Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 07-21-2017, 07:11 PM   #51
stangtjk
Re: Crossbreed
And almost forgot......
Got the next project already. Unfortunately whoever "restored" it last time was a little to fond of Bondo lol.
stangtjk is offline   Reply With Quote
Old 07-21-2017, 07:13 PM   #52
stangtjk
Re: Crossbreed
And this one is another in my backlog.
Old 07-21-2017, 09:38 PM   #53
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Crossbreed
How did you make the Jig for the body? I am about to pull the body off mine soon and that looks like a good idea.
Did four years at Eustis, did not care for all the I-64 mess....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 07-22-2017, 12:31 AM   #54
stangtjk
Re: Crossbreed
Jig was pretty simple. Just 2 2x6s some leftover plywood and a hand full of carriage bolts.
Discussed it a little more in the link below but I pretty much just threw it together using leftovers stuff I had laying around.
http://67-72chevytrucks.com/vboard/s...&postcount=449
I live about 15 minutes from eustis and work at the shipyard.... Don't care much for the area myself. Would like to head out west to get away from this horrible humidity.
Old 07-22-2017, 12:57 AM   #55
71meangreenc10
Re: Crossbreed
Out west is where it is at...I love Sierra Vista, not oven hot like Tucson or Phoenix, just got to drive a little to get what I need.
Im going to shoot some skin or raptor on my under carriage.
That jig is just the ticket I needed...
Smitty
71 C30 Wrecker
Old 07-22-2017, 10:28 PM   #56
stangtjk
Re: Crossbreed
I like the raptor liner for the undercarriage. Easy to get different textures with it so you can dial it in to fit your preference. I don't think I'd ever use it for it's intended purpose as a bed liner though. Seems to hard and slick for that.
Old 07-23-2017, 08:38 PM   #57
71meangreenc10
Re: Crossbreed
Awesome info.
Smitty
71 C30 Wrecker
Old 07-28-2017, 05:52 AM   #58
guynamedloren
Re: Crossbreed
Making a little more progress. Took the front axle apart and stripped and painted it. Same for the springs and shackles and I replaced the bushings with some red poly ones from
prothane. I also started mocking up the rear axle. Almost have a rolling chassis again.
What kind of paint did you use on the front axle, shafts, etc? Looks great and nice build.
guynamedloren is offline   Reply With Quote
Old 07-28-2017, 12:24 PM   #59
stangtjk
Re: Crossbreed
The axles and shafts never actually got "paint". I liked the flat black look of the epoxy primer so I stopped right there.
Old 07-28-2017, 12:35 PM   #60
stangtjk
Re: Crossbreed
I attempted to move the truck under its own power for the first time in over a year. Didnt move far as the HMMWV wheels are rubbing on the tie rod ends. Not sure what I'm going to do about it yet. Wheel spacers are the easy fix.
The stock rod ends we're replaced with some 7/8" heim joints before I got it so the taper in the knuckles has already been drilled out for a 3/4" bolt. The 7/8" rod ends are 2" in diameter. I could step down to 3/4" heims (1.75" diameter) and gain 1/8" of clearance but I don't think it would be enough. 5/8 heims are only 1.5" which would probably do it but I think they are a little too small. If I run spacers I'll have to get some longer wheel studs because they are barely flush with the lug nuts as is.
Old 08-10-2017, 11:58 PM   #61
stangtjk
Re: Crossbreed
Got the steering issues worked out, pretty much had to redo all the po's work..
Decided to run wheel spacers for now. Ended up using a set of the adapter type, 1.5" up front and 2" in the rear.
Since I got the clearance I needed I drilled the knuckles out using a 7/8 step bit and used some tapered bushings from barnes to convert back to tie rod ends instead of heim joints. The heims we're 7/8-14 tpi vs the tie rod ends 7/8-18 tpi so I had to cut off the tie rod tube ends and weld on new ones with the correct thread.
Old 11-08-2017, 10:18 PM   #62
stangtjk
Re: Crossbreed
Stripped the quarter panels and took out the inner bed sides to get to the back side..... Shot epoxy primer on everything and hit the back side of the quarters with bed liner... Didn't want to risk painting just to have a rust hole bust through a year or two down the road. Glad I took the extra step because as I was wire bushing the rust off the back side a couple pitted areas busted through even though there was nothing noticable after stripping the outside.
Old 11-08-2017, 10:31 PM   #63
stangtjk
Re: Crossbreed
Fixed the double wall top.... Cut out each of the 6 sagging sections on top, glued in some rigid foam insulation and glasses over it all... It also got a coat of epoxy primer followed by raptor liner. As much of this stuff that I've used they should be sponsoring this build lol.
Old 11-08-2017, 10:38 PM   #64
stangtjk
Re: Crossbreed
More primer and raptor liner. Funny how priming over that last little bit of yellow makes it seem like I'm starting to get somewhere.
Old 11-09-2017, 05:27 PM   #65
Lieferson
Lieferson's Avatar
Re: Crossbreed
This thing is slick!
1970 1/2 ton 4x4 4spd Suburban
1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold
1971 K5 on 35s Traded
1972 K5 3/4 ton PROJECT Sold
Lieferson is offline   Reply With Quote
Old 02-11-2018, 10:54 PM   #66
stangtjk
Re: Crossbreed
Finally got a warm enough weekend to shoot some liner on the inside of the top. Came out pretty nice.
Tried to upload a few pics but getting an error message.
Old 02-11-2018, 11:06 PM   #67
71meangreenc10
Re: Crossbreed
Nice work on the top. You said you shot raptor through HVLP. What was the needle size?
Smitty
71 C30 Wrecker
Old 02-15-2018, 03:22 PM   #68
stangtjk
Re: Crossbreed
Finally able to upload pictures... Deleted browsing history and cookies and it started working again.....
I only used the hvlp to shoot the raptor liner on the frame using a 2.5 tip. Everything else I've done using the schutz gun.
Old 02-15-2018, 10:23 PM   #69
SeventyOne
Re: Crossbreed
This is an awesome build! More please.
SeventyOne is offline   Reply With Quote
Old 02-15-2018, 11:04 PM   #70
stangtjk
Re: Crossbreed
Started mounting the winch. I plan on clocking the clutch 180 so it sicks out the top of the mounting plate. With the 67-78 front clip I should be able to just reach into the bottom slot of the grill to access it.
Old 02-16-2018, 07:56 AM   #71
72ironmike
72ironmike's Avatar
Re: Crossbreed
Nice build & a testament to talent & perseverance !
72ironmike is offline   Reply With Quote
Old 02-16-2018, 03:44 PM   #72
SeventyOne
Re: Crossbreed
What was the "4x4 Challenge" between you and your friends you mentioned awhile back?
Old 02-16-2018, 04:19 PM   #73
stangtjk
Re: Crossbreed
The original challenge was who could build the best rig with a $4k limit but it evolved as time went on... By the time I jumped in on it everyone was a year into the challenge and all had pretty much blown the budget so I didn't feel bad about starting off spending over 5k.
As time went on all but two of us lost interest in actually building anything so the challenge kinda lost it's way. The others ended up with pretty much stock Jeep's (wranglers and a Cherokee). The one guy that did some building has a first gen 4 runner that we did a solid axle swap on.
In the end the challenge turned into a camping trip with a tiny bit of mild trail riding but my rig with the full blow resto wasn't drivable at the time.... My buddy with the 4runner likes to joke that I'm building a show truck...
Old 02-16-2018, 11:18 PM   #74
SeventyOne
Re: Crossbreed
If a quality build = show truck i think a lot of us are guilty
Old 02-17-2018, 11:43 PM   #75
twp1
Re: Crossbreed
Problem is when you start you want to keep it simple and cheap but with every turn you always want to try to go the extra step and you spend a little more than expected!!!! But when your done you will be more satisfied with the extra steps!!!!! I will be watching!!!!
twp1 is offline   Reply With Quote
