04-17-2019, 09:21 AM | #51 |
motor exploder
Re: '65 Chevy Bel Air Wagon
I had a few cans of VHT 'cast iron grey' left over from another project, so that's what she got hit with, instead of the usual Chevy Orange. Fel-Pro oil pan gasket, timing cover gasket set, Fel-Pro rear main seal, new Water pump & wp gaskets (old one was super corroded inside) & new Carter fuel pump - I bumped the motor into the crossmember on the way out and bent the inlet tube on the other one - oops!
This motor was pretty grimy on the bottom. I pressure washed underneath after soaking it in degreaser before pulling it, but it was a bit of a chore getting all the gunk off without making a huge mess in the shop and on the driveway in front of the shop. The oil pan rail was pretty wavy, which is why it was leaking - I got after it with a body hammer and dolly and smoothed it out a fair amount. If it leaks, I'll be back to buying kitty litter! btw - old cork gaskets that were slathered in 'high-tack' gasket adhesive ON BOTH SIDES (!!!!) are a PITA to scrape off...
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
04-17-2019, 09:28 AM | #52 |
motor exploder
Of course, the older sister Irma got jealous over Wanda getting some attention, so naturally she finally got the 295/30/20 rear tires she's been hollering about ! I must've measured the wheel wells every which way 10x over, up on jacks with the bags deflated to make sure everything would fit. Most people only run a 255 or 275 on the back of these cars, but I was hellbent on stuffing a 295 in there and thank goodness it all cleared, barely, but it's all good.
These girls won't be getting much else this year, Daddy's broke now!!
04-30-2019, 11:11 AM | #53 |
Sweet wagon! I'm a wagon fan myself. Mine's a 65 Buick skylark with the engine, trans, wiring harness, dash cluster and steering column out of a 99 Chevy Silverado.
I cringed at the pictures of the deer incident, but it looks likeshe's in good hands. Nice work to Wanda and Irma. -Josh
1967 Buick Special wagon 1968 Jeep Wagoneer 1958 Chevy Panel Truck 2017 Suzuki M109R |
