#51 |
Re: Best brand of windshield?
Sorry, everyone. I have not been on here a lot lately. The windshield came very nicely packed. It was the correct fully lightly tinted model that I was looking for. It was slightly thinner than the original one that I had, but when looking at the side it seemed to be three ply where the original looked like two. That could just be the way things looked though. I have no way to confirm how many ply's either were. I had a glass installer do the actual install. I helped him do it. Before he got there, he wanted me to have the gasket and trim on it. I had brand new trim. I fought with the new trim for a while before deciding to try the original trim. The original trim fit like a glove. So, I spent the time to polish it and remove a few small dings. I also bought a new back window. I had the same issue. The brand new back trim fit like garbage in the corners. And I bought them both from a well known vender that advertises here quite often. My wife and I put the back window in ourselves with no issues (other than the trim not staying tight in the upper corners). The only issue that I have with the windshield is that on the top driver's side, on the inside the seal is a little rippled. That seems to be a common issue. I guess starting the install from the top helps to avoid this. The guy that did mine wanted to start on the bottom. He said that the seal would start to settle in after a while. It may be doing that a little, its hard to tell. I doesn't really look that bad. It looks great from the outside.
So... I would say that I would recommend the windshield and back window from Summit. They are OER branded, and other retailer's carry them as well. Summit is really good to work usually if you have an issue, so I went with them. |
#52 |
Maybe they got a new batch, but mine was incorrectly tinted. It did come in an OER box but the glass inside did not, I do not think, say OER in the corner. Does yours?
#53 | |
What was wrong with your tint Dave. I heard that you had a lamination issue also, isn't that correct? |
#54 | |
It was also missing the lamination in the corner for about 1.5". The seal itself covered the outside 1" of it, so you only saw a little corner once it was installed, but I'm glad I had it replaced anyway. If I had it to do over again (and they offered to do it for free!) I'd make sure I had new stainless. I and a friend tried to install it 5-7 times and that took a bit of a toll. Plus one of my pieces is repro and you can tell it's not as tight a fit. So I will collect a set of OEM stainless, get it polished, and then redo it I think.
#55 | |
#56 | |
If you hold a white cloth up behind it, it should have a noticeable green tinge. The Summit one was just a little grey, at least in my case. There was definitely SOME tint because the area where the lamination was missing was very clear in comparison.
#57 | |
Six in a row makes it go...
![]() Join Date: Mar 2009
Gonna call Bob's Classic Window next. My side glass is pretty good, but since I'm going to pull it and the vent windows to re-do the channels, I might as well make the whole cab tinted.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce Last edited by Shaky; 07-12-2016 at 04:06 PM. Reason: Add info |
#58 | |
