05-23-2017, 04:09 AM   #70
MTCK
MTCK's Avatar
Think I'll also pick up a set of rear hub caps. These are the crew's.
-Marcus
Project Plow Truck
Old 05-23-2017, 04:10 AM   #71
MTCK
MTCK's Avatar
Whoops.
-Marcus
Project Plow Truck
Old 05-23-2017, 11:22 AM   #72
Matt Man
Matt Man's Avatar
I forgot you had this truck. How does the 292 do in the 1 ton? The 250 in my 67 is pretty slow...especially with the 3 on the tree, but I think its because it has the stock intake/header and a tiny 1 barrel carb
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 05-23-2017, 12:58 PM   #73
MTCK
MTCK's Avatar
It's a real tire shredder. Haha kidding obviously. It's not fast but it pushes like a tractor. Gas mileage is some of the worst I've ever seen. Keep in mind I'm going backwards a lot but averaging 5-6 when plowing. I'll get a tank through it this week and see how that compares. Short version is it keeps up with traffic just fine.
-Marcus
Project Plow Truck
Old 05-23-2017, 04:38 PM   #74
BossH0G
BossH0G's Avatar
Howdy MTCK I like what you done with the truck. I like the sound of AK to, sounds better every day. So long story short your truck and Alaska both rock
BossH0G is offline   Reply With Quote
Old 05-24-2017, 12:44 AM   #75
NewType72
NewType72's Avatar
Man theat girl just loves a good workout! I'm sure you're keeping everyone mighty happy with all the cleared roads. Keep up the great work!
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
