Old 03-14-2016, 10:41 AM   #51
robnolimit
robnolimit's Avatar
Re: No Limit Trailing Arm Rear Suspension
[quote=70inbville;7519620]
Originally Posted by robnolimit View Post
The drop amount is somewhat adjustable, but I would say you will be in the 5" to 7" area. Outside of this range and you start running out of the range in which the panhard rod stays in a range of 0 to 3 degrees from level. So, call it 6" with a little adjustment range.
Is this drop including the blocks or not? just checking before ordering parts I don't need. Thanks
Good question. let me clarify.
To get the long shock/travel/ride/performance, in a way, total drop was the sacrifice point. WITHOUT a block, just the kit, with the axle directly on the trailing arm, the drop amount is 4" - 5". And, we would like the shock to stay in it's sweet-spot for the best performance. Yes, you could screw down the shock, or run a shorter shock, but that kind-of defeats the purpose. So, if you want more drop, add a 1" (5" - 6" drop) or 2" (6" - 7" drop) block. Blocks and U-bolts are not included with the kit.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 03-14-2016, 10:43 AM   #52
robnolimit
robnolimit's Avatar
Originally Posted by BAGGEDLB7 View Post
How well would this setup work for 1/4 mile launches?
Hmm, well, much better than OE or modded OE, due to the increased anti-squat %, and the shock quality and softer spring. But, for hard core drag use, a 4 link would be best.
Old 03-14-2016, 12:18 PM   #53
70inbville
Thanks Rob, I want the ride and drop of about 7 in so yes to the blocks. any worries of scrub line with a 16 in wheel with this kit at that drop?
70inbville is offline   Reply With Quote
Old 03-16-2016, 10:02 AM   #54
robnolimit
robnolimit's Avatar
Scrub line would be close. The lowest point of the system (like a stock trailing arm), is the U-bolt and hardware under the axle. With out any blocks, this is 5.75" (measured from the axle CL down to the lowest point) with our trailing arm kit. So, with a 2" block, you will have 7.75" from the axle CL down, and a 16" rim will have a scrub line of appx 8.2". So, it's close with a 16" wheel, but you will have .45" to spare.
Old 03-16-2016, 10:31 AM   #55
70's luvr
I'm about to put a c-notch in and am really interested in your version that doesn't hack more than whats needed.
70's luvr is offline   Reply With Quote
Old 03-16-2016, 04:45 PM   #56
70inbville
0.45" is a tad close, need to change that plan a bit. I would had to drag on a pebble in the road. Rob, thanks for the great info and help with the plans of many here!!
Old 03-16-2016, 07:02 PM   #57
crakarjax
crakarjax's Avatar
Scrub line only applies to flat-tire situations
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 03-16-2016, 09:10 PM   #58
70inbville
that is also good info to have thanks
Old 03-17-2016, 09:23 AM   #59
Skippy77
What a great new option!
Any plans to make this compatible with your raised rear rail kit? Is the test mule in the photos running your wide ride IFS? And if you have a picture with the bed back on yet I'd love to see it!
-Skippy
Skippy77 is offline   Reply With Quote
Old 03-20-2016, 12:17 AM   #60
SierraMtns
SierraMtns's Avatar
In the picts you can see that the truck has some rake, but the bed is not on. As soon as this is done, like this weekend, I'll get some picts and some finished ride height measurements. We should have done this on the other test trucks but things happen so fast as soon as they get to driving, and we missed the chance.
Hey Rob,
Any pictures with the bed on?
SierraMtns is offline   Reply With Quote
Old 03-21-2016, 10:45 AM   #61
robnolimit
robnolimit's Avatar
Did some more testing this weekend. Bed is on, Truck sits perfect, we put 3/4" of rake in it, to make it 'look' flat. At that point, we had 3.875" of 'up' travel avail, and over 4" of 'droop' avail. Ride quality and street handling is excellent! Our low tech testing with a few cones, and the memory of previous handling characteristics, shows the truck to have much more grip through the corner, a quicker corner entry, and a LOT more acceleration grip at corner exit (this is where it would get loose and want to spin before). I'll get picts up later today
Old 03-22-2016, 04:54 PM   #62
68Stepbed
68Stepbed's Avatar
No photos? You need to fire your photographer!! LOL
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 04-01-2016, 11:58 PM   #63
SierraMtns
SierraMtns's Avatar
Would still like to see some pictures with the bed on.
Old 04-02-2016, 11:36 AM   #64
robnolimit
robnolimit's Avatar
OK OK. Here are some picts. The truck sits good now with the bed on, but no floor in it yet. The truck has appx 1" rake. One of the things that slowed picts down is that the truck was apart again for a cam swap and a tune. The owner reports that the torque and throttle response is WAY better, and even with the increased power, the truck hooks and leaves with a lot less wheel spin. He also reports that mid corner grip and corner exit grip/acceleration inspires a LOT of confidence. (maybe too much) - But that it really stays connected to the road. The current spring is a 14" 225 lb. We are going to try a 12" 250lb spring to get a little bit more drop, more adjustment on the spring collar, and a bit firmer - about 10% is all. One pict shows the clearance in the notch at Ride Height.
Old 04-04-2016, 08:54 AM   #65
68Stepbed
68Stepbed's Avatar
That has a great stance! Thanks for the updated photos, Rob! Now time to start saving my pocket change!! lol
Matt
Old 04-04-2016, 11:04 AM   #66
robnolimit
robnolimit's Avatar
Thanks. I have some news coming soon. For the last few years I have been working on a purchasing plan for our customers. This could be huge for the consumer/builder, in the 'time-line' and 'financial planning' areas. It has never been done in Hot-Rodding before (and I understand why). We are very close to an announcement and testing. I'll keep you posted.
Old 04-04-2016, 03:49 PM   #67
68Stepbed
68Stepbed's Avatar
Oh really? I may have to swing by one day this week and see about the inside scoop on this!
Matt
Old 04-04-2016, 04:03 PM   #68
smbrouss70
smbrouss70's Avatar
Wish I lived that close... I'd have one of just about everything that No Limit makes... and I'd be single again...
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 04-12-2016, 11:12 PM   #69
Skippy77
Is this truck running your wide ride IFS?
Old 04-13-2016, 08:53 AM   #70
robnolimit
robnolimit's Avatar
The truck currently has the front Hotchkis TVS system on it, with drop spindles.
Old 04-13-2016, 09:52 AM   #71
SCOTI
SCOTI's Avatar
Interested in learning more about this.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-13-2016, 04:21 PM   #72
duallyjams
duallyjams's Avatar
awesome
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 04-16-2016, 08:50 PM   #73
SierraMtns
SierraMtns's Avatar
Hey Rob,
I have a couple questions before I place my order.
1. Could we order the kit with 12" 250lb spring?
2. Would this kit work with your guys rear sway bar?
http://www.nolimitengineering.com/pr...tegory=6157532
3. Would the kit work with this c-notch? It looks like it would but I am hoping you could tell from the pictures if it would or not.
4. Is the pinion angle built into the trailing arms or would I need to run shims?
5. Whats the lead time on one of these kits?
Old 04-17-2016, 11:19 AM   #74
SierraMtns
SierraMtns's Avatar
Now it's drill time. Use a 3/8" drill to drill out the rear hole for mounting the coil-over bracket. Then use 1 5/8" bit to drill through the frame for the upper coil-over mount bolt. Put the third mount bolt in place.
TIP: For the 5/8" hole, start with a 5/8" bit, using the bracket as a guide to center the drill. Stop after about 20 seconds. You should have the beginning od a hole started, in the center. Switch to a 1/4" bit and drill out a pilot hole, using the center from the 5/8" bit. Then go back to the 5/8" bit and open the hole up. This is much easier than fighting with the 5/8" bit all the way though.
*** Note the poition of the gusset on the mounting bracket. It is to the rear of the truck. There are 'left' and 'right' hand brackets. ***
Is a 1 5/8" bit needed or 5/8" drill bit? I marked it in red.
Old 04-17-2016, 11:23 AM   #75
SierraMtns
SierraMtns's Avatar
This truck already had a bolt-in notch. Now, lets talk about that. Shame on the aftermarket. Shame on them for helping you cut into your truck for no reason. ??? OK, the frame is approximately 4" tall (rail height), keep that in mind. Also, the rear gear housing is about 4" above the top of the axle tube. (top of center chunk to top of axle tube. So, if you pull the bump stops, and the axle travels up to hit the bottom of the frame, the top of the center section (gear housing) is even with the top of the frame. Are you with me so far? Now realize that the OE bed floor is .75" above the top of the frame. (Or worse, even with it if it's a wood floor). So, if the axle travels up more than 3/4" into the notch, WHAMMO, it hits the bed floor. So, if your keeping the OE bed floor, a 1" notch with a side mounted bump stop is all you need, and you wouldn't cut the frame so much.OK, I know some of you want it lower, and will cut a hole in the bed floor, but that's not what we're doing here. Please think about the notch thing before you cut.
We are working on a notch kit with bump-stops included, but the forming match may take another two months. We are not going to include bolt-in C notches with this kit. We will have them available separately. But, sincle so many trucks are already notched, we are not going to force you to buy something that you don't need, or don't want.
How is the notch coming along? We are close to months out from when you posted this.
Also would the notch work if you are running this kit with 2" blocks? Or would you need to run a deeper notch?
