Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 07-23-2016, 11:34 PM   #51
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Project Sloppy Jo.....
Started taking the driver side apart. Little more worse than the passenger side. You got to love the technique. The patch over the driver floor actually was welded to the rocker box. holding it up I guess.....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 07-23-2016, 11:44 PM   #52
71meangreenc10
So I remember in Casino, De Niro's car blowing up and he stated that no one knew that a steel plate on that model car was put under the driver seat. I think this was the idea when they added the plate under the patch over the cab mount......Nice
Smitty
71 C30 Wrecker
Old 07-24-2016, 08:11 AM   #53
lks dcvn
lks dcvn's Avatar
Wow - it's amazing what people do to their vehicles over the years...
I will say that over the past decade - more and more Blazer/Jimmy replacement sheet metal has hit the market so that helps those who are digging into restorations like you have done.
lks dcvn is offline   Reply With Quote
Old 07-24-2016, 09:58 AM   #54
71meangreenc10
Aluminum pop rivets everywhere.......
Sad, just sad......At least I can reuse that big piece of steel for patches.....
Smitty
71 C30 Wrecker
Old 07-24-2016, 07:06 PM   #55
71meangreenc10
Got the A pillar patch put in. Mocked the toe board patch and put it in along with the slip on mount. Tomorrow, put the rocker box in.....
Smitty
71 C30 Wrecker
Old 07-29-2016, 10:02 PM   #56
71meangreenc10
Rocker box complete, front floor ready for installation. That gets done in the morning, then fix the back floor....
Smitty
71 C30 Wrecker
Old 08-02-2016, 12:02 AM   #57
71meangreenc10
Front floor is now one piece again......No more pop rivets and tin patches for this old girl.......Got the rear fender prepped for repair tomorrow along with the wheel well patch welded in....Keep on moving.....
Smitty
71 C30 Wrecker
Old 08-02-2016, 12:52 AM   #58
lks dcvn
lks dcvn's Avatar
Nice work on the rust repair - it's good to see all that old shoddy work replaced with new solid metal.
Old 08-02-2016, 01:02 AM   #59
71meangreenc10
Thanks,
Front is so solid now. It was beyond terrible before....
Smitty
71 C30 Wrecker
Old 08-02-2016, 11:11 PM   #60
71meangreenc10
Front floor sealed and ready for work.
Smitty
71 C30 Wrecker
Old 08-08-2016, 12:43 AM   #61
71meangreenc10
Got the top on and now the fun of getting the sides square and doors aligned......
Smitty
71 C30 Wrecker
Old 02-10-2017, 10:29 PM   #62
71meangreenc10
Weather is nice so it is time to get back on Sloppy Jo....Picked up a nice Single Wall top. Squared up the tub and welded in the passenger rockers today. Got the door shutting smooth. Should be able to finish everything on the passenger side tomorrow then it is on to the driver side....
Smitty
71 C30 Wrecker
Old 02-11-2017, 10:55 PM   #63
71meangreenc10
Passenger side is completed with all metal repairs. Now working the drivers side. Once that is done, strip it for paint....
Smitty
71 C30 Wrecker
Old 02-14-2017, 10:31 PM   #64
71meangreenc10
Driver side now completed. Got to weld up a few straggler holes and then it is on to stripping and prepping for paint. Had to stretch this rocker a little to make it work. Structural work is now completed.
Smitty
71 C30 Wrecker
Old 02-17-2017, 08:03 PM   #65
71meangreenc10
Got Frame?
Smitty
71 C30 Wrecker
Old 02-22-2017, 04:18 PM   #66
71meangreenc10
Got the aftermarket tailgate put on today. New tooling on this has turned out a great product. Keep working.....
Smitty
71 C30 Wrecker
Old 03-08-2017, 11:56 PM   #67
71meangreenc10
Fuel line issue is solved.....
That mastercool flaring tool is the cat's meow......
Smitty
71 C30 Wrecker
Old 05-18-2017, 09:57 PM   #68
71meangreenc10
Got the fuel tank mounted up today. Made the new cross member to mount the tank up in the front with the stock straps from a 88 blazer. Going to run rubber straps between the tank and braces and insert some in between the tank and cross members.
Smitty
71 C30 Wrecker
Old 07-15-2017, 03:57 PM   #69
71meangreenc10
Finally got back to focusing on Sloppy Jo after building a porch for the wife. Got some primer laid on the frame. So far so good. Shoot another coat tomorrow, flip it over and give the bottom some love. Will be in color next week.
Smitty
71 C30 Wrecker
Old 07-21-2017, 04:18 PM   #70
71meangreenc10
Started to get the black on the frame today. Not bad, not bad at all....
Smitty
71 C30 Wrecker
Old 07-23-2017, 08:44 PM   #71
71meangreenc10
Sent old Sloppy Jo to the blaster and I now get to see some more Bondo Bandit repairs. Driver rear was full of it. Wife said it looked like it was shot with a shotgun, I called it Bondo Buckshot. Passenger side it repairable as is. Header needs to be cut out and some one slung a ton of Bondo in the hood. I started fixing the hood today and will get the welds grounded down tomorrow. I am not even saying I am perfect and there is a need for filler, but man they went crazy here.....
Smitty
71 C30 Wrecker
Old 07-23-2017, 08:45 PM   #72
71meangreenc10
More.....
Smitty
71 C30 Wrecker
Old 07-27-2017, 09:55 PM   #73
71meangreenc10
Got to cut out old Buckshot today. Got to love the metal bracket that the bondo was holding. It really was holding the bondo together. Sad.....Old patch panel cleaned up, all the black marks are paint, it is a straight patch....
Smitty
71 C30 Wrecker
Old 07-28-2017, 10:11 PM   #74
71meangreenc10
Shot some epoxy on the hood, got some more dents that need fixing, but it should be easy fixes. Cut out the patch for the rear quarter, put it in tomorrow.
Smitty
71 C30 Wrecker
Old 07-28-2017, 10:33 PM   #75
briank
Always amazed at whats hiding under the paint. Doing a great job!
briank is offline   Reply With Quote
