04-28-2017, 11:56 AM | #51 | |
Re: 49 chevy 1433
[quote=northern 49;7928271]
04-28-2017, 11:58 AM | #52 |
Re: 49 chevy 1433
I didn't order a column. I found a used one for 75 bucks. I just ordered the steering u joints and shaft and a support heim. That set me back about $300.00.
My work in progress http://67-72chevytrucks.com/vboard/s...d.php?t=720672 |
04-28-2017, 12:01 PM | #53 |
Re: 49 chevy 1433
[quote=NeoJuice;7928275]I will draw up a diagram and put it on here. Hopefully that will help you out and a few others aswell.
04-29-2017, 06:49 AM | #54 |
Re: 49 chevy 1433
Making great progress!!
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
06-08-2017, 11:07 AM | #55 |
Re: 49 chevy 1433
Any updates on the build ?
06-08-2017, 08:47 PM | #56 |
Re: 49 chevy 1433
When do you plan to have the truck on the road?
06-10-2017, 12:19 AM | #57 |
Re: 49 chevy 1433
Sorry not much for updates, life happens. Started working on a front panel for my box at work. I will post some pictures of that soon. I also finally bolted my intake manifold on but that's about it.
06-10-2017, 12:28 AM | #58 |
Re: 49 chevy 1433
nice work, thats how I "fixed" my fenders too, pounded out the dents and welded the cracks/tears. looked great and no need for a patch.
use a 88-98 bench, fits great and a lot of room. well a lot more than the stock bench, chewing on the steering wheel
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
06-10-2017, 12:28 AM | #59 |
Re: 49 chevy 1433
I don't know, I don't want to set myself a time frame, I think I would just let myself down. when I started this build I told wife it would be ten years, of the four years I have owned it I have really only worked on it for two and got more done than I expected but lately there hasn't been alot of extra time or money. I'm not giving up though.
06-10-2017, 12:30 AM | #60 |
Re: 49 chevy 1433
Thank joedoh, I've gotten a lot of inspiration from your builds.
08-24-2017, 12:07 AM | #61 |
Re: 49 chevy 1433
I haven't worked on the truck for a while. I put a little time into my '97 short box, it really needed some attention and there never seems to be enough time for my toys but I got an oil change done and it needed a new water pump. It sat for a month waiting on the water pump. The catalytic converter was also rattling so I took care of that. Then gave it a good thorough cleaning and some wax.
08-24-2017, 12:18 AM | #62 |
Re: 49 chevy 1433
My box had no front panel, so I decided to build one.
I had some old bed frame side rails laying around and I bought a 4x8 sheet of 16 gauge steel quite some time ago so I figured what the heck.I used the front lower bed brace for the width got to cutting and welding.
08-24-2017, 12:29 AM | #63 |
Re: 49 chevy 1433
I tacked together a frame, corners were cut a 45 degrees, clamped everything together and made sure the box was sqaured. Then I drilled the bolt holes in the sides and welded the corners inside and out. Then i cut a panel out of 16 gauge and used the big spot welder at work to weld it into the frame.
08-24-2017, 12:32 AM | #64 |
Re: 49 chevy 1433
Welding made easy.
08-24-2017, 12:37 AM | #65 |
Re: 49 chevy 1433
The welder is a Pro Spot I5 pressure resistantance spot welder. It is a full auto set machine and is really nice to have access too.
I think I'm pretty happy with how it looks. Just have to make new front floor brace now.
08-24-2017, 10:53 AM | #66 |
Re: 49 chevy 1433
Looking Good
08-24-2017, 03:58 PM | #67 |
Re: 49 chevy 1433
Nice GMT400!
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
09-10-2018, 11:49 PM | #68 |
Re: 49 chevy 1433
I know its been quite some time since I have posted anything, but that doesn't mean the truck is forgotten. I work on it when I can but life happens a lot.
I made a new toe board panel out of 16 gauge steel. Seemed like the best way to get rid of all the holes.
09-10-2018, 11:59 PM | #69 |
Re: 49 chevy 1433
I also took care of the firewall. I cut out the recessed area of each side leaving about a 5/8" flange then driledl 5/16" holes that I plug welded from the inside. I will finish the seam with a small bead of seam sealer on the outside and then a little more generously on the inside.
09-11-2018, 12:02 AM | #70 |
Re: 49 chevy 1433
The picture above with the toe board was supposed to be here.
09-11-2018, 12:06 AM | #71 |
Re: 49 chevy 1433
The passenger side done the same.
09-11-2018, 12:09 AM | #72 |
Re: 49 chevy 1433
Oh yeah. I also scored some nice Cragars this summer. I always wanted a set of these.
09-11-2018, 09:09 AM | #73 |
Re: 49 chevy 1433
Those RWL Indy 500s aren't made anymore. Awesome score.
09-11-2018, 12:07 PM | #74 |
Re: 49 chevy 1433
The firewall looks good. I may borrow that for the 54.
09-11-2018, 02:42 PM | #75 |
Re: 49 chevy 1433
I like the firewall! much nicer than a bunch of patches.
the cragars look sweet too, they look great on these trucks.
